Question about Sharp Televison & Video
Sharp Aquos LC-52D92U TV won't show picture when turned on using remote. But if you start from an unplugged state, plug it in and start it, it works. The problem is when you turn it off using the remote, and you want to turn it back on again, it will only show you a black screen.
    Top Expert:
  • Sharp Master
  • 74,136 Answers
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Posted on Nov 01, 2015
SOURCE: LC-37D62U Sharp Aquos HDTV Settings
lost sound on Sharp Aquos 37LCD62U
Posted on Jan 25, 2008
  • 208 Answers
SOURCE: Sharp Aquos LC 37D6U
Please be aware that this a big problem on this unit. The insulator material used by sharp to between the IC's on the AV board both on top of the boards and underneath the the AV pcb is failing. This insulator is mounted to the IC and under the metal heat sinc. Remove the back and pull the AV Board out of the unit. Use zylene or alcohol and clean all of the grey insulator from between the pins on the ic and order the replacement insulators from Sharp. Most times this will correct the no sound problem. Sometimes this has also damaged the AV pcb and it will have to be replaced. The parts that should be replaced come in a kit with sharp part # PSPKIT663WHZZ. If the kit is not available the 2 parts needed are PSPAZA663WJKZ AND PRDARA216WJFW.
Posted on Feb 05, 2008
SOURCE: Sharp aquos lcd screen goes blank
i was having these same problems with the screen going black, and i found that when i hit the back of my tv it would work sometimes. so, i improvised on some of the advice on this page and so far no problems. here is what i did (its very easy):
1. lay the tv on the floor and take off the back panel. (i think 12 screws)
2. on the right side of the tv (as you are looking at the back) you will notice a large metal covering that is held in place by 6 screws. unscrew these and remove the metal cover.
3. you will notice that the three screw holes on the left side of the board have some sort of metal or solder around them, in sort of a star pattern. when i looked closely i noticed that most of the metal (solder) was tarnished, or kind of blackened. (this must mean that the ground screws werent getting a good connection and this would explain why it would work sometimes when i hit it because it would vibrate the screws enough to get a good connection! )
so, take a pencil eraser and erase all the black or tarnish off the metal surrounding the screw holes. thats it! (to be safe i took some sandpaper and cleaned up the screw holes on the back of the metal covering, but i dont know if that was necessary)
at this point i followed another gentleman's advice to do a hard reset. this involved unplugging the 8 connections although i dont know if this was really necessary because i believe my problem was a ground issue. i did it just to be safe. his advice is on this site if you want to do this step.
4. i put everything back together and it worked! i performed a soft reset at this point which puts your tv back to factory settings. just go to menu>setup>reset>return to factory settings? yes
this will turn your tv off and back on. that's it. so far so good for me.
Posted on Dec 18, 2008
SOURCE: sharp aquos lc-37d43u tv
Same problem. TV worked night before and then would turn on but no picture or sound. Power and OPC lights blinking. I couldn't change the channel or get to the menu.
I disconnected the coaxial cable and the power for a few minutes and then plugged it back in (electric) but left the cable off. I got a message that it couldn;t get a signal. At that point I was able to change the channels. I plugged the cable line back in and everything worked fine... Good luck!!!
Posted on Jan 01, 2009
gymhasafit
  • 31 Answers
SOURCE: Sharp Aquos LC-46d65U HDMI connect
First off a little tip that manufacturers don't tell you is that you HAVE to TURN OFF the POWER to ANY UNITS that you are Connecting to via HDMI!!!!!!! If not you can short out the Inputs!!!!!!!! HDMI is usually Automatic, But sometimes you need to go into the Menus on all Devices to the HDMI section and write down their settings and compare them. Any definition that you are not sure of check the Manual or Google it! Match all the Settings (there won't be Much!) Hopefully the Inputs were not Damaged it only takes one time to short it out and then the Repairman makes a few bucks! Good Luck!
Posted on Apr 29, 2009
Sharp Aquos LC-52D92U static on display
if your seeing static on a digital tv , your problem is "Not" in the tv its in the signal source (cable box, sat scram,Etc)
digital tvs cant produce "static" displays because they don't receive wide spectrum signals like analog TV's did (carol-ann knows this!) there "filters" are very narrow and specific , this is also why there range is dramatically smaller than analog tvs
also everyone by now knows that tv stations can no longer transmit in analog format (in Usa), G4 cell phones got there band space
Jun 29, 2015 | Sharp Televison & Video
How do I stop the CC on my Sharp Aquos
Sharp Aquos LC-37G4U
Try the remote.
On the remote is a button labeled CC near the bottom.
Press the button to access a menu to switch off. Each time you press the button it will toggle among the choices.
If the tv has problems, try turning it off and unplugging for a few minutes to reset the EPROMs.
Plug in and turn on. Repeat the above.
If you want to change the size/color of the font you can get into menu mode by pressing the menu botton in the center of remote.
Next use the and > arrows to get to OPTION menu.
Use the ^ and v arrows to get to the Caption Setup menu and press Enter.
Feb 22, 2011 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
I have a Sharp LC-46E77UN TV. Remote will start TV green light on. No picture, just stays black. PVR is on and connected to TV via HDMI cable. Cannot turn off green light. Must use power button on TV and...
THe problem is in the set top box. Or common called the tuner box. IT looses the 5 volts to the main display and thus the monitor will go into a shut down state. THESE boxes are factory repair only and must be sent off to repair.
Feb 20, 2011 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
I have a Sharp Aquos LC-32D44U LC TV and I am not able to get a radio shack universal remote turn the TV on and off (or anything else) even though I have tried all the codes, auto set up and manuel set up....
I have the same model that quit working with its remote or any programmable one a found a solution here on FixYa. Turn off the TV and unplug it. Hold the power button on the TV for 10 seconds then plug the TV back in. My remote worked again by doing this.
Dec 31, 2010 | Sharp Aquos LC-45GD4U 45 in. LCD HDTV
My sharp 32" LCD stopped recognizing the remote, b...
I had the same issue with my Sharp Aquos 52 inch LCD TV. I called Sharp. The tech had me unplug my TV, take the batteries out of the remote (TV remote not cable) and press all buttons on the remote (including the buttons under the flip top at the bottom of the remote). I did this, put the batteries back in and plugged in the tv and everything worked. I had gone 4 months having to use the surround sound for volume and turning the TV on and off by hand. This took 2 minutes to fix.
May 20, 2010 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Sharp Aquos wont turn on
this is either a power problem or the screen needs re-gasing
Jan 17, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Tv remote controle codes for starchoice 5-in-1 remote (sharp aquos tv)
you might try unplugging the TV and then plugging in again. It worked for me
Nov 17, 2008 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Televison & Video Logo
167 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
