Please can you help my boiler is making loud noises similar to a perculator/kettle boiling. What can I do to resolve this?
  • 40 Answers
Sound like you have air in the system, bleed off at each rad
Posted on Apr 13, 2011
Very loud foghorn sound
Loud rumbling noises are often caused by either water boiling in the burner or by entrapped air in the system. To help prevent water boiling make sure that the boiler system has a pressure between 15 - 30 psi. Also check for sufficient water flow and remove any sediment from the in-line filter. To remove entrapped air, install an automatic or manual air vent at the highest point in the heating system and also make sure you have a properly working micro-air vent installed. With the unit turned off and cooled down, you can also try flipping the lever on the pressure relief valve to try and flush out any air in the heat exchanger . Hope this helps.
Sep 06, 2014 | Noritz Water Heaters
I cannot take off the lid of the Pro chef and manual is unclear. How do I unlatch it?
Manual Pro Chef PU 100
I have received the hot water boiler, but it does not stop boiling the water. Instead of going to "Keep Warm", the machine continues to boil the water indefinitely. We left the boiler on and came back after 2 hours, and it didn't stop heating the water. Therefore, I refilled the boiled, turned off the machine, unplugged it, plugged it back in, and then turned it back on. The water continues to boil without going to "Keep Warm". I require a solution to the issue or a replacement as soon as possible.
Apr 25, 2014 | Le Chef Electric Shabbos Hot Water...
Making noise when running
PUMP check it out does the boiler sound like a kettle boiling if so its over heating and needs descaling
Sep 18, 2013 | Fasco Water Heaters
What is an electric kettle? Is it different than stovetop one?
An electric kettle uses electricty and not the stovetop. Once the water has boiled, the kettle stops heating the water and you hear a noise signaling that the water is ready. I use one every day becuase I find that it boils faster than using a stovetop.
Jan 16, 2013 | Home
Why my boiler makes noise
Your boiler might have air in the top. This is called kettling. If you have a air eliminator on top of the boiler it may have stopped letting collected air out. Usally sounds like a kettle boiling.
Dec 13, 2012 | Water Heaters
Hi, I have a Bosch Private Collection Kettle. It is over a year old and has until recently been working fine. However, lately I do not feel that it boils to a high enough temperature for a long enough...
Some types of kettles use a separate power base to heat up the kettle jug. If this is the case with yours, turn the jug upside down and look. Also look at the parts on the base that touch the kettle jug contacts. If you can see the electrical contacts; mine were built on spiral rings for differing temperatures; try cleaning them with Brasso and a Q-tip (cotton swab) wiping the contacts several times to remove any tarnish and then use clean swabs to remove all traces of Brasso metal cleaner. Fill the kettle jug up to the maximum fill line and put the boiler on the maximum setting... boiling water. If the water doesn't boil... you have a more serious problem. Buy a new boiler as it isn't worth having someone fix it. Mine worked like new after I cleaned the contacts. Never immerse the jug contacts in water!!!
Nov 25, 2012 | Bosch Private Collection Jug Kettle steel...
Our kettle has started making a crackling noise when turned on now; thought it does boil the water, and there is no odd smell from it.
Our kettle start making the same noises and now no lights come on. i can spin it around the base and sometime it connects and work. i think it's an electrical issue of the base. i wonder if anybody knows if it's possible buy just that part, i would hate to buy new kettle just because of bad connection.
Jan 24, 2010 | Breville SK500XL Stainless Steel Cordless...
Brokem switch on bodum kettle,
The problem with your bodum kettle is not the switch but the fuse that is in the bottom of the kettle. Because you cannot stop the boiler even when it is empty, the boiler overheat and burn the fuse at the bottom. You must unscrew the 3 screws at the bottom part of the kettle (not the base), then unscrew a nut that retain the fuse in a gain to the base. cut the wires and replace the fuse by a new one (less than 2 dollars on ebay). You should not exceed the temperature of the fuse(172 C) as it will melt your boiler if there is no water. Thats why you have to put a fuse. This helps me resolve my button issue with my bodum kettle.
Jun 25, 2009 | Bodum Electric Kettle
Can i use water boiled from microware to make formula milk for a baby that is 1yr old
I wouldn't recommend to use the microwave to boil water. Here you can read the reason why: http://www.snopes.com/science/microwave.asp
Water can 'explode' when heated in a microwave under certain conditions. Best way to boil water should either be using a water boiler or an old-fashioned kettle.
Jun 17, 2009 | Westpoint TV-201 Microwave Oven
Switches off before full boil
Look under the kettle at the round circular connector in the bottom. Inside there is a small button that is depressed when the kettle is put on the base. If this is not pushed in far enough it will have problems.
The cause is that after some use the connector in the base plate collapses into the base by 1-2 mm This means the switch is not pushed in far enough.
My kettle had similar issues... I pulled the base plate apart (3 screws I think) and cut a round disk of plastic to lift the connector up by about 1-2mm and then reassembled the base.. No more issues
Nov 23, 2007 | Russell Hobbs RHOK3123 Cordless Electric...
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
