Question about Sport & Outdoor - Others
Please describe your failed to find IID IAMStreamConfig interface problem:
Heater wont fire display not reading anything no error codes on IID or lights on back of board
How old is the heater? Is the control fuse good? The issue you are describing is exactly what should happen if you power up the heater and DO NOT select POOL or SPA. If the membrane pad on top of the heater is not working or the user-interface board is bad then the heater will not be able to turn the heater on.
May 30, 2017 | Pool & Spa
Iid iamtvtuner
install soundmax sound driver
Oct 06, 2013 | Computers & Internet
My laptop will not finish loading it gets to this screen & stops - Wireless module not supported! The system detected a wireless module installed. The system is not supported. System halted! Please...
This is a fairly common problem with HP laps. Nobody, even HP, has come up with a definitive reason. Best thing to try:
>Replace the wireless NIC (network interface card) from your laptop. It will be accessed by removing a cover on the rear. This may or may not work.
OR
>Remove the NIC (described above). Get a USB wireless internet adapter. Install the drivers that come with it, then reboot the computer and plug it in to any USB port. Hopefully that should solve your problem.
HERE is a link to an adapter.
I carry one of these whenever I go out on calls in case the owner's computer has a failed NIC and can't access the internet and it never fails for me.
>Remove the wireless NIC
Oct 06, 2013 | HP 2000412NR AMD Dual-Core E300 Processor...
IID REMOVAL AUTOSENSE
Drunk troller....you WILL goto jail if you tamper with it, stop drunk driving and get your life together to have it taken off
Aug 11, 2012 | Computers & Internet
Error 80004002:Cannot find VCapture:IAMStreamConfig
The latest version of PK-635 web cam driver will fix it.
1. A4TECHPKDrivers.rar
2. PK635.zip
May 11, 2010 | A4tech PK-635 Webcam
Error 80004002: cannot find Vcapture: IAMStreamConfig
2. PK635.zip
Apr 29, 2010 | A4tech PK-635 Webcam
Do I need a driver for plantronics USB DSP v4 audio interface
Yes you would need a driver for your Platronics headset if you intend to connect it to your PC
Could you please describe the model of your plantronic headset so that i can get the required drivers for you.
Thanks.
May 21, 2009 | Plantronics DSP-400 Headset
Deference Lacie d2 Quadra1TB/Lacie big disk ?
It's all about the interfaces.
The Quadra has four interfaces: • eSATA • FW 400 • FW 800 • USB 2.0
The triple has all but the eSATA interface listed above.
For doing video work you want a big drive with a fast interface. If you have eSATA available then that's the fastest. If you don't then you're just as well off to go with the triple interface. The FW 800 would be the next fastest, then the USB 2.0, then the FW 400.
Because of the way that data is transferred I believe that when doing video work you would be best served by the FW 400 instead of the USB 2.0 even though the USB is faster I don't believe it is a full duplex communication so the FW 400 is actually better for video.
Apr 03, 2009 | LaCie Big Disk Extreme with Triple...
ASA5510 Active/Standby Not Working
This is a old post, have you received and answer yet?
If not, make sure the internal interfaces are connected to one another and both have links. The ASA needs to have a "heartbeat" signal that passes between the 2 devices and this seems to be what's failing.
Dec 15, 2008 | Cisco ASA 5510 Firewall
Sport & Outdoor - Others Logo
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
