Question about Car Audio & Video
How to put in radio code for 325e - Car Audio & Video
    Problem Solver:
  • 13 Answers
Bmw instructions
you will need the use of a lift to be able to lift car off the subframe once you have dismantled the wheels, suspension etc , get a work shop manual, that will give you a step by step guide on how to do this , it is pretty complex so i'd really recommend getting the workshop manual
Jun 03, 2014 | 1982 BMW 325e
Cant find the location of obd code reader connector on 1985 bmw 325e
Are you trying to connect a code reader or your phone to your car? You probably mean OBD-II, which didn't come along until several years after 1985.
Apr 30, 2014 | Cars & Trucks
Gears slipping
Smell the transmission fluid, if it smells burnt then you have clutches in the transmission slipping. Also check and see if there are any code for the powertrain.
Dec 10, 2013 | Goodyear 1987 BMW 325e Accessory Drive...
I have 1985 bmw 325e that will not start. i have replaced the computre and coil. cannot get any fire. the radio is missing and when i try to start it a light flashes on and off THEFT
do you have reverse lights when backing up?? open the ignition apply E-brake and put gear selector in reverse,,if no lights come on than your reverse light switch is faulty and will prevent engine from turning over....let me know and good luck
May 14, 2010 | BMW 325 Cars & Trucks
Replace struts on a 1987 bmw 325e
YOU NEED TO REMOVE THE STRUT COMPLETELY USING COIL CLAMPS CLAMP THE SPRING AND REMOVE TOP PLATE UNDOO THE LARGE NUT ON THE STRUT ITSELF THEN PULL OUT THE INTERNAL SHOCK REPEAT THE PROCESS IN REVERSE FOR ASSEMBLEY
Sep 01, 2009 | BMW 325 Cars & Trucks
Reset ''Service Oil'' sensor on a 1985 BMW 325E off dash console
Call your local BMW dealer and ask them...should be free!
Good Luck
Jun 14, 2009 | 1985 BMW 3 Series
HOW COULD I READ CHECK ENGINE CODE ON A 1986 BMW 325E???
You can't use a tool to pull codes from an '87 BMW 325(e). You have the 2.7 liter and your DME, or computer is a Motronic. If you had a 325i, then a tool could read the codes because the computer was upgraded that year to a Motronic 1.1 system with a round plug in under the screw cap on the driver's side under the hood. The only tool you can buy is the one for resetting the service interval light and resetting the oil change light. To answer your question about going about finding your driveability problem would be to get a BMW Bentley Manual. This manual shows you how to use a standard voltmeter to check everything from your computer plug in. Your computer is located above the glovebox.
Good Luck,
~Stillin~
Jun 05, 2009 | 1986 BMW 3 Series
My 325E BMW is not starting
check to see if the raised pin on the fly wheel has has broke off. to do that you, take out the position sensor on the bell housing & look on the flywheel to see if it is there. your have to manually turn the engine whale somebody else looks to see if the pin is still there. if it is not. where it is suppose to be, just put a sheet metal screw in its place. by taking a long drill bit and drilling it out to put the screw. try and see if that's the problem
Aug 25, 2008 | 1985 BMW 3 Series
Car Audio & Video Logo
48 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
