Question about MGE UPS Pulsar Ellipse Premium 800 UPS System
Hello, I own an ellipse premium 800 UPS system. I plug it in and it won't work at all. No sounds, no beeps no lights. I thought it could be that a fuse is burnt so i opened up the box. There are 2 fuses FU1 and FU2. I used my multimeter to see if current runs through them and it does on both so it shouldn't be the fuses. I also measured the voltage output on the two batteries. One shows 2.2 V and the other one 6.4V Could you please point me to the right direction? What could be the problem? I am a student in Electronic Engineering so I would really like to fix it myself so that I will learn something from all this. Thank you for your time
    Problem Solver:
  • 9 Answers
Check input utility voltage and ensure batteries are plugged in
Posted on Apr 19, 2011
I need to conect to my UPS via my computer . Not sure who to do this?
Is easy, here is how to do it:
  1. Plug your computer in your UPS
  2. Plug the UPS to an outlet/plug
  3. Start the UPS
  4. And done
If you want your monitor conected to the UPS make sure it has 2 spacest to plug them in or use an extension cord with 2 outlets or more.
Hope it was usefull
May 06, 2011 | MGE UPS Pulsar Ellipse Premium 500 UPS...
Hello, could you please tell me the battery type of this UPS model in order to change it? Thank you.
12V (Per Cell)
6Ah
Dimensions
151mm x 94mm x 51mm (Per Cell)
Sealed Lead acid battery - you need 2 of these!
Oct 05, 2010 | MGE UPS Pulsar Ellipse Premium 800 UPS...
Hello, could you please let me know the battery type of MGE premium ellipse pulsar 800VA ups? Thanks in advance.
The batteries in an UPS are sealed lead acid batteries. The voltage and amp hour rating depends upon the VA rating of your UPS.
I suggest you shut down your UPS and remove the batteries and get replacement ones that are the same rating as the ones in the UPS. Be careful of the size of the battery, they are a neat fit inside the UPS battery compartment.
It beeping all the time
Does the red light flash over the battery symbol?
If so the batterries are either faulty or have a low level of charge or the charging circuit is faulty.
Batteries in the UPS typically last 3 to 5 years and it depends upon several factors. including the number of times the unit must go on battery power and environmental conditions. There are usually several batteries in the UPS and while the battery voltage may show 13 volts, this may only be a float charge/voltage and a true indication of the battery voltage and condition requires the batteries to be tested under a load. There maybe one battery in a set of batteries that is faulty and causes the whole battery system to fail and indicate a battery fault.
Oct 05, 2009 | MGE UPS Pulsar Ellipse Premium 800 UPS...
Ups problem
The batteries need to be replaced. They probably have more than 3 years.
Replace the batteries and let the new ones charge fully for a day and your UPS will work like new after that.
Oct 14, 2008 | MGE Pulsar Ellipse 800 (89363) UPS System
MGE UPS SYSTEMS ELLIPSE 800
i think u need to replace the battery so u get it working again.
thank u
May 20, 2008 | MGE Pulsar Ellipse 800 (89363) UPS System
Pulsar ellipse 500 problem
Please use a flat screw driver. Press it a bit hard and you can turn the screws and open it. There is a problem with the RELLY. I suggest you see a technician.
Mar 08, 2007 | MGE UPS Pulsar Ellipse Premium 800 UPS...
MGE UPS Pulsar Ellipse Premium 800 UPS System Logo
142 people viewed this question
Top MGE Computers & Internet Experts
Jax Planet
Jax Planet
Raj Patel
Are you a MGE Computer and Internet Expert? Answer questions, earn points and help others
