PC with ECS P4VMM2 V5.0A motherboard won't power up after working for years. Power supply fan doesn't come on, case fan doesn't come on, PC dead. Tried replacing power supply, same result. Power supply comes on when I pull the 24-pin connector and short the power switch leads (pin 14 with pin 15). Voltages look good with multimeter. Tried replacing CMOS battery, PC still dead. What next? Could there be something in the CMOS that is preventing the power supply from powering up?
  • 1 more comment
  • chuckfay101 Apr 11, 2011
    Should I try clearing the CMOS to see if that helps? What is the downside of clearing the CMOS? How do I reset it to the correct settings?
    Thanks, Curtiende. I expect the case fan will start working again once the power startup problem is resolved. The motherboard is a micro ATX form factor board, so the main power supply connector on the motherboard is actually a 20-pin connector, not 24-pin as I initially wrote. Like you, I'm afraid the motherboard has failed, but I was hoping that resetting the CMOS memory might help resolve the motherboard problem. Is there any hope that would help?
    Thanks again, Curtiende. I agree with your suggestion of using the BIOS settings menu instead of removing the battery for the CMOS, but the PC won't even power on, so I can't get to the BIOS setup software. I can't get to any software, not even the power on self test. So I have removed the battery and replaced it, but I didn't use the jumper setting to reset the CMOS yet. Still wondering if there could be some setting in the CMOS that would cause the power supply to sense through its motherboard connector that it should not power up.
    Master:
  • 341 Answers
The mother board and the fan also need replacement. If you have recently added any other hard ware to the machine, remove it and try booting again.
Posted on Apr 11, 2011
  • Curtis Otiende
    Curtis Otiende Apr 11, 2011
    Removing the battery for the CMOS ( complimentary metal oxide semiconductor ) will only reset the BIOS (Basic input/output system) to default settings. Instead of resetting the bios by removing the battery, there is also an option within the BIOS settings menu to "Load Defaults" if that is all you are looking to do. I recommend this to avoid the problems that may also be caused by resetting the BIOS and adding more problems that you may not realize because the system is not already working.
  • Curtis Otiende
    Because there is no power at all. This is clear evidence that the Power supply is not ok. please use a different working power supply that is compatible with your machine and you will know the next problem if there is any.
What drivers can use for my video and sound card? ESC P4VMM2
driver for motherboard ECS P4VMM2
On this page you are offered with driver for p4vmm2 motherboard existing in our database. Icons placed on the left of file name will prompt you in which format and in what language driver download ECS P4VMM2 motherboard are represented in this file.
If the needed file doesn't exist, therefore the desired driver is missed in our database. It can be ordered in the File Request section.
You can also try to find the appropriate driver for kindred motherboard ECS models by clicking on the links shown below.
  • http://www.fixdevice.com/drivers/motherboard/ecs/p4vmm2.html
  • http://www.driverstock.com/elitegroup-p4vmm2-driver-download/25-9-3830/index.html
Sep 20, 2011 | Computers & Internet
My pc doesn't power on..power supply was verified good. what to do?
Unplug everything except the motherboard,power supply, Ram and video card if it is not on board and try it. Sometime a HARD DRIVE or CD-ROM can lock up a motherboard if it works then plug in one piece at a time till you find the problem.Bad Ram can do it to and a loose video card.
Bios downloads http://www.ecs.com.tw/ECSWebSite/ECSSearch.aspx?menuid=0&lanid=9&keyword=P4M266A
Feb 15, 2011 | EliteGroup Via P4M266A (P4VMM2 V7.3)...
My pc with EliteGroup P4VMM2 Motherboard didnot turn on but the fan and of cpu are working but wont open! what shoul i do? pls email me @ nhatz_cruel@yahoo.com
verify that the monitor is working if you can. Is the hard drive lite lighting up, If not try removing and reseating the ram. if the hd lite in on then it would sound like the graphics card is out, try replacing it.
Oct 21, 2010 | EliteGroup P4VMM2 Motherboard
I HAVE A PROBLEM,PLZ HELP. MY PC HAS NO POWER EVEN I REPLACES A NEW POWER SUPPLY.MY MODEL IS ECS P4VMM2 REV.8.1
A 4 pin square connector on ATX boards must be connected to power up, also if you have a bad device such as hard, floppy, or CDROM drive, it could keep the power supply from coming on.
Jan 20, 2010 | Computers & Internet
When i replace and upgrade my ecs p4vmm2 ram up to 1gb..first it enter os but when i restarting im stuck with checking nvram"..im done with re installing the usb wire,reseting cmos..unplugging...
Sounds as though your new RAM may not be compatible with the ECS.This is most certainly the case if the system boots correctly with the old RAM back in place.You may need to check the specs for this mobo on the EliteGroup website to find out what RAM is compatible.
Nov 07, 2009 | EliteGroup P4VMM2 Motherboard
ECS P4VMM2 driver
I lost my ECS P4VMM2 motherboard driver, and i need the driver to work my pc completely...
Aug 11, 2008 | ECS RS400-A (V1.0) Motherboard
Heat sink fan P4VMM2 v 3.2A
Which one of these CPU's are you using?
Jun 17, 2008 | Pioneer ECS P4VMM2 V3.2A P4(478)/FSB...
Second opinion for ecs p4vmm2 8.1
It's ok to upgrade the processor to P4 the mother board is capable to run the pentium 4 2.0Ghz only . I said that because i'm using that type of motherboard ecs p4vmm2 with processor 2.0Ghz. But for my opinion the problem of your friend computer is not the processor is about the cooling fan heatsink because if the heatsink is not fit or properly lock the processor is over heating that's why the computer hanging and shutdown. If you can tight the two clip that was broken the problem is solved because i have also the same problem before one of my client computer. but if you friend want to upgrade to p4 it's better to buy also a new fan and heatsink for P4.
Thanks and God Bless
Jemuel
May 08, 2008 | EliteGroup P4VMM2 Motherboard
P4vmm2 motherboard wont start
cheak and change ur power supply
Jan 05, 2008 | EliteGroup P4VMM2 Motherboard
Dead ECS G733 laptop
Yes, try replacing the power button assembly first and the heatsink assembly and fan before shelling out big bucks on a Mobo (which is probably pulled from another LT).
Nov 21, 2007 | EliteGroup ECS G733 Notebook
Computers & Internet Logo
102 people viewed this question
David Payne
David Payne
