Question about Xerox Phaser 3100MFP/S Laser Printer
Put custom manual tray problems - Xerox Phaser 3100MFP/S Laser Printer
Hync error
Posted on Apr 20, 2011
No removeable crumb tray located as shown & listed in manual
The tray may have been forgotten during assembly. Toaster oven crumb trays often simply slide in and out; there are no tracks. Put CEM on autodial and keep trying until a human being answers. Consider getting a crumb tray from some other brand and using it
May 31, 2013 | CEM Global Toaster Ovens
What does it mean: "put custom in manual tray"?
"generally" printers have a main tray and a manual feed tray, which is typically a fold down tray in the front of the printer. This manual tray allows the feed of envelopes, thicker paper, transparancies etc. including " custom sized paper" The printer is saying that your software identified that it "needs" custom paper instead of your
normal paper. Hope this helps.
Mar 11, 2013 | Office Equipment & Supplies
HP Lazer 4300dtn keeps trying to print from tray 1. How can I set the default to tray 2?
Selecting which tray is used for printing
You can select how the printer pulls paper from the trays.
Understanding tray order
When the printer receives a print job, it selects the tray by trying to match the requested paper
type and size with what has been loaded in the trays. Using an "autoselect" process, it searches
all available trays for the paper that satisfies the request, starting with the bottom tray and ending
with the top tray (tray 1). The printer begins printing the job as soon as it finds the proper type/
size.
Note The "autoselect" process occurs only if no specific tray is requested for the job. If a specific tray
is requested, the job prints from the requested tray.
 If paper is loaded in tray 1 and tray 1 is set TRAY 1 TYPE=ANY and TRAY 1 SIZE=ANY on the
Paper Handling menu, the printer will always pull paper from tray 1 first. See "Customizing
tray 1 operation" on page 47 for more information.
 If the search fails, a message appears on the printer control panel display requesting that
you load the correct paper type/size. You can load that paper type/size, or you can override
the request by selecting a different type/size at the printer control panel.
 If a tray runs out of paper during a print job, the printer automatically switches to any tray that
contains the same paper type/size.
The autoselect process changes somewhat if you customize tray 1 operation (as explained in
"Customizing tray 1 operation" on page 47) or set tray 1 for manual feed (as explained in
"Manually feeding paper from tray 1" on page 49). See if this works. Good luck !
Jan 08, 2011 | Computers & Internet
HP Laserjet 4700 Always Defaults to Tray 1
Your tray 1 might be open (even just partially) or your manual feed setting might be on. You can find this setting under > Configure device / Printing / Manual Feed
Jun 25, 2009 | HP LaserJet 4700 Printer
Envelope printing
The manual bypass tray on the Phaser 8400 can be set only when you have paper in the tray.
The envelope will read in the set up when you have it in the tray.
Nov 12, 2008 | Xerox Phaser 8400 Laser Printer
P801front load washer
put on prewash cycle. note which tray water enters and that is the prewash tray.
put on wash cycle which has no prewash. note which tray water enters and that is main wash tray. remaining tray is rinse
Sep 06, 2008 | Samsung WF337AA Front Load Washer
Paper source
I would suggest checking printer properties in the computer and ensure the paper size and source is Letter and set to Automatic Choose. Another choice may be to deleted the printer driver and re-install it. You can also go into the menu options until you get to Set factory defaults, press Select, then try the print job again.
I really suspect a program is controlling this from the computer.
To get a list of the existing printer settings, Select Menu and use the Right Arrow button until you get to Printer Menu Settings. The printed report should tell you what your actuall settings are. Maybe the default is set to Custom, instead of Letter.
The Set Factory Defaults option should fix most problems.
Good Luck John Moser
Jul 01, 2008 | Lexmark Optra S 1625 Laser Printer
The paper tray has paper in it, yet I cannot get the printer to print, and the display box reads 'papaer empty custom in MP' Please help what does this mean? Why can't I print? Many thanks
WHAT MAKE AND MODEL? (HP?0
BUT WHAT THE PRELIMANARYLOOKS LIKE.
1 OF THE PROBLEMS IS THE PRINTER IS THE TRAY IS SET TO CUSTOM.
PULL TRAY OUT LOOK AT HOW THE TRAY IS SET ....
IT SHOULD BE IN STANDARD NOT CUSTOM.
AND ANOTHER PROBLEM ALSO IS THE TRAY'S ADJUSTMENT IS OPEN TOO FAR.(CLOSE IT UP TILL PAER IS HELD IN ON ALL FOUR SIDES.
Jun 09, 2008 | Samsung Office Equipment & Supplies
Xerox Phaser 3100MFP/S Laser Printer Logo
512 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
