Question about Plumbing
Do you have a diagram of an ajax valve I could look at? Water leaking from pipe on roof, ajax may have to be readjusted. How???
  • 710 Answers
Hi jogun457,
If you have water coming out of the pipe on your roof, then the water pressure is set too high. Yes, you should adjust your ajax valve.
To do this, locate the adjustment screw either on the back or the top of the valve. Turn it counterclockwise to reduce the pressure. Watch the pressure gauge (does yours have a gauge on it?)
and wait after each turn for the pressure to settle before making another adjustment until you have the correct pressure.
If you don't have a gauge, turn the screw counterclockwise 1/4 turn, then you'll have to watch your pipe to see if it has stopped leaking water onto the roof. Don't turn too much at a time or you'll lose pressure at your taps. Turn the faucet on after each adjustment to check.
Hope this helps. If it does, I'd appreciate your vote. Thanks for visiting fixya.com
Handie Andie
Posted on Apr 11, 2011
Black water coming out of returns from solar panels on roof of my home. Panels are 15 years old and there was frost in San Diego the nite before it happened
How do solar hot water panels work? - Explain that Stuff
www.explainthatstuff.com/solar-hot-water-systems.html
Jun 2, 2015 - Photo of solar hot water panels on house roof. ... What if you cut the top and bottom off a plastic bottle and fitted pipes at each ... This is the technical name for the big black panel that sits on your roof. ... The heat is then passed into the hotwater tank, and the cooled water (or fluid) returns to the collector to ...
Solar water leak - YouTube? 1:46https://www.youtube.com/watch?v=WaWkzfs6bikMay 22, 2012 - Uploaded by EnovativeGroupLeaky solar system, enovative group investigates... ... Solar water leak ... Solar Water Heating Panel and ...Pool Solar Panel - A How to Fix - YouTube? 2:50https://www.youtube.com/watch?v=f_KzEsxQhbEJul 7, 2012 - Uploaded by Clive WoodrowEasy and cheap way to fix a leak in your pool solar panel. ... The pipe (to carry the water to and from the ...
Dec 21, 2015 | Solar Pool & Spa
How do I install my hot water heater?
Youtube offers many videos of the water heater installation. Drain first with a garden hose. after turning off water and unplugging electric or shut off gas.
If changing to a tankless, remember they often require a larger vent pipe to the roof. 4" usually, not the 3" for tank water heaters. Local building codes may require a permit and a larger Gas feed pipe.
Also if you're going to use the old Pressure Relief Valve DO NOT test the valve by activating the little lever. Once used over time their internal seals weld onto the closed seat and tend to rip and leak if you test the valves function. Replace with new ( $15) if it's been operated. Most plumbers now use Braded Feed Lines from/to the Water sources, making future replacements easier. You might find the replacement Tank is not the same geometry as the old one, having longer braided feed lines helps when they are on opposite ends of the tank top and the original feed lines are copper and wont reach the new tank pipes or the tank gas starter door is on the back side requiring you to rotate the tank 180. If you're changing size, measure the width and height. It might not fit the old installation.
Apr 24, 2014 | TitanNet TITANTANKLESS. COM PRESENTS THE...
Is my water heater leaking?
You have water leak that you can hear running water.
Could be broken pipe under house.
Could be water running out of tank at TP valve.
Turn off all water taps and put ear against each pipe at tank.
If TP valve is leaking, then replace TP valve.
If pipe is broken under house, then call contractor.
Copy following links for troubleshoot walk-thru.
http://waterheatertimer.org/images/Ear-against-pipe-200.jpg
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#listen
Aug 28, 2012 | Reliance 606 Series 40 Gallon Electric...
GE Smart Water Model # GE40M06AAG
Bad relief valve or too much pressure in the tank. Does water heater system have a pressure blotter tank that allows for expansion(an expansion tank)
May 05, 2017 | Water Heaters
I have a 3 ft stainless double wall chimney that is going thru a ceiling/roof in my garage. there were no instructions on installation. how is this secured? Pls thx Jer
You can use metal strapping with short self-tapping sheet metal screws also where it penetrates roof a metal collar on inside should be used and a roof collar approved for B-wall vent pipe to keep water from leaking inside on outside on the roof.You can penetrate outside of B-wall vent pipe with short screws to secure the pipe just don't penetrate both pipes.this outside pipe is just a insulator to keep heat from transferring through pipe.
May 01, 2011 | Selkirk METALBESTOS 104082 ROUND GAS VENT...
Pressure releif valve leaking
Hot water pressure relief valves serve two functions. The first is to remove high-pressure water from the hot water tank. The second function is to act as a high temperature valve to remove water that exceeds a predetermined point for the valve. Both of these relief settings are preset at the valve factory. Many pressure relief valves will come with a metal tag that identifies these release points. If you're attempting to remove the hot water heater pressure relief valve, pay careful attention to ensure that you replace with the correct valve.
