My dell inspiron 1420 laptop is unable to boost up (start) when switch on the power switch. The power swith light was go offf after fews second. please advise whether is the graphic card faulty or mother faulty or others.... Thanks for your technical advice
  • smng1315 Apr 11, 2011
    my dell inspiron 1420 laptop is unable to boost up (start) when switch on the power switch. The power swith light was go offf after fews second. please advise whether is the graphic card faulty or mother faulty or others.... Thanks for your technical advice
    * the power and battery and cable connection are in good condition. (no problem at supply to laptop)
  • 415 Answers
The last time you used it did it have power/battery life left? This will happen if it is completely dead. Check to see if your power adapter is plugged in tightly and watch to see if the indicator light comes on when you try booting up.
It sounds like a power problem because problems with the OS (operating system) may not get you into windows but it doesn't shut down the machine like that.
If it's plugged in correctly then you may have a problem with the power adapter. They can go bad...
Posted on Apr 11, 2011
Dell Inspiron 1420 switch off while on at Internet site and it will not start up again when pressing the on button.
you can first try to connect your laptop to an AC power source via the ac adapter, if it fails to charge the battery, then it must be your battery died. try a relacement dell inspiron 1420 battery,which usually lasts longer and is compatibale with your dell and costs much less than the original one!
May 09, 2011 | Dell Inspiron 1420 Notebook
Inspiron 1420 dell says plugged in not charging
Check power adapter’s DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Feb 22, 2010 | Dell Inspiron 1420 (dncwja1_1) Intel Core...
Finding bluetooth on dell inspiron 1420 with vista - unable to install driver
try to download the updated driver from supprt.dell.comand update the driver
Jan 16, 2010 | Dell Inspiron 1420 (dncwja1_1) Intel Core...
My dell Inspiron 1420 will not power on. when the power button is pushed the power light comes on for about 3-5 seconds followed by the battery light for about 1 second and thats it. nothing else comes on...
a dell inspiron 1420 is a laptop you have put it under printers
im assuming your talking about a laptop
try charging your laptop or turning it on with the charger still attched to the laptop
if laptop does not turn on with the charger attached then either that the battery is dead and you need a new one or your laptop itself is gone
Dec 30, 2009 | Office Equipment & Supplies
Problem in os
Try starting explorer by going to file\new task (run..) and typing explorer.
If it doesnt work, just type msconfig on the same box and go to startup tab, leaving everything unmarked, just reboot your pc and problem should be solved
Jun 21, 2009 | Dell Inspiron 1420 Laptop
Over heating of my DELL INSPIRON 1420
check processor fan and use extra portable laptop fan.
Jun 01, 2009 | Dell Inspiron 1420 Laptop
The fan could be faulty (ie stopped spinning) or the heatsing vents are clogged with dust.
Remove the fan and check/clean the vents/fan. If the fan is faulty replace it.
Mar 13, 2009 | Dell Inspiron 1420 Laptop
Computers & Internet Logo
82 people viewed this question
David Payne
David Payne
