Question about Fellowes W11C Confetti-Cut Shredder
Where can i get parts for a fellows w11c shredder?
fellowesrep
  • 102 Answers
SOURCE: Fellows sb-95c shredder parts???
Call Fellowes Customer Service at 1-800-945-4545
Posted on Feb 23, 2008
dlundmark
  • 797 Answers
SOURCE: Fellowes Shredder Parent Part # 38605
If this unit is worth it to you, you can build your own gear.
Here is a link to get plastic repair materials to make plastic parts. This site also will have materials for repairing plastics.
Another possibility is to search Ebay for a unit like yours which has other problems. Never can tell... it may be there.
Make sure you ask for the model of the unit in your search (on the NET as well. The serial in this case is not needed.
Posted on Jul 26, 2008
t_vinson57
  • 58 Answers
SOURCE: T7CM Fellowes shredder -- internal parts
This is how a got my hard to fine gear!
Contact Michael Business Machines for your local dealer 1-800-223-2508
Good luck, Tom
Posted on Mar 27, 2009
SOURCE: Fellows T7CM Shredder
Make sure you remove all five screws--there's one hidden under the sticker on the underside of the shredding unit.
Posted on Mar 16, 2010
  • 2509 Answers
SOURCE: Fellowes W11C: will only run in reverse. Where
There is a switch to put it in reverse. This is not a sensor problem. All the sensor does is detect something in the slot.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Posted on Feb 26, 2011
Where is the fuse in the fellowes w11c?
There probably isn't a fuse. Or it's a non-replaceable one.
They suggest you allow it to cool for 20 minutes, when it becomes overheated it's supposed to shut down. Then in the case of a paper jam, try reverse, if that doesn't work, try forward again.
Aug 02, 2016 | Fellowes Powershred W11C Shredder 120V,...
Suddenly stopped. Power source is good.p Had been working ed. Does not go forward nor backward. Power source is goog.
It could be there is still some material in the cutting wheels. We have had this happen to our shredder a few times, do your best to get stuck materials free.
Good Luck
May 07, 2014 | Fellowes Powershred Personal W11C Shredder...
Fellowes W11C: will only run in reverse. Where are the sensors located?
Feb 26, 2011 | Fellowes W11C Confetti-Cut Shredder
Only runs in reverse
I just had this problem with my shredder. I think the problem started with a bin that was full. Running the shredder in reverse resulted in shredded paper being pulled up into the slot used to feed paper into the shredder. Some of this shredded paper was blocking the little plastic tab that activates the switch when paper is inserted, so the shredder would no longer start when paper was inserted. I emptied the bin and removed the shredded paper from the feed slot, being careful not to break the plastic "sensor" while removing the paper from under it. The shredder works fine now.
Dec 13, 2010 | Fellowes W11C Confetti-Cut Shredder
Machine won't come on . I think the sensors need to be cleaned
Try going to OfficeMax and buy some lubrication paper that is made to run through your machine. I had the same problem. It was like there was a short in the shredder. Bought the lubricating paper and it worked the first time. No problems since. Good luck!!
Dec 07, 2010 | Fellowes W11C Confetti-Cut Shredder
Runs only in reverse
Nov 06, 2010 | Fellowes W11C Confetti-Cut Shredder
Was shredding papers and unit stopped,and will not take anymore papers,but it will still go in reverse Fellowes model w11c
Make sure you use a can of compressed air and cotton swabs to cean the entrance and exit sensors.
Jun 11, 2009 | Fellowes W11C Confetti-Cut Shredder
Fellowes W11C Confetti-Cut Shredder Logo
66 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Jim Keysor
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
