Question about Waterwise 9000 Water Distiller
Our Waterwise works for some time until half of liter has been destilated (cca 15-20 minutes). Then stops. Please help us. What to do?
Waterwise 8800 Water Distiller Troubleshooting
Our distiller has been leaking water out the bottom. We have ordered a new lid for the kettle, got it today and started the pot up. Well, it is still leaking. Do you have any suggestions?
Sep 05, 2012 | Waterwise 9000 Water Distiller
1994 vw golf 1.9 overheating
First question is what constitutes "overheating".
Since the car has been parked for years, the thermostat could be sticking closed.
The cooling system could have air pockets and need to be bled.
The water pump may be corroded inside and not pumping enough volume.
If the gauge goes above half way, the fans should start up. But half way should be more or less normal, not hot yet.
I would look at flow problems first, beginning with removing the thermostat and driving it without one for a few days. Also check and see if there is a process to bleed the cooling system of air.
Jun 24, 2012 | Cars & Trucks
My greetings to all Iam from Saudi Arabia and bought 2005 ford free star sport with 4.2 L and i do not know how to get the manual and how many for oil for changing oil with filtter . thank you
you should change the oil every 4000 to 5000 km in that hot climat your van should take a little more then 4 liters of oil so buy 6 liters oil filter part # should be on the filter you could take it off the old one if your doing this yourself drain oil put new filter in and add 4 liters of oil wait 5 minutes check oil level on dip stick add half liter at a time and check oil level again wait few minutes in between for oil to drop down in oil pan for proper readings on dip stick.repeat ontil oil level shows in the hatch marks on dip stick DONT OVER FILL. also fill oil filter with oil before instaling the new one to insure that oil will flow trought engine at startup without having to fill oil filter first leaving engine to run without oil until this happends internaly on its own you may have a liter left after your done ,you can use this for top ups inbetween oil changes .you should also check and replace your air filter at this time .
Apr 11, 2011 | 2005 Ford Freestar
My waterwise distiller light turns on for a few minutes and then just shuts off.
possible deffect on mother board try to replace then conduct observation of unit.
Feb 24, 2011 | Waterwise 9000 Water Distiller
I have WaterWise 8800 since 2004, and now when I start it up - it keeps shutting itself off. Tried to clean out dust through the slots at top of machine where fan is. Still not work. What's wrong?...
Have you used Kleenwise to remove scale from the boiler? YOu can call Waterwise and they have technicians that can help you. I have had my Waterwise 7000 for many years, and love it! It makes the BEST tasting water, no chemicals or biologicals in it. I keep my machine clean and when I have questions, I call the tech guys for help.
Dec 23, 2010 | Microwave Ovens
99 chevy astro ,lost key replaced steering column. now no start. pass-lock ignition,tried key on position for ten minutes 3 consecutive times, still no start. Got fuel and fire. It actually starts for...
Yes it sounds like a security system problem. Does the new column have pass key? You are leaving the key on until the security light stops flashing? The light is flashing for 10 minutes?
Nov 01, 2010 | Chevrolet Astro Cars & Trucks
Stop beeping freezer after power faiilure? The reset button only lasts half a day?
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Apr 10, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
2002 camry battery changed, dies in idle
Check the manufacture's Cold Cranking Amps (CCA) rating.  Some manufacturers recommend a minimum CCA.  If your CCA is below the manufacturer's specs, it can cause your car to run erratically.  This also can cause problems with your computer and give you faulty DTC's. (Diagnostic Trouble Codes - Service Engine Soon Light)  This especially causes problems with General Motors cars.  I'm always hearing of people with these problems.  Let me know how it works.
Feb 02, 2009 | 2002 Toyota Camry
Waterwise 9000 Water Distiller Logo
Top Waterwise Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Waterwise Kitchen Appliances - Other Expert? Answer questions, earn points and help others
