Question about GE Microwave Ovens
I have a ge jes0736sm1ss microwave oven. when you open and close the door the light comes on only for a second then goes back off. you can punch in a time and the clock will count down and ding when done but no light comes on and it doesnt heat. no sound that it is working
SOURCE: No heating, no clock, no timer, otherwise fine!
One of your door interlock switches is defective . I would suggest having it repaired by a qualified repair tech in your area.
Posted on Oct 04, 2007
  • 579 Answers
SOURCE: panasonic dimension4 genius microwave oven
High voltage parts are suspect. Need to put a voltmeter on the input (primary) side to the high-voltage transformer (big heavy iron thing in there) Should be getting 120Vac when it goes to cook cycle. Don't touch the other (high voltage) side of this transformer. If the power is there, you are looking at replacing high-voltage capacitor and diode. If that doesn't solve it, then it needs a new magnatron. Its affordable if you do it yourself - buy the part on EBAY - lookup "universal magnatron"
Hope ya fix it!
Posted on Jan 31, 2008
  • 109 Answers
SOURCE: Emerson MW8102SS Oven doesn't work
if it's out of warranty it is.
Posted on Apr 03, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Microwave oven runs with door open
This is usually caused by either a bad door switch, a loose door switch mount.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Apr 18, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Microwave oven comes on when
It sounds like either a bad door switch or door switch mount, or a sticking relay on the control panel.
This is usually caused by either a bad door switch, a loose door switch mount, or occasionally a problem on the control panel.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can order Panasonic parts here.
Otherwise, I would recommend that you contact your nearest Panasonic-authorized servicer.
Posted on Aug 19, 2008
GE Profile microwave oven PEB7226SFSS quit warming food but appeared to be on/operate with light on/timer counting down. Installed door switches-now the microwave "works" only when the door is open
Sounds like on reassembly you reversed wires to door switch.
switch might have letters C NO NC (common, normally open, normally closed) one wire goes to C common, the other to NC normally closed. Try reversing the wires.
If you use meter measuring continuity meter on C and NO should be high resistance until you press switch.
meter C to NC measures low resistance until you press switch then measures high or infinity (open)
Sep 28, 2016 | GE Microwave Ovens
How to change nightlight bulb on ge advantium 120 oven
Advantium - Interior Light Operation While Microwaving
The Advantium 240 oven interior (cavity) light will illuminate anytime the door is open. However, due to the dark tint on the oven door, there is not a light on while cooking since the food would not be visible using the interior lamp.
Food may be viewed during a microwave cycle by pressing the Microwave/Oven Light pad.
One of the Upper Level Speedcook lamps will come on for 5 seconds. The Microwave/Oven Light pad can be pressed up to 5 times during a microwave cooking cycle. The limit of 5 times is to prevent excessive heat on microwave cookware from the Speedcook lamp.
The Advantium 120 oven cavity is illuminated anytime the door is opened and while the unit is in the microwave only mode. As a result it will not have the Microwave/Oven Light pad.
Aug 25, 2012 | GE Microwave Ovens
Interior bulb needs to be replaced. What needs to be removed to gain access? Thanks
If the light is not operating properly, you will want to have it checked by an authorized service technician. To obtain in or out of warranty repair on Major Appliances, you may call 1-800-GE-CARES (800-432-2737) or schedule service online.
Check here
http://www.geappliances.com/search/fast/infobase/10000007.htm
Aug 25, 2010 | GE Advantium 120 Convection/Microwave Oven
Whenever I open the door on my GE Spacemaker XL mircowave the internal fan goes on. This is the fan that goes on when the unit is cooking and not the exhaust fan. It goes off as soon as the door is closed...
That is normal for it to spin for about a second or so becuase of switch changeover but should not remain on constantly when door is open. Have it checked up if it does not happen like the way I described it.
May 13, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE microwave won't turn off
Just checked the GE website. Had the same problem with my 5 year old microwave. GE website says to close and open the door quickly three times. First time I did this it didn't work. Second time I closed the door with some significant force and reopened it more quickly. Worked. Unplugged the microwave, plugged it back in, still fine.
Mar 21, 2009 | Microwave Ovens
Microwave seems to turn on when door latch is opened
What's happening is you are activating one door switch a little before the other, and that is causing your light, fan, and turntable to come on. The plastic parts are not perfectly rigid, so they flex a little when you press the button, and that causes the lag to be more apparent. Even if you press the door open faster and look really close, you may notice the light, fan, and turntable coming on for a split second. That's perfectly normal. The relay on the control board must also be turned on before it will actually be cooking.
Feb 22, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave works with door open
If the top is open, the upper door switch should be open and the high voltage section should not be energized. That's the way it's *supposed* to work. But that buzzing is worrysome! Does the turntable turn during this condition? Does the inside light come on? How about the fan? If not, then I would doubt that it's cooking. If so, some models will do this. It's not uncommon to notice that the fan and light will try to come on for a split second when you shut the door. This would not indicate a problem. It has to do with the timing of the door switches and a replay on the board. If it's still under full warranty, it wouldn't hurt to call a GE-authorized servicer.
Nov 07, 2006 | LG LRMM1430 Microwave Oven
Microwave Ovens Logo
119 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
