Question about Dell Inspiron 1525 Notebook
Nesecito la aplicacion msvcrt.d11. - Dell Inspiron 1525 Notebook
    President:
  • 650 Answers
Try to check your disk here is a link to explain using your installation windows disk
If you don't have a disk you can probably find one on the net or borrow one..
Start your computer press F11 start from the cdrom with disk in and press r for repair when prompt
http://technet.microsoft.com/en-us/library/bb491051.aspx
You can also try safe mode command prompt
You can also take the hard drive out and connect it to another computer as a second drive and run that computers command prompt.. Type CHKDSK (Your Drive: ) /F /R... on ..Example mine says CHKDSK D: /F /R press enter type Y for yes and enter don't turn off the computer.. when it is finished type EXIT and put HDD back in the another computer and start it
After run Malware bytes to remove the mal -ware that is freezing the computer...the link Here
If you can get the malware installed and ran in safe mode or connect
the drive to another computer and run it you won't need to chkdsk but checking the disk is good because if fixes bad sectors on the drive also files...Made my hard drive run smoother and makes no noise..
Posted on May 19, 2011
La aplicacion pantech home (proceso com.pantech.home) se a detenido de forma inasperada. y dice vuelva a intentarlo. En la parte de abajo de este aviso, tambien aparece un aviso que dice FORZAR CIERRE. Que...
aplicacion pantech home (proceso com.pantech.home) se a detenido de forma inasperada. y dice vuelva a intentarlo. En la parte de abajo de este aviso, tambien aparece un aviso que dice FORZAR CIERRE . Que se puede hacer para solucionarlo
Jan 28, 2013 | Pantech Crossover
Cpu reading 100%
posiblemente tenes alguna aplicacion mal instalada, te recomiendo desinstalar aplicaciones que no uses y luego limpiar la Pc con Ccleaner o Hijackthis. Slaudos
Jan 16, 2012 | Toyota Corolla Cars & Trucks
EN LA PORTATIL ACER ME LEE EL DISCO SIN PROBLEMA, PERO CUANDO CONECTO EL DISCO USB PORTATIL VERMATI EN MI CPU CORE 2 DUO QUADZ ESTE NO LO LEE
Apreciado endor74,
Tu disco duro externo podria estar averiado o tener la tabla de ficheros corrupta. Por favor descarga la siguiente aplicacion de Seagate para verificar si es por motivos de hardware:
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=SeaTools&vgnextoid=720bd20cacdec010VgnVCM100000dd04090aRCRD
Si no te indica ningun problema de hardware, te recomiendo que utilices la siguiente aplicacion de OnTrack para intentar recuperar los datos todavia accesibles:
http://www.ontrackdatarecovery.co.uk/data-recovery-software/easyrecovery-lite/
Si no aparece ningun dato como accesible y recuperable, entonces solo queda la opcion de formatear el disco de nuevo. Te recomiendo esta guia que puedes seguir paso a paso para formatear el disco:
http://www.ehow.com/how_6026_format-hard-drive.html
Cordialmente,
Eddie Knight
Dec 28, 2010 | Verbatim 500GB USB Desktop 500 GB Hard...
`LA IMPRESORA HP DESKJEST F380 ME MARCA ERROR Y NO ME IMPRIME
Use este enlace y baje la aplicacion.Luego habra la aplicacion.Esta le dara un diagnostico de su problema.
Try using the HP Print Diagnostic Utility in Windows - HP Customer Care (United States - English) .
Si necesutas mas ayuda vuelva.No ovide dar un "thumbs" o algun testimonio de mi solucion,gracias.
Nov 18, 2010 | HP DeskJet F380 All-In-One Printer
Msvcrt.dll or .d11 says this file was not found. I cannot get it to start. Says fatal error - shutting down.
check out this link
http://www.ehow.com/how_6372455_repair-msvcrt_dll-windows-xp.html
Oct 26, 2010 | Dell Inspiron 1525 Notebook
Nesecito saber como abrir la tv sony para cambiar
QUITALE DOS TORNILLOS GRANDES QUE TIENE ATRAS PEGADOS A LA ORILLA, UNO AL LADO DERECHO Y OTRO AL LADO IZQUIERDO, LUEGO ALAS HACIA EL FRENTE LA TAPA FRONTAL Y VERAS UN COMPARTIMIENTO DONDE VA LA LAMPARA, LE AFLOJAS ESOS DOS TORNILLOS Y LA SACAS.RECUERDA PONER LA TAPA DE ESE COMPARTIMIENTO LUEGO DE PONER LA NUEVA LAMPARA, SI NO NO FUNCIONARA.Y BUSCA EN EL MANUAL COMO RESETEAR EL TIEMPO DE LA LAMPARA.ESPERO ESTO TE AYUDE.
Jan 29, 2010 | Sony KDF-42WE655 Television
Dell Inspiron 1525 Notebook Logo
67 people viewed this question
Alun Cox
