Question about Cell Phones
The device was working for 1 year without problems. suddenly the phone is ringing but i cant receive any call. i can see the incoming number on the screen of my panasonic. i can only answer from another phone device of my office. It seems like internal call is blocked always on.
  • Cell Phones Master
  • 17,130 Answers
This means that you can hear the ringing of the call but is not able to activate the call, so it means that the green button is not active as the call is taken.
This can happen if there is fault in the pads. You can disconnect the battery and open the phone, remove the pads and look for moisture, dirt or faulty pad contacts- the carbon film failure.
if so you need to get a repair kit to form the tracks . other wise warm the pads and reset.
Posted on Apr 11, 2011
No dial tone cant make calls
No dial tone and inability to receive ring signals are symptoms of connection problems. The installation instructions should indicate how your telephone system should be connected to the network.
Dec 30, 2013 | Lands Phones
Receiving faxes whilst connected to a phone line automaticly
Check video for 'fax receive set up' in similar model:
Manual receive: In coming call receives like telephone
Fax/tele: Incoming call rings like telephone if its not fax, if incoming is fax it will entered in fax mode automatically
Automatic: Incoming call converts in fax mode after ring count ends( ring to answer option also avail in fax set up mode rage 1-6 rings)
Fax: Incoming calls straight away converts in to fax mode.( this option only for dedicated fax lines)
Set up your best option as per your requirement.
Nov 29, 2012 | HP LaserJet 3050 All-In-One Printer
Unit around 3 years old. Suddenly will not receive or send calls, although phone rings when there is an incoming call so it has power.. Have checked and the phone line is connected. Our landline phone unit...
yea these phones are ****. choose a different brand if you can afford to. we have to buy new ones yearly. the batteries are as high as the phone.
Mar 03, 2011 | Uniden Cordless Phone
Hp officejet 6500 instructions for receiving a fax? Thanks
You can receive faxes automatically or manually. If you turn off the Auto Answer option, you must receive faxes manually. If you turn on the Auto Answer option (the default setting), the device automatically answers incoming calls and receives faxes after the number of rings that are specified by the Rings to Answer setting. (The default Rings to Answer setting is five rings.)
If you receive a legal-size fax and the device is not currently set to use legal-size paper, the device reduces the fax so that it fits on the paper that is loaded. If you have disabled the Automatic Reduction feature, the device prints the fax on two pages.
NOTE: If you are copying a document when a fax arrives, the fax is stored in the
device memory until the copying finishes. This can reduce the number of fax pages stored in memory.
This section contains the following topics:
• Receive a fax manually
• Set up backup fax reception
• Reprint received faxes from memory
• Poll to receive a fax
• Forward faxes to another number
• Set the paper size for received faxes
• Set automatic reduction for incoming faxes
• Block junk fax numbers
• Receive faxes to your computer (Fax to PC and Fax to Mac)
When you are on the phone, the person you are speaking with can send you a fax while you are still connected. This is referred to as manual faxing. Use the instructions in this section to receive a manual fax.
NOTE: You can pick up the handset to talk or listen for fax tones.
You can receive faxes manually from a phone that is:
• Directly connected to the device (on the 2-EXT port)
• On the same phone line, but not directly connected to the device
NOTE: The automatic document feeder must be empty to receive a fax. If there are documents in the ADF, then the device will not be able to receive incoming faxes.
To receive a fax manually
1. Make sure the device is turned on and you have paper loaded in the input tray.
2. Remove any originals from the document feeder tray.
are documents in the document feeder, then receiving the fax will be
unsuccessful.
3. Do one of the following to answer a fax manually:
• Set the Rings to Answer setting to a high number to allow you to answer the
incoming call before the device answers.
• Turn off the Auto Answer setting so that the device does not automatically
answer incoming calls.
4. If you are currently on the phone with the sender, instruct the sender to press Start on their fax machine.
5. When you hear fax tones from a sending fax machine, do the following:
a. Press START FAX Black or START FAX Color on the device control panel.
b. When prompted, select Fax Receive.
NOTE: Depending on your country/region, the device might receive the fax
automatically when you hear fax tones from the sending fax machine.
6. After the device begins to receive the fax, you can hang up the phone or remain on the line. The phone line is silent during fax transmission.
Jan 30, 2011 | HP 1250 Plain Paper Thermal Inkjet Fax
HP L7650 will not auto answer incoming faxes
To set the answer mode to manual or automatic via the control panel
? Press Auto Answer to turn the light on or off, as appropriate for your setup.
