My trial version has expired so now i cant use teamviewer rite? so whether have to license key for that or i can use expiry one? reply soon
  • 91 Answers
Team viewer has a free version. Uninstall your Teamviewer and install it again. During the installation process select non commercial use so that it will never expire.
Hope this help.
Posted on Apr 11, 2011
Testimonial: "good ans thnx"
  • Faizi Faizighnhg
    Faizi Faizighnhg Feb 25, 2014
    good thaxs yaaar
  • Narayan Rout
    Narayan Rout Aug 04, 2016
    Many Many Thanks...wright
Hey, maybe this is too late, but I did find the solution.
These are instructions for Teamviewer users that have had their Teamviewer trial version expire. This is mostly due to choosing "Commercial" instead of "Personal" when installing.
-special note: the reason this occurs is because the Teamviewer remembers the name and account name on your computer, so the main idea is to change the names to new names.
Steps:
1. Uninstall your Teamviewer:
Go to Start>All Programs>Teamviewer8>Uninstall Teamviewer 8. Follow through with the uninstall application.
2. Change Names on computer:
For Windows XP users:
a. Go to Start>Control Panel>System>Computer Name. Enter a different name in the "Computer Description Box." (your computer may not have a description at all. In this case, just enter in a name that you for sure have never used before.) At the bottom you will see "To rename this computer or join a domain, click Change." Click the "Change" button. Under "Computer name:", enter a different computer name that is no longer than 8 characters. Click "OK." It will prompt you to restart your computer, TAKE CARE TO NOT RESTART YOUR COMPUTER OR YOU WILL HAVE TO RESTART THE PROCESS!
b. Now, go back to Start>Control Panel>User Accounts>Change an Account>Computer Administrator (with name of your account)>Change my name. Change the name to a new name. Click "Change Name." AGAIN, DO NOT RESTART YOUR COMPUTER AT THIS POINT!
c. Disconnect your computer from the internet. (If you already know how to disconnect from the internet then skip the rest of step "c.") Now again go back to Start>Control Panel>System>Hardware>Device Manager Look for the "Network Adapters" tab. Click the "+" sign next to "Network Adapters." You will have to temporarily disable every driver listed under here. So, right click on the driver, click disable. Do this for every driver listed under "Network Adapters." You may now restart your computer.
d. If you haven't restarted your computer yet by this point, restart it.
e. Restinall Teamviewer. During the installation process, SELECT PERSONAL, NOT COMMERCIAL!!!
f. Reconnect to the internet. If you did the driver disabling option, go back into Start>Control Panel>System>Hardware>Device Manager, right click the disabled drivers and enable all of them. Otherwise, just reconnect to the internet.
g. After the installation of teamviewer and reconnecting to the internet, you may now try to use Teamviewer again. You'll know if it was successful if you see a different number under "Your ID." You should now be able to use Teamviewer again.
For Windows Vista, 7, and 8 users:
a. Go to Start>Control Panel>System and Maintenance (may say System Security)>System>Advanced System Settings. Enter a different name in the "Computer Description Box." (your computer may not have a description at all. In this case, just enter in a name that you for sure have never used before.) At the bottom you will see "To rename this computer or change it's domain or workgroup, click Change." Click the "Change" button. Under "Computer name:", enter a different computer name. Click "OK." It will prompt you to restart your computer, TAKE CARE TO NOT RESTART YOUR COMPUTER OR YOU WILL HAVE TO RESTART THE PROCESS!
b. Now, go back to Start>Control Panel>User Accounts and Family Safety>User Accounts>Change your Account Name. Change the name to a new name. Click "Change Name." AGAIN, DO NOT RESTART YOUR COMPUTER AT THIS POINT!
c. Disconnect your computer from the internet. (If you already know how to disconnect from the internet then skip the rest of step "c.") Now again go back to Start>Control Panel>System and Security (Note: If you're viewing the Large icons or Small icons view of Control Panel, you won't see this link. Simply click on Device Manager)>Device Manager. Look for the "Network Adapters" tab. Click the "+" sign next to "Network Adapters." You will have to temporarily disable every driver listed under here. So, right click on the driver, click disable. Do this for every driver listed under "Network Adapters." You may now restart your computer.
e. Reinstall Teamviewer. During the installation process, SELECT PERSONAL, NOT COMMERCIAL!!!
f. Reconnect to the Internet. If you did the driver disabling option, go back into your Device Manager, right click the disabled drivers and enable all of them. Otherwise, just reconnect to the internet.
hope this helps! :)
Posted on Sep 13, 2013
  • 2 more comments
  • Desiree Sep 13, 2013
    hey, maybe this is too late, but I did find the solution.
