How to setup the printer so that i can start using it
  • 97 Answers
Please refer to your printer's manual, there's a how-to-guide there to setup your printer and connect it to your PC desktop.
Hope this helps.
Posted on Apr 11, 2011
How do I solve a problem with a Epson printer that wont print because of error messages saying that printer is incompatibke with somthing called ENPAPP
If your enpapp.exe error is related to a specific program, reinstalling Epson Connect Printer Setup-related software could be the answer.
Instructions for Windows 7 and Windows Vista:
  1. Open Programs and Features by clicking the Start button.
  2. Click Control Panel on the right side menu.
  3. Click Programs.
  4. Click Programs and Features.
  5. Locate enpapp.exe-associated program (eg. Epson Connect Printer Setup) under the Name column.
  6. Click on the Epson Connect Printer Setup-associated entry.
  7. Click the Uninstall button on the top menu ribbon.
  8. Follow the on-screen directions to complete the uninstallation of your enpapp.exe-associated program.
Instructions for Windows XP:
  2. Click Control Panel.
  3. Click Add or Remove Programs.
  4. Locate enpapp.exe-associated program (eg. Epson Connect Printer Setup) under the list of Currently Installed Programs.
  5. Click on the Epson Connect Printer Setup-associated entry.
  6. Click the Remove button on the right side.
  7. Follow the on-screen directions to complete the uninstallation of your enpapp.exe-associated program.
Instructions for Windows 8:
  1. Hover the cursor in the bottom left of the screen to produce the Start Menu image.
  2. Right-Click to bring up the Start Context Menu.
  3. Click Programs and Features.
  4. Locate enpapp.exe-associated program (eg. Epson Connect Printer Setup) under the Name column.
  6. Click the Uninstall/Change on the top menu ribbon.
After you have successfully uninstalled your enpapp.exe-associated program (eg. Epson Connect Printer Setup), reinstall the program according to the SEIKO EPSON Corporation instructions.
May 05, 2015 | Epson Office Equipment & Supplies
Tip
HP printer UNINSTALL using CD
<p><span><b>Resolution:</b></span><br /> <ol> <li> <span>Run the uninstaller from the SETUP.EXE driver</span> <li> <span>Delete printer from Printers folder</span></li></ol> <p><span><b>Removing printer using the SETUP.EXE driver:</b></span><br /> <ol> <li> <span>Run the uninstaller from either the printer CD-ROM, diskettes, or the downloaded Setup.exe printer driver.</span> <li> <span>Go to Start, then Run and in the Open line type X:\Setup.exe, (where X is the CD-ROM drive or the floppy drive or the Directory on the hard drive where the downloaded driver as copied to.</span> <li> <span>Follow the on screen instructions.</span></li></ol> <p><span><b>Deleteing Printer:</b></span><br /> <ol> <li> <span>Run the uninstaller from either the printer CD-ROM, diskettes, or the downloaded Setup.exe printer driver.</span> <li> <span>Go to Start, then Run and in the Open line type X:\Setup.exe, (where X is the CD-ROM drive or the floppy drive or the Directory on the hard drive where the downloaded driver was copied to.</span> <li> <span>Follow the on screen instructions.</span></li></ol> <br />
on Mar 10, 2011 | Office Equipment & Supplies
My 1005mfp HP printer scanner error 20 how I
Hp are tricky scanners to install and setup. You need to unplug the USB cable, power on the scanner and begin a fresh setup.
Let the software tell you when to reconnect the USB cable to the computer. Let it finish setup and reboot computer. Once in windows, the setup will complete automatically.
Go in START menu and click on the HP Solution Center in the HP folder to activate the scanner.You can't jsut press the SCAN button on the scanner. It won't work. You need to start the software first or use Photoshop.
Also, the way to fix this Error 20 is to first ensure that your HP Printer is set up to be the default printer on your PC. It's often the case that the printer you have on your system will either not be the default, or will have some sort of error that will prevent it from being properly used. You should click onto "Printers & Faxes" on your system and then right click onto your HP Printer, and select "Set As Default". This will allow your PC to use the printer every time you print,removing some confusion.