When the Auto Answer light is on, the device answers calls automatically. When
the light is off, the it does not answer calls.
To set the answer mode to manual or automatic via the embedded Web server
1. Open the embedded Web server, click the Settings tab, click Fax in the left pane,
and then click the Basic sub-tab.
2. Select On or Off in the Auto Answer drop-down menu in the Other Basic Fax
Settings section.
Set the number of rings before answering
If you turn on the Auto Answer setting, you can specify how many rings occur before
incoming calls are automatically answered.
The Rings to Answer setting is important if you have an answering machine on the
same phone line as the device, because you want the answering machine to answer
the phone before the device does. The number of rings to answer for the device
should be greater than the number of rings to answer for the answering machine.
For example, set your answering machine to a low number of rings and the device to
answer in the maximum number of rings. (The maximum number of rings varies by
country/region.) In this setup, the answering machine answers the call and the device
monitors the line. If the device detects fax tones, it receives the fax. If the call is a
voice call, the answering machine records the incoming message.
To set the number of rings before answering via the control panel
1. Press Setup.
2. Press Basic Fax Setup, and then press Rings to Answer.
3. Enter the appropriate number of rings by using the keypad, or press the left or right
arrow button to change the number of rings.
4. Press OK to accept the setting.
To set the number of rings before answering via the embedded Web server
2. Select a number in the Rings-to-answer drop-down menu in the Other Basic Fax
Settings
section.
Dec 02, 2010 | HP Officejet Pro L7650 Printer
No matter what phone I use, my magic jack wont ring!
Seems like alot of discussion around on getting phones to ring.
I think the interesting scenario here is when people want to be able to connect the MJ to house wiring to have phones connected remotely work normally (call/ring).
First, it is important to have phones which have REN's (Ringer Equivalence Number) be as small as possible (usually the REN can be found on the phone or in its technical specifications).
I started with MJ connected to my home wiring (ie connect MJ to a wall phone socket hoping to have a phone elsewhere in the house work normally). I was using a TRU8885 with 2handsets (is AC powered) - the REN on this phone is a paltry .08 . I could call normally, but not get a ring.
I had an old computer with USB ver 1.0, so I first got a cheap USB 2.0 card which I installed which did not fix the problem - it is reasonable to assume these cards have sufficient power.
I tested the phone directly attached to the MJ (4ft phone cable) and it rang. I tested likewise with a 20ft cable and it worked. I reconnected to my house network and it did not work with the phone attached to phone jack at my desk. icon_sad.gif
I traced the lines in my basement (I was already disconnected from outside landline connection) contemplating eliminating unnecessary wiring and lo and behold I discovered in a corner of my basement that an old bell-ringer phone was connected to my house network! When I disconnected this phone (and the obvious voltage load associated with it), my phone rang perfectly.
Here's my conclusion:
1. use a phone with lowest possible REN (less than 1 certainly, closer to .1 desireable).
2. don't worry about powered hubs if already connected to computer's USB since it is likely sufficiently powered.
3. don't get into power boosting phone systems (see #1)
4. eliminate high-REN other devices from phone network
5. run a test of of phone direct connected to MJ - if this doesn't work, likely your phone is not AC powered or is too high a REN.
Jul 06, 2009 | Uniden Lands Phones
Cant receive a fax
Your voice mail is probably answering before the fax can grab the line. Try setting the number of "rings to answer" on the fax to 1 or 2 rings less. The best solution if you only have one phone line is to buy a device called a "comswitch". I use one. They automatically detect if the incoming call is a fax and switch the call to the fax machine. If its not a fax it switches the call to the proper device. They are not that expense. Look on e-bay.
Larry
Dec 01, 2008 | HP OfficeJet 6110 All-In-One InkJet...
How can I change the Rings to Answer setting to one ring?
1.
Press Setup.
Get manual at http://h10032.www1.hp.com/ctg/Manual/c00863866.pdf
Jul 07, 2008 | HP Officejet Pro L7680 All-In-One Printer
No respond to incoming calls
go to phone settings. check the profile and change it accordingly..regs
Jun 19, 2008 | Nokia 6260 Cellular Phone
Unable to Receive Incomming Fax's
I need help with my MFC 240 c Brother printer. I cannot send faxes or receive faxes. I do not know how to set the setting. Plus I lost my book that went with it.
Feb 07, 2008 | Brother Multi-Function Center MFC-240C...
Cell Phones Logo
21 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
