Question about Intel D845EPI (INTELKD845EPILPAK10) Motherboard
Ram support for intel 845 motherboard - Intel D845EPI (INTELKD845EPILPAK10) Motherboard
    Master:
  • 149 Answers
  • 184-pin DIMM Banking: 2 (2 banks of 1)
  • Chipset: Intel 845E
  • Error Detection Support: Non-ECC only
  • Graphics Support: AGP 4X
  • Max Component Density: 512Mb
  • Max Unbuffered DDR SDRAM: 2048MB
  • Module Types Supported: Unbuffered only
  • Supported DRAM Types: DDR SDRAM only
  • USB Support: 2.x Compliant
  • Each memory slot can hold DDR PC2700, DDR PC3200 with a maximum of 1GB per slot.*
    *Not to exceed manufacturer supported memory.
    Posted on Apr 11, 2011
      Scholar:
    • 72 Answers
    Hello. this website will show you the supported RAM for your Motherboard.
    RAM Support
    Hope this helps!
    4 Suggested Answers
    Benimur
    • 6966 Answers
    SOURCE: intel ASUS P4 845 GL Motherboard
    Hi, For an ASUS P4BGL-VM Intel 845GL Chipset Ultra ATA100 MATX CPU Type: Intel Pentium 4 478-Pin (OEM), the Asus site specifies max of 2 x 184-pin DIMM Sockets support max. 2GB PC2100 / PC1600 non-ECC DDR or SDRAM memory but not "and". Personally, I find it more practical to install 2 X 1Gb rather than a single 2Gb. Hope this gives you some idea. Kind regards.
    Posted on Aug 07, 2007
    cyrylthewolf
    • 143 Answers
    SOURCE: ram support for intel 845 motherboard
    Ok. So you've defined the Intel 845 chipset on your motherboard.
    But is it the 845 or 845G chipset?
    Click HERE for the specifications of the Intel 845 chipset.
    Click HERE for the specifications of the Intel 845G chipset.
    Peepnklown is only HALF right.
    The Intel 845 chipset does NOT support PC133 memory.
    The Intel 845G chipset DOES support both DDR and PC133 memory.
    The difference?
    The 845 has a single memory controller for DDR memory.
    The 845G has two memory controllers. One for DDR and one for PC133.
    Although you're going to need DDR memory as it is FASTER and less expensive than the older PC133 memory. (Believe it or not.)
    I do NOT recommend using Corsair's ValuSelect memory on this chipset. I have two boards with the 845G chipset and that type of memory does not allow the board to boot.
    These boards typically come with DDR266 (PC2100) modules installed.
    I would go ahead and buy DDR333 (PC2700) memory for it. The board you have may not utilize the full speed of that memory, but will use tighter memory timings if the RAM is clocked down by the board. This will result in better efficiency of memory use by the processor.
    Think of it as giving the motherboard "breathing room".
    I could recommend PNY memory for the most basic compatability. (Not that they manufacture their own RAM modules...) Or perhaps Nanya, Infineon or Microtek.
    Look for memory compatability lists for your particular motherboard module online. You could also use PNY's memory configurator on their website.
    Click HERE for PNY's memory configurator.
    Good luck.
    Cyryl
    Posted on Nov 18, 2007
    • 135 Answers
    SOURCE: No Dispay, No Beep
    Try leaving it off but with power to it (should see a small green LED on Mobo) for about 30 minutes or more.
    After this time try starting it with RAM installed of course!
    If this doesn't work your Motherboard is dead.
    Posted on Feb 17, 2009
    Can I replace 256 MB SD RAM with 512 MB DDR1 ram in intel 845 glly mother board?
    I have installed RAM of 256MB each (2slots total 512MB ) and system BOOTS UP, but it keeps restarted on every 5 minutes.
    Please advice
    It is 845 GLLY Original and 1.7ghz.
    Dec 27, 2009 | Intel D845GLLY Motherboard
    Finding Intel 845GVSR & 915GLVG Compatible Motherboard & Proc
    you can use intel dg41 mbd , dualcore processor,1 gb ram,160 gb hdd or use intel atom for support contact 91-9645071021
    Aug 11, 2009 | Intel D845GVSR Motherboard
    How much ram can be supported for 845 p4 motherborad
    My Intel 845 WD motherboard after upgrading the BIOS was able to support 4 Gigs of RAM.
    Jul 08, 2009 | IBM (02R4087) Motherboard
    Which ram sported by 845 intel motherboard
    Check page 7 at this link for memory module requirements for 850MD and 850MV. http://download.intel.com/support/motherboards/desktop/d850mv/qrg.pdf
    Jul 07, 2009 | Intel Motherboard
    Intel 845 mother support
    research the ram to see if it will work on that motherboard. some ram requirements are present when you get memory for a pc. not all ram are compatible with certain motherboards.
    Oct 02, 2008 | Intel Motherboard
    Ram support
    Any 845 intel board should support 512 ram.may be the one u have brought is defective.plz be specific and more detailed quires when u post next time.
    May 10, 2008 | Intel Motherboard
    The difference?
    Good luck.
    Cyryl
    Nov 10, 2007 | Intel Motherboard
    Intel ASUS P4 845 GL Motherboard
    Aug 07, 2007 | Intel ASUS P4BGL-VM 845GL Chipset Ultra...
    Intel D845EPI (INTELKD845EPILPAK10) Motherboard Logo
    108 people viewed this question
    Top Intel Computers & Internet Experts
    Tony
    David
    David
    vsri9
    Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
