Question about Car Audio & Video
Where can I gey a harness to fir this radio without having to go to the manufacturer? They don't sell the harness for rhee unit online.
    Master:
  • 149 Answers
Factory alarm for 2001 cabrio, is it part of the radio?
No, it is not part of the radio unit proper. I have been driving my car since it was 3 days old without the factory radio. I could not tell you where the alarm is located, & I would not cut any of the original wires that lead to the radio to the harness, those might have something to do with the alarm, Vw tends to wire things funny
Jul 10, 2014 | 2001 Volkswagen Cabrio
Can I buy a VR500CSBT connecter to female ISO connecter to fit VR500CSBT in my Vauxhall Corsa as I don't want to cut the indvidual wires of the conecter that came with the stereo and join it to an
they sell wiring harnesses that connect to the car manufacturers radio/player harness with wires to connect to after market players, do they sell one for your car? not sure
Mar 10, 2013 | Roadmaster (VR500CSBT)
I bought a JVC KD-R620 and I can't get To power on without having the ignition wire(red) and the battery wire(yellow) connected. And it won't save my settings either..I don't have a blown fuse...
Ok, just so I get this right. You want this unit to power up, without hooking the 2 power wires??? Red is constant power, yellow is switched power. Did you use a wiring harness to hook the radio up or did you hard wire it? I alway recommend a harness. This would make the install easier. If the unit works witht them wired, use it.
Sep 03, 2011 | JVC Car Audio & Video
Can I hook up a pioneer deh-p3500 without a harness?
If you are talking about the radio harness, probably not. If you are talking about the wiring harness to plug it into the vehicle. The answer isn't so simple. Aftermarket radios have standardized wiring colors. BUT, they don't match vehicle wiring. So, unless you know your vehicles wiring diagram very well, I wouldn't recommend installing without the wiring harness. If the problem is that someone installed in your vehicle before this and cut the vehicle side of the harness, then I recommend you visit scosche or PAC website to see if it is available. It CAN be done, the question is SHOULD it be done. And the answer is no. Harnesses are very cheap these days, unless you have a data transfer style radio, then it gets a little costly. Most are around $7-$20. Hope this helps
Aug 22, 2011 | Pioneer Car Audio & Video
How do I get factory amp to work with after market radio with correct wiring harness
hi,
not much can help without seeing all fittings but if you nip to motorworld they have most connectors for aftermarket and they got decent guys who fit the systems they sell,
hope this helps
Mar 13, 2011 | Jetta Radio Wire Harness Wiring Stereo...
VRCD400 SDU I am trying to install this radio in a 2003 Saturn Vue that had a factory am/fm/6disc/cassette radio with the 'advanced' (power amp) audio system. The factory system was stolen. The factory...
I would suggest calling or find online Crutchfield. They have been car stereo experts for many years. They sell harnesses for just about any car allowing you to plug in your stereo directly to the existing harness. I guarantee they will know!
Mar 24, 2010 | Virtual Reality VRCD500-SDU CD Player
Cd player in toyota paseo
Very simple. DIN size head units fit without any adapters (assuming your car has the DIN size factory radio with pocket underneath {I have '93 Paseo and this was the setup of mine, though Crutchfield.com shows option of factory stereo with pocket and without [guessing there was a double DIN size option]}). All you need is a wiring harness. I've seen these anywhere from $5 - $20. This will connect to the wires on the harness for your new radio, then instead of cutting any of the factory wiring, you simply plug the factory harness into this new socket.
The trim ring around the radio/climate control/ashtray area is held in with clips. It just pops out (may have to use a thin screw driver to get your fingers under one of the edges to start). Four screws hold the metal frame where the head unit, climate control, and ashtray are. Take those out and pull the metal frame out a bit, then disconnect the wires of the climate control, power lead to lighter, and stereo harness and antenna. Two screws per side hold the stereo in to the metal frame. Take those out, slide out the factory radio and put in your new head unit (You will not use the metal cage or any other mounting brackets the head unit may come with). The holes on the metal frame should line up with mounting holes on the side of your new radio.
Not to endorse one vendor over another, but Crutchfield.com supplies instruction sheets and any needed install accessories free with purchase of new head unit. Their prices are often slightly higher than you can find elsewhere (comparable to retail stores, usually more than online stores), but you get the wiring harness and instruction sheets for your vehicle. At the very least, you can use their site to see what fits your vehicle (Note: Many other stores do this as well.)
May 31, 2009 | 1993 Toyota Paseo
How to remove factory radio
Removing the radio bezel is easy, which is the plastic surrounding the radio including the heater vents. Slide something thin, or your fingers underneath from the bottom of the bezel and gently pull towards you, carefull not to break any tabs. Once you have one tab out keep working all around the bezel until its off. You will then see the radio and how its mounted. There are 4 screws holding the radio in. Remove and put in the cup holder so you dont lose them. Pull the radio out towards you until you can reach behind and unclip it from the harness. You must also remove the antenna wire from the back of the radio. (before you begin its a good idea to unhook the battery)
To install an Ipod they sell the Ipac-chy, which is a can-bus unit. The unit clips into the radio harness then the other side clips into the car harness. They are around $80. It comes with a patch cable that charges the ipod as well. Look around online for the best price. Metra I believe has one too.
Nov 20, 2008 | 2005 Jeep Grand Cherokee
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
