Question about MSI P6NGM-FD Core 2 Quad Socket 775 1333MHz PC2-6400 Motherboard Retail
Cant get any display through xpert vision 8800gt with msi p6ngm
I cant get any video through my monitor connected to xpert vision 8800gt with msi p6ngm and windows(vista) doesnt detect it.
These are the things Ive tried:
updating motherboard bias from msi website
reseating the 8800gt
trying both dvi sockets
installing latest drivers from both nvidia and xpervision website
tried adding it through "add new hardware" in windows.
checking all psu connectors are seated - 4 pin cpu and 6 pin graphics card
  • 1 more comment
  • jr006z1388 Aug 07, 2008
    hi collie
    Yes the fan is spinning fast and the heatsink is clean.
    I should have mentioned this is a new build and the 8800gt card has never been recognised by the system.
  • Anonymous Nov 13, 2008
    no driver sound
  • Anonymous Mar 24, 2014
    instale xp y no tengo conexion internet
Hey,
There are two jumpers called J1 and J2 on the motherboard next to the HDMI connection. They switch between DVI and HDMI. Maybe your jumpers are switched to the undesired position.
Check it out!
Posted on Feb 15, 2009
Just bought an 8800gt myself. Problems are with certain VIA chipsets on mobos and also if your PSU doesnt have enough amps on the 12v rail. i think it needs around 32a
Posted on Oct 27, 2008
  • 781 Answers
Is the fan on your video card working and is the heat sink for it clean this could be an overheating problem
Posted on Aug 07, 2008
New display detected vista
Boot-up in safe mode; add the MSI video drivers and re-boot normally
Mar 07, 2014 | MSI Computers & Internet
No screen display msi megabook s260
If you have a desktop monitor available try hooking your laptop up to that. if you get a display on your desktop monitor then that means your laptop screen needs replacing. If you get no display on your desktop monitor then that means the GPU chip in your laptop has gone bad.
Sep 12, 2012 | MSI MegaBook Computers & Internet
When I Connected the Msi RX1650XT-T2D256E card, display flicker And Linings Appear on my Monitor
That is a sign that your video card is going bad. Contact MSI for a replacement video card, they are usually pretty good about that.
May 10, 2011 | MSI (RX1650XTT2D256E) (256 MB) PCI Express...
Hello I have a P6NGM motherboard which is reboot after a few second during start. I tried to remove RAM,HD and DVD but still the same.I also remove 12 volts and retain the ATX supply and It won't...
Hello from here you can download a manual:
http://www.msi.com/product/mb/P6NGM-FD.html#/?div=Driver&os=XP%2032
Try to reset the bios to factory settings
Also try to remove the cpu fan and add new cooling paste
But it could also be a harddrive failure
Are there any drivers missing (chipset) ??
Good luck
Dec 10, 2010 | MSI P6NGM-FD Core 2 Quad Socket 775...
GeForce 8800gt, will not play videos without pixelizing
Try updating the drivers for the 8800gt, if that doesnt work, try installing a codec pack (just google)
Dec 30, 2008 | Computers & Internet
Palit Geforce 8800gt 1Gig Glitches + BSOD
Nvidia's recommendations for the 8800GT are 26 Amps (I think) on the 12V rail... Although you would think 20 Amps would be enough, my next step would be to uninstall the video card driver again, get yourself a copy of a program called Driver Cleaner dot net, run the program in safe mode to completely remove all of the Nvidia driver, then reboot into Windows, download the latest WHQL driver for your card from nvidia's website, and see if that fixes it. If not, either try the card in a system with a more powerful power supply, or get a more powerful power supply, and see if your error goes away.
Dec 24, 2008 | Palit Microsystems GeForce 8800 GT,, PCI...
Unknown device
Hello the homepage is here:
if it does not help to upgrade the drivers
Disable it in the device manager
It also depends how new your current windows is
This failure comes often when you upgrade your bios
and running a old windows.
Good luck
Sep 06, 2008 | MSI P6NGM-FD Core 2 Quad Socket 775...
MSI P6NGM Issues
I would put the old ram back in, and then reset the bios by following the instructions in the motherboard manual. (usually with putting a jumper on some pins)
Harris
Apr 25, 2008 | MSI P6NGM-FD Core 2 Quad Socket 775...
Mobo and graphics card compatibility
They both should work fine on XP.
Go here for the drivers for your motherboard..
And, here is the most recent driver for the 8800gt straight from Nvidia.
Apr 06, 2008 | Intel Motherboard
MSI P6NGM-FD Core 2 Quad Socket 775 1333MHz PC2-6400 Motherboard Retail Logo
344 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
