Question about HP Photosmart C6180 All-In-One InkJet Printer
Colour not printing properly have replaced all cartridges how do you clean the heads
    Scholar:
  • 166 Answers
Well take out all the cartidges and cleaning procedure is mentioned below: http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?tmp_rule=52784&tmp_task=useCategory&lc=en&dlc=en&cc=us&lang=en&product=1153494&key=null&site=null
Then before you insert the cartidges turn off the printer and unplug the power cable from the back of the printer press and hold the power button of the printer for atleast thirty seconds release the power button.Then wait for atleast ten secs, plug the power cable back in the printer wait for ten secs let the printerwarm up and open the cover to insert the cartidges. Try and print I hope this will reslove your problem.
Posted on Apr 11, 2011
Replaced ink cartridge- still not printing! help
When the printer is not indicating you need to replace a cartridge, and it is not printing good, most of the time the print head is clogged. Run the head cleaning program several times and if that still not works, remove the cartridge and put a drop of clean water or printer cleaning fluid fall in the nozzle, you see down where the cartridge was seated.
Then print a few pages, with the colour that would not print and continue till you see the colour come back again.
switch a ink jet printer on at least once a week. During startup the printer will perform a cleaning cycle. After a few minutes you can switch of the printer. This could keep the front heads clean for a long time.
Success
Mar 23, 2015 | Epson Expression Home XP-410 Small-in-One...
Printing colour is wrong, colours come out pink. Nozzle check indicates cyan colour is not printing. I have carried out cleaning, deep cleaning. I've cleaned the print head and finally just replaced the...
> replaced the print head
Did you replace the tri-colour ink-cartridge, or did you replace the print-head mechanism?
Are you sure that the CYAN part of the ink-cartridge is not empty?
Mar 09, 2011 | Canon i9900 InkJet Photo Printer
I have a Canon Pixma MP270 and I can only print in colour both the black and colour lights are lit up on the printer
f print quality does not improve by the standard cleaning of the Print Head, clean the Print Head deeply. Cleaning the Print Head deeply consumes more ink than the standard cleaning of the Print Head, so clean the Print Head deeply only when necessary.
1. Make sure that the power is turned on.
2. Clean the Print Head deeply. (1) Press the g0022565.png (Maintenance) button repeatedly until y appears. g0054776.png
(2) Press the Black or Color button.
The machine starts cleaning the Print Head deeply. Do not perform any other operations until the machine completes the deep cleaning of the Print Head. This takes about 2 minutes.
3. Check the print head condition.
When the deep cleaning is completed, the LED returns to the copy standby mode. To check the print head condition, print the nozzle check pattern.
See " Printing the Nozzle Check Pattern".
If the problem is not resolved, turn off the power and clean the Print Head deeply again after 24 hours.
If the problem is still not resolved, replace the FINE Cartridge with a new one.
See " Replacing FINE Cartridges".
If the problem is still not resolved after replacing the FINE Cartridge, contact the service center.
Print the nozzle check pattern to determine whether the ink ejects properly from the print head nozzles.
NOTE If the remaining ink level is low, the nozzle check pattern will not be printed correctly. Replace the FINE Cartridge whose ink is low.
You need to prepare: a sheet of A4 or Letter-sized plain paper
2. Load a sheet of A4 or Letter-sized plain paper in the Rear Tray.
3. Open the Paper Output Tray gently, and open the Output Tray Extension.
4. Print the nozzle check pattern.
(1) Press the g0020617.png (Maintenance) button repeatedly until A appears. g0054754.png
The nozzle check pattern will be printed.
5. Examine the nozzle check pattern.
See Examining the Nozzle Check Pattern.
Examine the nozzle check pattern, and clean the Print Head if necessary.
1. Check if there are missing lines in the pattern (1) or horizontal white streaks in the pattern (2). g0054755.png (1) Check if lines are missing in this pattern. If yes, the cleaning is required.
See " Cleaning the Print Head".
(A) Good
(B) Bad (lines are missing)
(2) Check if horizontal white streaks are present in this pattern. If yes, the cleaning is required.
(A) Good
(B) Bad (horizontal white streaks are present)
Post back!
Oct 26, 2010 | Canon Office Equipment & Supplies
My epson CX3900 not printing in black. colour printing is very good i did many head cleaning with the epson utility but not help at all. my black ink cartridge is full, is there any other way of fixing the...
1. Have you checked the protective tape that covers the contact area on the cartridge.
2. this may be a clogged head on the black cartridge side of the print head even though you used the print head cleaning utility.
3. You may have to contact the manufacturer to see what they recommend as how to clean the print head properly.
Apr 19, 2010 | Epson STYLUS CX3900 All-In-One InkJet...
Mx700 only printing in B&W
This is a software problem, do uninstall and re installation of the printer software on your computer and that should do it...
Dec 14, 2008 | Canon MX700 Office All-In-One InkJet...
One color
yep, print head needs proper clean, here it is.
OK, Canon will hate me for posting this.
1. Remove ink cartridges
2. Remove print head
3. go to sink or tub (stainless steel, not plastic type), pick up a roll of paper towel on the way.
4. Fold several layers of paper towel and place on flat surface.
5. Run hot water until HOT!
6. Turn hot water back to a dribble.
7. Run the dribbling hot water through print head, be careful not to wet the gold contacts.
8.When water running through print head is clear, place print head on paper towel.
9. Repeat number 7 and 8 until no colour shows on paper towel.
10. Gently DAB print head (DO NOT WIPE) inside and out with dry paper towel until dry.
11. I normally replace print head after drying, but you may wish to let it air dry overnight.
12. Replace print head in printer and install cartridges
13. Start printing.
I do this to all 4 of my Canon printers every 6 months or so.
If any colour fails to print after this process it means your print head probably needs replacing.
Jun 29, 2008 | Canon i860 InkJet Photo Printer
Colour prints not satisfactory
D_foofat,
This link will take you to instructions on cleaning your Cartridge Print Head: http://h10061.www1.hp.com/ccsearch/search?method=viewDocument&redirUrl=http%3A%2F%2Fh10025.www1.hp.com%2Fewfrf%2Fwc%2Fdocument%3Fdocname%3Dc00285228%26cc%3Dus%26lc%3Den%26dlc%3Den%26product%3D402150%26dlc%3Den%26lang%3Den&docId=document%28c00285228%29&uqry=&cqry=clean+printhead&ctry=us&dlc=en&lang=en&qry=clean+print+head
I hope it helps, and Good luck.
Mar 16, 2008 | Computers & Internet
New colour cartridge but no colour print
sorry but not much, there is a product on the market called nozzle rockett, it is the best i've used to free up a clogged print head, in AUS you can get it at any Cartrige World
Feb 28, 2008 | HP DeskJet 845c Printer
HP F380 printer
This happens when your print head gets dirty. Just claening the print head should solve your problem. To do this: Click start button > click Printers and faxes. > Right the printer icon > click properties > Here you should find something like "Head cleaning" or "Clean the print head". This option can be used to clean the priter head automatically. If it does not work, you can manualy take out the cartridge and dip it in to IPA (Isopropyle alcohol) solution would clean the head[dip the head only not the complete cartridge]. After a few minutes (10-20) you can fit the dry cartridge the printer. If nothing works try changing the cartridges. Note: When the ink is running out this may occur. The only thing we can do is to replace the cartridge.
Oct 06, 2007 | HP DeskJet F380 All-In-One Printer
HP Photosmart C6180 All-In-One InkJet Printer Logo
63 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
