Question about Microwave Ovens
My microwave goes on and does all the usual stuff except does not heat. It is an ETNA T2114RVS/E01. Any ideas why? Regards Conor
  • Microwave Ovens Master
  • 3,740 Answers
Hi Connor and welcome to FixYa, I am Kelly
There are 3 things that cause this symptom.
1. High voltage capacitor
2. Power diode
3. Magnetron
You can check the High voltage Capacitor by unplugging the unit and removing the outer cover.
Then locate the LARGE capacitor. Hold a screwdriver well back on the INSULATED handle and short across the terminals 3 times. If it is good it will for sure get your attention. (Bright Blue BANG) Then remove all of the terminals on ONE side of the capacitor. Probe the terminals with a multimeter set on R x 10K and watch for a jump in resistance and then it quickly drifts to infinity. Reverse the leads and do this again watching for a jump in resistance and then drift to infinity. It should do this each time you reverse the leads.
LOCATE the power diode it will have one wire or terminal that is connected to the HV Capacitor.
You must make sure one side of the diode does not have any connection. Then read resistance across the diode. Reverse the meter leads and read it again. It should show a very low resistance (ZERO "ish") in one direction and a very very high resistance or infinity in the other direction. Any other reading is a failed diode. I.e Zero both directions =Bad infinity both directions = BAD Resistance in ONE direction = good.
If both of the above pass the tests most likely the magnetron has failed. However if you happen to have 4 door interlock switches vs 3 you could have a bad door interlok switch. Since you said it makes all the right noise but does not heat... I suspect one of the 3 components above.
After repairs make sure you have reconnected the Capacitor and Diode.
Thanks for choosing FixYa,
Kelly
Posted on Apr 11, 2011
  • kutlhanga Apr 11, 2011
    Thanks kelly. I will try these things and let you know.
    Rgs Conor
Everything works except the food does not heat up. Any recommendations?
This could be a diode or a capacitor. It is not expensive to fix if you have the time and patience. If you don't then you should take it into someplace to have it repaired.
Apr 24, 2015 | GE Profile Spacemaker XL 1800 36"...
Went to use and everything works except it does not heat
No heat means that the magnetron circuit has failed. It is the part the generates the microwaves that heat the food. Magnetrons replacement cost are high, usually as much as a new oven so it is rarely cost effective to repair. Sorry.
Jan 08, 2011 | Whirlpool MH1140XM Microwave Oven
When microwaving with my cad cm4ss microwave. after a minute or two it switches off and shows E01 It does not happen every time. Any idea what the fault may be
Error 01 is usually magnetron failure. I suspect the connections to the magnetron may be poor.
Watch out as lethal voltages are at that point!
Nov 09, 2010 | CDA Microwave Ovens
Over Stove Microwave, all works except doesn't heat
Hello. The problem you are having with your microwave is due to either a shorted rectifier or a shorted magnetron.
Regards, Joe
Dec 23, 2009 | Microwave Ovens
Lg microwave oven mc9283jlr error=e01
My LG microwave heating is OK but the grilling only not working
Jul 06, 2009 | LG Microwave Ovens
Microwave is not cooking/heating.
sounds like the magnatron they can just go out like a light bulb easier to buy a new microwave hope this helps regards Jim
Apr 13, 2009 | Microwave Ovens
Everything works except heat
this is something you should probably call a repair technician for, due to the danger of the componentry.
Usually in ther case of this problem, even a technician will advise you to replace the unit, in the minds of cost effectiveness and safety...
Mar 21, 2009 | GE JE1540 Microwave Oven
GE Spacemaker Microwave JVM165OWB005--No more heat!
If you look at consumer affairs.com, there are many problems like this with GE microwaves. Not a good track record, experiencing problems with mine as well.
Apr 15, 2008 | GE JVM1650 1000 Watts Microwave Oven
Used tefle coated tin micro+convection oven
There are some times when it is ok to use metallic stuff in a microwave. This is probably one of them. But you won't get the manufacturer to agree. Metal concentrates the microwave energy making a strong enough local electric field to cause sparks and heat. Usually burns that spot. Do you have one of those popcorn cookers for microwaves? Works by heating a special pad in the bottom just right.
What the manufacturer is saying in the warning is:
Don't sue us if you use metal in this oven and something goes wrong.
Feb 07, 2008 | Microwave Ovens
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
