Question about Canon i-SENSYS MF4120 All-In-One Laser Printer
I have taken all the paper but still its showing the paper jam message
Are you running low on toner, I know it sounds like a stupid question but I've had the same problem and I did the checking every possible place paper could get stuck, I used an air duster to clean the rollers (don't touch them - the grease from your fingers probably won't do any harm but I'd rather not take the chance). I had a notification that I was running low on toner so changed it - works perfectly now!
Glenn D
Posted on Aug 24, 2013
    Guru:
  • 352 Answers
Did you check under the toner and drum for paper? Pull the toner and drum out, check for paper stuck in the rollers. Also there id a door on the back of the printer. Check for paper behind it. Then turn the printer off for 5 mins and try again.
I hope this helps Regards GM
Posted on Apr 11, 2011
Paper jam error
could be a stuck, failed, or out of place sensor. recheck all sensors in paper path(s) carefully
Sep 19, 2013 | Kyocera Office Equipment & Supplies
My HP Laserject 5100 Printer has the Paper Jam Problem. After that, I check printer. But i haven't seen any paper jam. When i print out, nothing show on paper and show the paper jam.. How to fix?
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Jul 04, 2011 | HP LaserJet 5100 Printer
I have a new Pixma printer. I got some paper jammed in the printer. After I removed the paper and pressed OK, I still get the error message "Rear cover The paper is jammed. Clear the paper and press...
Make sure all the paper bits are taken off , now to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken .
Sep 29, 2010 | Canon Office Equipment & Supplies
HP Officejet Pro 8500 printer message "Paper jam"
An error code showing that there is paper jam alert, but no paper is in anywhere in the machine except in the tray.....I have checked all areas, taken the back carriage of the unit, opened the top and opened the machine. removed the paper tray, everything, but there is no paper stuck in the unit
Jun 30, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
I CLEARED A PAPER JAM ON T8024 AND RESTARTED THE MACHINE. IT STARTED SHOWING REGISTRATION JAM. HELP ME TO SOLVE THSI PROBLEM
Hi
Check the following possibilities that may causing the error message.
1. Some times more paper may be taken in the paper feed area, check for any other paper jam in other area of the printer.
2. Remove all the printer drives, ports and uninstall the printer software and once again reinstall it by following steps given below
Start - Control Panel - Add and Remove Programs - Remove the program in the list called Tally Laser printer.
By now you have uninstall the software and now reinstall the software with the available cd given at the time of printer purchase and start printing.
Thank you
May 11, 2010 | Tally T8024 Laser Printer
Message shows 'clear paper jam then press check mark....no paper jammed in printer but it will not reset.
message keeps showing print cartridge cradle cannot move, I have check everything, no paper jams nothing under printer, I am turned off printed but keep getting same message.
Sep 17, 2009 | Lexmark X4530 InkJet Printer
Fax will shows a Paper jam but no paper found in machine.
Are the all sensor flappers whole?Or it may be an PCB problem
Jan 26, 2009 | Canon LaserClass 9000L Plain Paper Fax
Canon MX300 Paper Jam
I have the same problem - every time I turn on my printer now, the alarm signal shows up with "Paper jam" but when I check for jammed paper, there is none. So I think there's something faulty with the printer. Is there any way to reset it? I've looked everywhere but can't find it.
Jan 16, 2009 | Canon MX300 Office All-In-One Printer
Can't print faxes due to error messages
Please check rear door area for paper, can you use manual feed slot? Power off machine with all jams removed and paper loaded, then power on, can you tell us exact error message/lights that are shown in this state?
Oct 15, 2007 | Brother IntelliFax-2820 Laser Fax
Canon i-SENSYS MF4120 All-In-One Laser Printer Logo
136 people viewed this question
old marine
old marine
