Question about Health & Beauty
Do you have service manual regarding Midmark 7300 surgical table electric power/battery.this unit is 110volts but ,they in into 220v,the charger circuit is burn ,can you provide us a service manual en circuit for charger.?
  • 7 Answers
SOURCE: Powermust 600 Plus doesn't provide power
maybe fuse is blown
Posted on Dec 18, 2008
dmftrucker
  • 1922 Answers
SOURCE: 2 12/2AWG = 1 10/3AWG
yes, with a double run of 12-2w/ground you'll end up with 2pairs of 12 for your 2 hot phases(you will need to mark one pair red to substantiate the 2 different phases) and each 12 gauge wire will carry 20 amp each alone, then you'll have 2 pairs of 12 with white insulation white for neutral is fine but the other pair for the safety ground will need to be marked or painted green where ever visible per N.E.C. i.e. main panel or dryer receptacle or hardwired into the unit itself,use 10-3w/ground its cheaper in the long run and you dont have to run a doubleheader
Posted on Sep 27, 2009
Testimonial: "dmftrucker was patient with me... it took a bit for all to sink in but I got good technical, code based advise from him. Thanks a Lot! kk"
dmftrucker
  • 1922 Answers
SOURCE: model 3755 5.5 qt. Crock Pot base unit burned out
for what they get at a repair versus a replacement you better start looking, it will cost you more just to get an estimate than a new unit will cost
Posted on Oct 26, 2009
Testimonial: "Thanks. Your suggestion is probably the most realistic approach, but reviews of the new models with plastic handles scare me away from Rival."
  • 37 Answers
SOURCE: How can the battery charger be changed?
Yes this is a very simple job to do. there are only 2 small bolts holding it in. Make sure the generator is in the off position and removed the 2- 5amp fuses in the transfer switch for N1 and N2 Use a fuse puller designed for this (you can get at home depot or lowes for around $9-$10) not a pair of pliers or screwdriver, etc... there is 240VAC on these fuses.. N1 and N2 are what ultimately feed the transformer in the generator which steps the voltage down to 24-26 VAC and feeds the battery charger. Other than that its fairly simple, let me know if you have any more questions.
Posted on Dec 03, 2009
SOURCE: Samsung WA71N2, plugged to 220V should be 110V only
chang the board! servise center will charge probably 400sr
Posted on Feb 03, 2010
How can I tell if my Dyson DC 35 cordless uses 220 volt as power supply to change battery. The one I purchased is advertised to do so. This is because I purchased it to use in the Philippines
Your devide should have the indications on electric input on a small plaque. Actually, it it's cordless, it works with a rechargable battery so most probably you should look at the charger unit. Probably it's 110/220V and has a swith somewhere,
Don't you have a user's manual?
Read here, might give you some clue:
http://www.dyson.co.uk/medialibrary/Files/Dyson/Support/downloads/UK/floorcare/Manuals/DC35_Manual.pdf
Aug 02, 2015 | Dyson Vacuums
Do i need 220v connection to use furnace
Is this a furnace or AC unit? How about adding yhe make and model? I have a 1 ton mini-split on 110volts but anythin larger is 220v.
Aug 28, 2014 | Heating & Cooling
When I turn my wheelchair on a service indicator light at bottom of joystick blinks 9 times. How do I fix this?
If: Battery indicator flashes the charge level is low
immediately after recharging.
Then it is a. Weak Batteries.
b. Charger malfunction.
c. Electrical malfunction
Solution a.Replace batteries.
b. Replace charger. Contact Dealer/Invacare.
c. Contact Dealer/Invacare.
I got the above from the manual. The link is:
http://www.invacare.com/doc_files/1125085.pdf
Regards
Chellakumar
Jun 13, 2014 | Invacare Pronto M51 Power Wheelchair
Capacator in lower left corner is blown apart from an 220v generator connection.... where can i get a replacement capacator or board ?
The capacitors are industry standard items that can be cross referenced from the component markings, values, or part numbers referenced on the components through several national component suppliers such as Digikey, Mouser Electronics, or Newark Electronics. If a single bulk capacitor has blown, both should be replaced as the other will have been stressed and should not be trusted to be functionally sound.
Apr 11, 2014 | Parallax Power Supply Parallax 7300 Series...
Charger faulty, no charging.
hi, Sounds like a dodgy charger , check for a fuse on the side that the leads go to the scooter... I offer a free testing service, you only pay the return postage...UK only... One thing check the fuse in the battery pack, the charger will not work if it does not see the battery voltage
Regards
Rob
www.gewizrepairs.co.uk
Feb 04, 2014 | Pride Travel Pro 3-Wheel Mobility Scooter
Plugged 110v dishwasher into 220v
When you have a 220v outlet there are two wires that both supply 110volts, thus the 220volt rating. 110volts uses 1 wire that supply's 110 volts and the other wire is a "neutral" what is a non current carrying conductor. In other words there is no 110 volts on the second wire. Most of the time if you supply a 110 volt appliance with 220 volts you most definately fry something if not everything. Probably the main thing that blew was the control panel be it a computer board, dial switch etc. Sorry for the bad news but it might be cheaper to replace the unit than having it looked at and repaired
Feb 05, 2012 | Whirlpool Dishwashers
I accidentally plugged in epson nx110 to 110v when i shoudl have plugged it in 220v , burnt smell and no power at all
Not sure why it burnt going from 240 down to 110volts. The unit should not have worked. However, if it is a 110 volt machine and you plugged it into 240 volts... different story... At best you have blown the power supply board or board fuse.. At worst, the machine will be fried inside.
Aug 09, 2011 | Epson Perfection V500 Flatbed Scanner
I have a 310v 3 phase coffe machine how can i use
Hello tonyludlow1,
I can speak from personal experience with 3 phase. I built a 220v 3phase converter to run my 3 phase commercial table saw. I do not believe you will have success running a 310v 3 phase coffee unit. It is likely that the heating elements are set for 310v, and if you run it on 220v domestic wiring your heating elements would not heat optimally. If it could be done, you would need to rewire the electrics in the coffee unit to 220v. Sorry to be a downer. Positive feedback appreciated. Kind regards, NormanZ :o)
Jul 08, 2009 | Coffee Makers & Espresso Machines
Battery Charging Problem
The problem is not with the batteris, but with your charger, you have to make sure it can take 220V or you will burn it. Look for a switch on it to change from 110V to 220V.
Aug 28, 2008 | Energizer Rechargable Battery with Charger
BattEry..
You can search any online auction site, electronics retailer, or wherever you like with this search term "110 220 adapter", and you should find plenty of inexpensive (less than $10.00 US shipped) travel converter/adapters that will fix you right up by converting a 220V outlet to 110Volts for your new laptop.
Good luck.
Mar 21, 2008 | HP Pavilion dv6755us PC Notebook
Health & Beauty Logo
154 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
