Question about Kenmore Elite Oasis 27052 Top Load Washer
Th e washing machine fills up but before it starts to spin...stops and reads "f" the door remains locked and you have to un plug it and plug it back in to get it to drain the wayer that fillled but basically the entire cucle shuts down after the water fills
  • 3 Answers
YOU MUST TO TURN OFF IF IT'S NOT YOU MUST CALL A TECHNICIAN
Posted on Apr 11, 2011
Sharp washing machine won't unlock door
I was going to suggest switching t off for a while, allowing the thermal lock to release.
Mar 22, 2014 | Washing Machines
My washing machine wont start. The door lock
You will have to replace the door lock wax motor.
May 21, 2010 | Hotpoint Aquarius WF220 Front Load Washer
Front loading ge washing machine only 2 months old. door locks,
take water lines off of water valve at rear of unit and clean dirt out of screens.
Jun 19, 2009 | GE WSXH208A Front Load Washer
Washer filled with water to began wash; once closed....nothing- wash cycle did not contuine - standing water remains. will not spin or perform any other actions. has stop working entirely
That sounds like a faulty door switch. This can be tested by a technician bridging the door switch contacts. Check also that the door lock is not stuck inside using a pencil or a small screwdriver, be careful not to damage door lock.
If the door lock was not the problem, then check the water level floater , and also ensure that hot water is filling properly, otherwise the thermostat wont detect right temperature and cycle will stop.
More likely you have a problem with the door lock switch.
Apr 10, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Control lock light will not go off.
Do you have any error codes?
Does water remain in the washer after the final spin?
If water remains in the washer after the final spin, then the door will not unlock. Drain/Spin or Spin Only to remove any remaining water from the washer. The door should unlock at the end of the cycle.
Is the door locked and the Add A Garment light on?
If the Add A Garment light is on, then the washer door will unlock after the Pause/Cancel button is pressed once. Pressing the Start button will restart the washer at the same point where it left off in the cycle.
Is the door locked and the Add A Garment light off?
If the Add A Garment light is off, then the washer door will unlock after the Pause/Cancel button is pressed twice. The door will not immediately unlock while the cycle is running due to a possible high-water level in the washer, high-water temperature, tumbling or spinning. It may take up to five minutes for the washer to stop spinning and draining before the door will unlock. You will hear the door click when it unlocks.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Control Lock
No final spin- washer tub rocks back and forth and times out
e47 i believe is a door lock issue, although its locking shut there are multiple switches in the lock mechanism
Feb 22, 2008 | Frigidaire GLTF2940ES Front Load Washer
Front load washer stops and starts and door lock light remains on
You probably have a bad door latch or door interlock. Both, if defective will cause the symptoms you describe. The door must remain closed and lock before a wash cycle will begin, and for it to complete properly.
Jul 10, 2007 | Frigidaire FWTBB30DS Front Load Washer
Wash starts it fills with water then stops and wont wash
problem may just be that drum is not turning so you think program is stopped. try cancelling and select spin program and see if you get spin
Apr 01, 2007 | Hotpoint WMA44 Front Load Washer
Kenmore Elite Oasis 27052 Top Load Washer Logo
29 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
