Question about DeLonghi Kitchen Appliances - Others
F26 Accidently switched on without oil and safety cut out happened. Now won't switch on. How can I re set please
  • Tony Organ Aug 28, 2013
    Kelly is right. the unit has a thermal fuse that goes open circuit and will need to be replaced by a serviceman
  • DeLonghi Master
  • 3,740 Answers
Hi and weclome to FixYa, I am Kelly.
The unit has a non resettable thermal safety device and the manual states this:
WARNING: The level must always be between the
maximum and minimum levels indicated.
Never use the deep fryer when the oil is below the
"min" level as it could cause the thermal safety device
to come into operation; to replace it you need to
contact one of our service centres
I know this is probably not the answer you wanted to hear but your faced with contacting a Delonghi Service Center for replacement of the thermal safety device.
Service Ceter locators
USA
http://www.delonghiusa.com/index.php?service
AU
http://www.delonghi.com.au/maps/service_rep_locator_au.asp
UK
Customer Service line 0845 600 6845
Thanks for choosing FixYa,
Kelly
Posted on Apr 11, 2011
How do I get washing machine door to unlock?
The error F26 does indicate a fault in the door switch circuit. See the image below for a complete listing of what can cause this error. There is a door unlock error that would display if the door is not locking or unlocking but the F26 means the control is not seeing the door switch open and close. One thing to try first before scheduling service or replacing the part is to check the connections on the door switch.
Unplug the washer first and remove the lower access panel and reach up to the door lock and try to feel for the connections and make sure they're tight.
Jun 16, 2014 | Whirlpool duet Washing Machines
Craftsman 42in 16hp engine will not stay cranked. Changed sparkplug, airfliter, changed oil, check all 3 neutral switches all fine. Will crack for about 15 minutes and cut off. Could it be overheating...
make sure the oil is up on the safe mark on the oil stick, you should use 30 or 40 weight motor oil , but if it has oil safety switch ,it could have gone bad,and it will shut d0wn the motor, just try unplugging the safety switch and see if it stays running ,if it does replace the safety switch.
Aug 05, 2012 | Craftsman Garden
I have a yamaha vstar 650it starts fine but when I put it in gear and drive off it stalls....not sure why??
I would check to see in your owners manual if it has an electronic oil sending unit and check if it reads bad does it shut off your bike.then check your oil level. Then go from there see if low oil can stop your bike from running. in some cases it does it a safety measure. But i would do what is called a wiggle test with the bike running wiggle one section of wires at a time to see if this kills the engine. Once found inspect this area good for loose ground or wire or broken clip or frayed wiring Check all get back to me.Remember to rate my solution it is why i am here. Thanks in advance.
Apr 13, 2012 | 2002 Yamaha V Star Classic
1993 chevy caprice classic wagon 5.0 8 cylinder hads a problem with engine shutting off with in seconds after start ! i did check for vapor lock in gas line, had new spark plugs replace, new fule...
Think the oil pressure switch keeps the fuel pump running once started. Suggest replacing Oil pressure switch. And no it won't effect oil pressure reading when it goes bad. The switch is a safety device. When you roll it over and the oil pressure drops the switch cuts off the fuel pump. Neat huh? Need some good feedback Thanks!
Jul 21, 2011 | 1993 Chevrolet Caprice
My Husqvarna riding mower won't start. I was
Check to see if you left the blades engaged. There is a safety switch that prevents starting with blades engaged. Easy to miss, happened to a friend of mine last month.
If this really helpful, please rate.
Jul 11, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
F26 (on an HE5t)
This is most likely a problem with the door switch or a loose connection at the switch.
Jan 16, 2011 | Washing Machines
What does F26 mean
Hi, Well The error F26 does indicate a fault in the door switch circuit. There is a door unlock error that would display if the door is not locking or unlocking but the F26 means the control is not seeing the door switch open and close.This is most likely a problem with the door switch or a loose connection at the switch.
You can unplug the washer first and remove the lower access panel and reach up to the door lock and try to feel for the connections and make sure they're tight.
Thanks! mannu_rakesh
Sep 11, 2009 | Washing Machines
Cut off switch problem
The pressure switch will trip off when the compressor reaches the rated setting (usually 120 ~150psi). If the compressor keeps running untill the safety pops releasing air (usually about 160psi) then the switch is most likely problem. I use SquareD switch from WWW.Grainger.com. However if the compressor keeps running but never pops the safety and only reaching around 90 to 100psi, then you could have several other issues including: leaking fittings (check with soapy water), worn cylinder and piston (on oilfree compressor examine cylinder from below and look for scratches), leaking valves on oil type compressor. Please email with your finding and any questions Good Luck
Jan 28, 2009 | Porter Cable Cable 4.5 Gallons 150PSI Job...
My dt125 starts but when i put it in gear it cuts out
SOUNDS LIKE IT COULD BE THE SAFETY SWITCH FOR THE KICK STAND ,IF THE SWITCH HAS BEEN DAMAGED IT WILL START UP FINE AND WHEN PUT IN TO GEAR AND CLUTCH IS RELEASED IT WILL DIE.(This is a safety feature)
If that don't fix,Please post back
Please rate this fixya solution
Jan 23, 2009 | 2000 Yamaha DT 125 R
Kitchen Appliances - Others Logo
884 people viewed this question
Top DeLonghi Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Shehu Pro
Shehu Pro
Are you a DeLonghi Kitchen Appliances - Other Expert? Answer questions, earn points and help others
