Question about Dishwashers
Can you please tell me where i can find a manual for dishwasher tisira l65x. we have just had it installed by landlord and it is not letting water through. we have checked the plumbing and it is fine but the dishwasher is not taking the water
  • 3,740 Answers
Hi and weclome to FixYa, I am Kelly.
This is a new unit..... Look inside the bottom tub area for a domed plastic float and remove the packing tape from it. (usually either front left or front center. Also if there is a flood switch with packing material on it..... it usually will be mid point RH side of the lower tub area.
I searched for a manual without success. This appears to be a contractor only dishwasher.
I am certain the problem your having is that not all of the packing materials have been removed. The tape is usually on the inside of the tub but... depending upon manufaturer there can also be tape under the unit. Look for paking tape and remove it. The tape is usually white or a light tan.
The water level sensors are taped during shipment to prevent damage.
Thanks for choosing FixYa,
Kelly
Posted on Apr 11, 2011
  • Kelly
    Kelly Apr 12, 2011
    Just doing a folow up. Did you find any packing materials still in the dishwasher? If this is 2nd hand dishwasher the float switch can be stuck in the UP position and this also will prevent any water from being introduced into the dishwasher. Food particulate / debris gets on the stem of the float assy and it will not move up or doen the 1/2" that it should. The stem will have to be cleaned so that as you raise the float assy. up you hear a microswitch CLICK. Als as you let gravity lower the float you should hear a CLICK. The click you hear as you lower the float is the one that provides power to the inlet water valve. IF you diswasher also has a FLOOD switch and it happens to be stuck in the up position you will get no water but the unit will attempt to drain.
    Kelly
HAVE NO INSTRUCTION BOOKLET. MOVED INTO THIS HOUSE, CAN WE OPEN UP THE DISHWASHER SOMEHOW DURING THE 87 MINUTE SHORT CYCLE? WE CAN'T OPEN IT!
Maybe might find a user'smanual for your old unspecified dishwasher but you should provide make and model. Also, you can make a google search for it usiing terms manual, the make and the model
Jun 22, 2015 | Dishwashers
L65X Dishwasher problem
has there been a soultion mine is doing the same?
Jan 10, 2012 | Dishwashers
Hi I have a DS605SS Fisher & Paykel Single Drawer dishwasher, I rent the house and the landlord says that it is quite new can you please confirm the year? Also when we turn it on it runs for like 20...
Heeeyyy - these have been around for ages no one can tell you the age unless you bought it and know where it was bought from to trace the serial numbers...
I fail to understand why this is your problem when you are renting the house. Tell your stingee landlord to get it fixed - you are getting shafted,,,
Its unacceptable for a Landlord to do this..
Jun 12, 2011 | Fisher and Paykel DS605SS Built-in...
I'm using a GSD 1100G00WW that is probably from may of 1991, landlord says its fine but, I have had yuckie dishes for two months, how long do these last in hard water? My dishes seem to come out dirtier...
Sorry but FIXYA does not get into wars between tenants and landlords . you have an option to MOVE,or possibly sharing in the cost of replacement unit .
Oct 20, 2017 | GE Dishwashers
My wife and I are renting a house. The landlord told us that the water heater was recently replaced. The hot water smells pretty bad. The landlord says that the fowl smell is due to the anode rod in the...
Hi. Your landlord is correct. Anode rod can produce rotten-egg smell. Ask him if he can replace the "sacrificial" anode rod with "Power" anode rod or zinc/aluminum rod to get rid of the smell. However, you need to decide whether you tolerate the bad smell produced by anode rod or the minimal toxin produced by zinc/aluminum rod.
You can also try to drain/clean the tank first then add peroxide treatment and see if the smell goes away. If you do this method, the smell is more likely to come back if you go on vacation and left the heater unused for several days.
This article explains it better: Why Does My Water Smell Like Rotten Eggs (scroll down to page 2)
Let me know if you need further assistance. Thanks.
Jun 18, 2010 | Kitchen Ranges
My landlord would like to use my router. how do i
It depends on your router settings. If you use a password, your landlord will need to know the type of security and your password. If you use a mac address filter, you'll need to add your landlords mac address to the list in your settings. Try connecting to your router in a web browser, it's probably at 192.168.1.1, and look at your security settings.
Feb 12, 2010 | NetGear WGR614 Wireless Router
Kenmore dishwasher has never cleaned dishes
make sure you are getting plenty of water. Start the D/W without putting soap in disp. run for about 1 minute, Make sure there are no suds inside. If there is, run full cycle to get excessive amount of soap out. If no suds check in pump resevoir to make sure its not clogged.
Jan 05, 2008 | Dishwashers
Dishwasher: GE Profile Quiet Power II
the product model name and/or number?. and I could easily find a guided manual for you.
Dec 28, 2007 | Computers & Internet
Dishwashers Logo
281 people viewed this question
Top Dishwashers Experts