    Steps:
    hope this helps! :)
  • Dev Patt
    Dev Patt Jul 14, 2014
    Thank It's Work's
  • Khim
    Khim Aug 28, 2015
    Works like Magic. Saved after so many other unnecessary responses on the net. Cheers buddy
  • raja raja
    raja raja Oct 02, 2015
    Deriree..U really rocked...love u..thanks a ton..it worked
Just when the pop-up with the expired trial license comes up, click on "extend" license and when it asks you, enter the e-mail address and then select a new license mode (Personal Use) and confirm that you will only use it in a fair manner.
This will change the license mode on the servers and you don't need to use ugly hacks of any sort.
Posted on Jul 09, 2015
  • kotabalaji
    kotabalaji Aug 13, 2016
    IT doesn't work bro please help me ...
  • kotabalaji
    i don't find an extend option
WOW...!!!! it really works...bro..i tried many ..but it really works...thanks
Posted on May 08, 2014
My IDM trail version was expired i want to use it again i cant able to use another trial version even after uninstall the trail version it shows IDM has not been registered for 30days. Trail period is
There is a hidden file on your PC that tells the software when the trial period has expired. It is difficult to locate and even harder to eliminate. You'll have to buy a license to continue.
Dec 18, 2016 | Computers & Internet
Hi, I had download a trial copy of office project 2010 and it's going to expiry soon. I wander if you could so kind to let me know the product key for it? Thanks alot
Hi Maan,
I understand that you have downloaded the Trial copy of Office Project 2010 and it is going to expire soon. You wanted to make this trial version into genuine version by updating the original product key of genuine version.
Microsoft allows users to use the trial version only for testing purpose.
They do not have option to convert the trial version into genuine version by updating the Original Product key as the complete set of installation files are different.
You need to uninstall this trial version of Office Project 2010.
Reboot the computer and buy the Office project 2010 online or from retail store.
Install this new version.
This is the only option that you can try.
Regards
Chockalingam
Nov 07, 2013 | Computers & Internet
I dont know my product key for my microsoft office, my trial period is already expired
Hi.
Thats life when using trial software - the product key will expire.
You need to by a license/product key - or look here: http://crackzone.net/
Regards
Feb 13, 2011 | Microsoft Office Professional 2007 Full...
My product key had expired!! What im going to do?!
You probably had a "free 30 day trial" version of some software,
and the trial-period has ended.
Follow the on-screen instructions to purchase a license-key for the software. When prompted, enter the license-key to 'un-expire' the software.
Sep 26, 2010 | Computers & Internet
Downloaded trial version of Office Home and Student 2007. Like it. Purchased full license online and rec'd product key along with order confirmaion. Now find only product key for trial version works -...
I had a similar problem in that I first had a trial version, and then after the trial had expires, I bought a newer version. But the expired trial version security would not let the new version run, even though I had uninstalled the old trial version. I finally gave up and switch to OpenOffice, for free, and took back the copy of MS Office I had purchased.
Jun 30, 2010 | Microsoft Office Professional 2007 Full...
I need the product key for the Microsoft office 2007 , it was the trail version and need it to keep working pls.it had important info. in it .
You need to purchase a license key from Microsoft to activate your trial version. If the trial expires, your data will not be lost. You'll just need to move your files to another computer with a licensed copy of Office to view and edit them.
Feb 27, 2010 | Microsoft Office Professional 2007 Full...
My new laptop won't let me access any microsoft applications because it says that the product key is invalid. What do I do
i/we donot support illegal or piracy of software(s)..
howevr, u may try with ur sole responsibility..
http://serials.ws/all/?l=m&pn=6
always use genuine n licensed software....
Nov 05, 2009 | Microsoft Office Professional 2007 Full...
How can i activate kaspersky
Which Version you have of Kasper
Jan 22, 2009 | Dell OptiPlex GX260 PC Desktop
Computers & Internet Logo
32,059 people viewed this question
David Payne
David Payne
