Question about Compaq Evo D510 PC Desktop
My comptuer do not show the clear display it show like cloud!
    Master:
  • 341 Answers
Adjust the display of the monitor using its buttons. Adjust the brightness and contrast.
Posted on Apr 11, 2011
If a municipality takes a clouded-title property for unpaid taxes, can that property be sold given the cloud?
This is a case of "Buyer Beware". Depending on state laws, a municipality is allowed to sell a clouded property with a "quit claim deed" which means they only sell the municipality's interest in the property and the cloud remains. A diligent buyer should discover what the cloud is that is tainting the title and determine if the title can be cleared (use a Title Company or attorney). If the cloud is environmental contamination that property must be cleared of the contamination under the laws of the state and the EPA. For protection the buyer should require a warranty deed from the municipality as a condition precedent to sale which would require the municipality to clear title of any defects prior to a sale. No person should buy a property without clear title for your own protection.
Jan 04, 2017 | Municipality
I have received instruction on new iPad to delete a book from my kindle library and then reload it from the cloud. How
Make sure you have the Kindle App.
when you display your Library ( items on iPad ) your screen will show something like this ( non grid view)
26301916-wwqbgew2mggh3wiwo1yeqqgk-2-0.png Notice at the bottom it will say device or cloud.
on device you should be able to,slide book title to the left revealing the word Archive in red banner.
26301916-wwqbgew2mggh3wiwo1yeqqgk-2-2.png Touch this and it should be sent back to Cloud.
Oct 05, 2016 | Apple iPad Air
I reset my kindle and cannot get table of contents. I am showing the covers of the books instead of listings.
It sounds like you might be looking at the Kindle Store.
Try touching the top of the screen. This should cause some icons to display. Touch the Home icon. You should then see a list of books that are stored locally. If the reset wiped them all out and they don't show then you'll have to touch the top of the screen again and then touch *Cloud* after connecting to 3G or Wi-Fi and select the books from your Cloud that you want back on your device.
May 10, 2015 | Amazon Kindle Paperwhite
My pendrive show unrecognized in my pc. what should i do
Insert pendrive firmly 1st then restart ur pc ; inbuilt pendrive drivers will be installed after restart of pc your work refresh ur comptuer about 5 times till the drivers get installed goto "mu computer" ur pendrive icon will be displayed double click n start using repeat the above process if it doesnt work 1st time
Sep 23, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
When turn on comptuer the screen show red, blue, green squares scrolling, cannot see boot process. What is causing this?
Most probably you either have a loose connection between your monitor & your PC, or the data cable connecting the monitor & the PC is defective & needs to be either repaired or replaced.
You can try to use another cable of the same type & see if this will fix the problem.
Jun 08, 2010 | Gateway 450ROG 15inch SXGA+ LCD Display-...
How do i connect my compaq pc to tv
Without the model number comptuer, I cannot verify what outputs your comptuer has. Without this, I will provide the various ways a PC can be connected to a TV.
1. Use a VGA to DVI adapter (HD-15 pin to DVI). Use either a standard VGA montor extension cable (cheaper) or a DVI extension cable (more expensive) to make the connection
2. If you computer has a DVI output, use a DVI extension cable only
3. If your computer has HDMI output - use a HDMI to DVI adapter and either a HDMI or DVI extension cable.
In all 3 cases, you will probably need to go to the comptuer's Display Properties and adjust the screen size so it looks OK on your TV (go to the Control Panel - find Display) and adjust the screen resolution to match the format of your TV.
One note - when purchasing DVI cables, understand that there are 3 types - DVI-D (digital), DVI-A (analog) and DVI-I (digital and analog) and that the pin outs are different. Be sure to check your the owners manual of your TV to find which connection it needs.
Here is a good reference for DVI types
http://www.interfacebus.com/Design_Connector_Digital_Visual_Interface_DVI_Bus.html
Dec 02, 2009 | Compaq Computers & Internet
Hitachi cp-s240 blue tint cloud problem
This might sound like a worn spot in the (blue) lens from heat, or a bad color driver on the mother board. It could possibly be dirt or condensation behine the lens(s)
Jun 19, 2009 | Hitachi CP-S240 Multimedia Projector
Used Toner Bottle Full Ricoh Aficio 1035P
The used toner is stored in the Transfer Belt assembly on the right door that you open to remove a jam. Remove one spring on each side and release the catch while gently lifting up on the belt and roller assembly. It swings 90 degrees up from the rest of the assembly. There are 6 screws that hold a cover on the lower assembly. remove it and dump the waste toner. *** VERY MESSY*** have a vac on hand. Not a shop vac unless you want toner clouds floating around the office. If the six screws aren't present, dump the toner out of the **** between the mylar-rubber blade and the lower assembly. once this is done, the message will clear.
Apr 08, 2009 | Ricoh Office Equipment & Supplies
No picture
You may need to reduce the resolution on your comptuer screen. Try going to Control Panel, Display, and Settings and lowering the resolution a notch or two.
Also, you must make sure that the computer is set to send the signal to the external monitor,. That usually means holding down the Function key and pressing the F5 key or the one with the picture of two monitors on it. You will see several options for display. Toggle with the F5 key to the one that shows the computer screen and the external monitor at the same time.
Dec 19, 2007 | CTX Optoma EzPro 580 Multimedia Projector
Compaq Evo D510 PC Desktop Logo
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