More Help... HP LaserJet Error Codes and HP Printer Support
Thanks,
Sep 19, 2014 | Office Equipment & Supplies
How do I change language settings on my Dell V313 printer
Incorrect language appears on the display
If the "Before you troubleshoot" checklist does not solve the problem, then try one or more of the following:
CHANGE THE LANGUAGE USING THE PRINTER MENUS
1 From the printer control panel, press .
2 Press the arrow buttons to scroll to Defaults, and then press .
3 Press the arrow buttons to scroll to Set Defaults, and then press .
4 Press the arrow buttons to scroll to Use Factory, and then press .
5 Complete the initial printer setup.
CHANGE THE LANGUAGE USING A BUTTON COMBINATION (IF YOU CANNOT READ THE CURRENT LANGUAGE)
1 Turn the printer off.
2 Press and hold down and , and then press to turn the printer on.
The printer resets and starts the initial printer setup.
3 Complete the initial printer setup.
Printhead error
Apr 22, 2013 | Dell V313w AllInOne InkJet Printer
Printing from netbook
Use a desktop computer to copy the contents of the bundled printer CD-ROM to a thumb drive. If a second computer with a CD-ROM drive is not available, go to your printer manufacturer's website and download the appropriate drivers to your netbook's hard drive. Specific instructions may vary depending on your manufacturer, so read and follow instructions provided on the website. Insert the thumb drive into your netbook. If you downloaded the drivers instead, follow the manufacturer's instructions for installation. Open the file browser and click on the USB drive. Click on "Install" or "Setup." Follow the on-screen instructions for driver and software installation. Connect your printer to your netbook using a USB cord. Some software setups will automatically recognize the printer and launch a setup wizard. If a setup wizard does not start automatically, on your task bar choose "Start" and then "Printers and Faxes." In the window that opens, double click on "Add Printer." Click "Next" in the printer wizard window. A new frame appears asking you for the type of printer that you would like to initialize. Choose "Local Printer" and click next if your printer is connect through the USB port. Choose "Network Printer" if you want to use a printer installed on your network. Click "Next." Click the name of the printer you are using in the list. Click "OK" Choose "Yes" when prompted to choose whether or not you want to use the printer as your default printer. Click "Next." Click "Finish." Hope it helps.
http://windows.microsoft.com/en-US/windows-vista/Find-and-install-printer-drivers
Jan 21, 2013 | Computers & Internet
How to set up wireless printer on windows 7 net book
I have just bought an epson sx435 wireless printer. I have set it up on my xp desktop with usb cable. How do I set it up to be wireless on xp
and how to I set it up on my Acer Aspire one 522 netbook running windows 7.
Home > Printer Wi-Fi Setup Setting up a Printer Wi-Fi Network Using the Control Panel Using the Wi-Fi Setup Wizard with LCD panel WPS setup You can set up a Wi-Fi network for your printer by using the printer's control panel. Using the Wi-Fi Setup Wizard with LCD panel If your printer has an LCD panel, you can use the Wi-Fi Setup Wizard to simplify manual setup. mark_no.gifNote: This setting is not available for all printers or may not be enabled. Make sure that the Wi-Fi is enabled on your computer in advance. Check the SSID and password for your network as these are required during Wi-Fi setup. If you do not know the SSID and password, check with your network administrator. For step by step information on setting up a Wi-Fi connection using the Wi-Fi Setup Wizard, click the following link. This feature is not available for all printers or may not be enabled.
exlink.gif../p_body/panel/wizard/manual_01.htm
Well to start with xp look at the following.
http://support.epson-europe.com/onlineguides/en/sx430sx435w_nwg/html/index.htm
May 30, 2012 | Computers & Internet
Could not start setup ir2318 software
Just wild guess: arey ou using a compatible operating system with the driver of your printer?
Apr 24, 2012 | Office Equipment & Supplies
Have new hp computer lexmark4200 wilol not printcan not understand the people on the phone with foriegn accents please help
To use a new printer on your computer, you need to install driver for that printer.
Check out there must be a setup CD/DVD shipped with your printer. If got it do the following steps.
  1. Remove all connection from printer to computer.
  2. Put the CD/DVD in computer.
  3. It will start automatically
  4. Follow the simple on screen instructions
  5. If setup display any message to connect printer, then connect your printer to computer and on it.
  6. After setup finished, you will able to use your printer.
If any problem....just Ask me
Gud luck
Iqbal
Apr 15, 2008 | Office Equipment & Supplies
USB installation problem
This problem comes somtime when you connect the printer prior to dirver installation.
  1. Rmove your printer driver from Start-> Printers and Faxes
  2. Right click on printer icon select Delete
  3. Re-boot system, before re-boot remove all USB connections.
  4. Start Installation from Setup CD
  5. Don't attach printer to system till Installation finished or Setup says to connect the printer.
Thanks
Iqbal
Apr 15, 2008 | Lexmark X2550 All-In-One Printer
Computers & Internet Logo
12 people viewed this question
David Payne
David Payne