Your hot water heater has a pressure relief valve safety mechanism. When pressure inside the water tank exceeds certain limitations, the valve opens up to allow the pressure to be released. A faulty pressure relief valve will not release excess pressure, which could cause extensive damage to your home. You should test the hot water heater pressure relief valve once every six months to ensure proper operation. If the pressure relief valve fails the test, replace the valve with a new one immediately
Locate the pressure relief valve on your hot water heater. The pressure relief valve has a lever handle on top with a drain pipe attached to it. The pressure relief valve is most often on the side of the water tank toward the top. Newer models of hot water heaters have the pressure relief valve on top of the water tank.
  • Inspect the area around the pressure relief valve for signs of leaking water. If there is leaking water near the relief valve connection, replace the relief valve. If no leaking is evident, proceed with testing the pressure valve.
  • 3
    Examine the area below the pressure relief valve drain pipe. Most water heater closets either have a drain in the floor below the pipe or the pipe is inserted into another pipe to direct the water out of the home. If the end of your drain pipe is not in another pipe or there is no drain in the floor, place a bucket under the drain pipe to catch water when you test the pressure relief valve.
  • 4
    Pull the lever handle on the top of the pressure relief valve up with your fingers. A working lever will lift up without difficulty.You should begin to hear water going through the drain pipe. Slowly release the lever to shut off the pressure relief valve. The pressure relief valve is good. If you did not hear water running through the drain pipe, lower the lever on the pressure relief valve and replace the valve. If the lever is difficult to raise, do not force the lever. Replace the pressure relief valve.
  • Now with all that said if you have a closed loop water supply system and you have a pressure vessal/expantion tank it may have gone bad and is making the TP valve leak. you can call your water provider to see if you have closed loop system.
    Feb 04, 2011 | Whirlpool Water Heaters
    Turned off the hot water to fix a leaking tap. now the tap has no hot or cold water and the hot water tank valve is leaking?
    It sounds like two problems.
    Problem 1) Clog inside faucet or clog inside pipes at faucet
    Remove supply tubes leading to faucet and see if problem is inside pipes or inside faucet.
    My bet is clog inside faucet.
    If you have galvanized pipe that meets copper pipe, this can be trouble spot.
    Article on clogged water pipes at Inspectapedia:
    http://www.inspectapedia.com/water/Water_Pipe_Clog_Repair_Guide.htm
    Article on clogged pipes:
    http://www.waterheaterrescue.com/pages/WHRpages/English/Troubleshooting/Tanklets/backflushing.html
    Problem 2) Water heater leak ... you say tank valve is leaking? Is that cold-water shut-off valve? Or tank drain valve? Or TP valve?
    If cold water shut-off is leaking, then replace shut off.
    If tank drain valve is leaking, then check if plastic valve is cracked. If drain valve is cracked, then replace with a brass valve from Home Depot. If plastic valve breaks off, then use hammer and screwdriver to gently chip out the broken plastic valve. New valve threads need teflon tape to seal pipe. If valve is just dripping, then put garden-hose cap over end of valve and screw down tight.
    If TP valve is leaking, then replace with same temperature and pressure rating.
    New TP valve threads need teflon tape to seal pipe.
    Problem 3) If pressure is low all over house:
    Buy pressure gauge at hardware store that screws onto hose connection.
    Test pressure on outdoor spigot.
    Open faucet and check if pressure drops. This says if problem is inside pipes that enter house.
    Test pressure on water heater drain valve.
    This says if pressure problem is before -or- after water heater.
    If problem is before the water heater, then shut-off valve located on cold water line is suspect.
    If problem is after water heater, it could be in hot water outflow pipe on top of water heater, or a nearby elbow.
    Remove hot water line leading from water heater and check pressure. This says if problem is where hot water leaves tank.
    Read articles above about clogs inside water lines.
    Nov 16, 2010 | Rheem Water Heater Pressure Relief Valve
    Removing a stove pipe through the roof
    I would begin by going up on the roof to see what the situation is because you are going to have to remove the stove pipe and repair the roof to assure no leaks. Usually the only thing holding the pipe is roof cement through a rubber boot. Use a razor blade knife to cut through the tar, then remove the boot by pulling the roofing nails that hold it in place. After that, patch the roof and reshingle. If this is more than you care to do yourself you will have to hire it done. good luck
    Jan 22, 2009 | Plumbing
    Plumbing Logo
    1,885 people viewed this question
    Top Plumbing Experts
    Donni Steen
    Tom Chichester
    Are you a Plumbing Expert? Answer questions, earn points and help others
