Question about D-Link DIR-815 Xtreme N Wireless 802.11N Simultaneous Dual Band Router With 4 Port Gigabit Switch
I connected a new D-Link DIR-815 router to my DSL modem (Qwest's Actiontec M1000). Finally got the router to aquire DNS addresses, but Firefox and ping are unable to access www.google.com.
  • Tony Apr 11, 2011
    what si the ip address and dns that your pc is getting?
  • r_goates Apr 29, 2011
    I found a fix. The problem was the DSL modem acts as a router also, so the normal setup for the DIR-815 will not work. I changed the 815's IP address (it was the same local address as the DSL router, by default) and connected the DSL router to a numbered ethernet port on the 815 (instead of the "internet" port) and it worked.
5 Suggested Answers
sandrew
  • 2961 Answers
SOURCE: Cannot connect to internet via Actiontec M1000 (Qwest)
open internet explorer, go to tools, internet options, then the connections tab and make sure ' never dial a connection' is ticked, assuming you had a dial up connection before using the router, other than that you need to check the routers settings, like the password /username for your ISP connection and assuming you originally set it up using an RJ45 lan cable (supplied) before using the wireless.
Posted on Aug 23, 2008
  • 35 Answers
SOURCE: d-link 614+ will not connect with Qwest M1000 modem
Well what everybody really doesnt know is that if Qwest provided you with a modem named Actiontech that modem has the same ip address of router so just change routers ip address to 172.16.0.1 and subnet mask to 255.255.0.0 and the problem should be solved.Im a product specialist for dlink.
Posted on Aug 27, 2008
  • 27 Answers
SOURCE: Use a Qwest Actiontec GT701-WG router with a different ISP?
Yes, if the other isp is also providing dsl services, but you will have to configure the device the other isp will not help you with that.
but its really not that difficult.
Posted on Feb 23, 2009
SOURCE: hello a want to conect my router but dont let me
HI! I bliv u are having some issue setting up ur router.. I will be more than glad to assist u. here are the steps u need to do:
1. press the reset button on the back of the router for 20sec..while pressing the reset button, unplug the power plug and after 2secs while pressing the reset button plug it back in and press for 30secs after that unplug the router for 15secs then plug it back in..once all the lights are solid and ok
2. connect the ethernet cable to port1 of the router and the other end to the lan port of your computer..
3. pull up ur browser then type at the url:192.168.1.1.or 192.168.0.1 or u can check the routers default gateway by right clicking the network icon on the lower right of your task bar and click on status and it will show the ip address of the computer, subnetmask and default gateway, the default gateway is the routers ip address, once u type in to the url, it will ask u the username and password, by default the username is admin and the password is 1234 or just leave it blank
4. it will show the setup page of the router. u can set the router on the specific internet setup that u have.
a. if ur isp is a cable company, normaly u need to do a mac clone on the router setup page by cloning the computer that is reg to the cable company, how to determine it. ex. the computer that is reg to the cable company is a desktop or laptop, if this computer is connected to the modem directly and u can access internet.
b. once u determined it u need to connect this computer directly to the router and do a mac clone and set ur internet settings to auto-dhcp..then save the settings and after that, unplug to the power of the modem and router, plug in 1st the power of the modem then once all lights lit, plug in the router, then once all lights lit, try to pull up a browser that ur computer is connected directly to the router.. ur cable connection shud be, cable from the modem will go to the WAN port of the router and connect ethernet cable on port1 going to the lan port of the computer..once u can access the internet, u can now access again the setup page of the router by typing at the url:192.168.1.1 and u can setup the wireless settings, u need to create a ssid or wireless name and a security..
5. If ur isp is a dsl normaly they give u a username and password to connect to the internet, ur settings on the router should be PPPoe
6. If ur isp gives u a static ip address settings, u need to set the router to isp setup.
a. how to check the isp of the isp given to u..
1. click on start
2. run
3. type cmd
4. it will show a dos prompt
5. from the dos prompt type ipconfig/all
6. it will list the ip address, subnet, default gateway, dns server
this settings should be type in to the settings on the router for static ip addressing..
if you have any query please feel free to get in touch.. good luck
Posted on Sep 02, 2009
Where can I get a quest m1000 mnual for a quest m1000 modem
Here's a link to the quick setup guide:
http://setuprouter.com/router/qwest/m1000/manual-596.pdf
and Centurylink help site:
M1000 Actiontec Modems
Note: Google searching for actual .pdf manual results in links to hacker sites, be careful.
Nov 11, 2014 | Actiontec M1000 Dsl Wifi Modem In Box W/...
I can connect to my wireless internet on my laptop, but then it says there is no internet connection. What do I need to do?
check your ip address and see if your getting both IP and DNS address.
check your router and see if it has a WAN address by going to 192.168.0.1
if not power cycle the cable or dsl modem and then your router and try again.
Mar 06, 2011 | D-Link DIR-615 Wireless Router
I am trying to connect a D-Link DIR-628 router to a Qwest Actiontec GT-701-WG DSL modem. My computer OS is windows XP-service pack 3. The modem works fine when connected directly to the computer and...
Plug your internet into the router then, the router to the computer. Go to your network settings and run the network setup. This will change the settings in windows to except the router into the network. You may have to restart the computer. This should give you internet access to your computer through your router.
Jan 27, 2011 | D-Link Computers & Internet
I have an Actiontec wireless modem from Qwest and I cannot find the SSID
If you haven't changed your SSID, the default SSID is provided on a sticker on the bottom of your Actiontec router. It usually starts with a JR
I’m happy to help further over the phone at https://www.6ya.com/expert/jonathan_828b54f422cbefdd
Nov 10, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
My DIR-655 won't work!
It would be helpful if you could be a bit more specific regarding the way you hooked up the dir 655 to your network and your specifc DSL modem. If the modem you are using is the Actiontec M1000 DSL modem you will not be able to obtain internet access because the DIR 655 is trying to route an already routed IP, the M1000 has a built in router / DHCP that by default is enabled. You can use option 1, access the configuration settings of your M1000 and change the WAN configuration to act as a transparent bridge. After doing so and rebooting the modem you will have to enter your DSL login information like a PPPoE username and password for example into your DIR 655 network settings. With this configuration the modem simply acts as a bridge to relay data directly to the DIR 655 and the 655 itself provides login credentials to obtain internet from your DSL provider as well as hand out IP addresses to the local network. Option 2 is to continue to use the M1000 as a router by default and disable DHCP on your DIR 655 so that it essentially acts as nothing more than a switch or wireless access point while the M1000 hands out local IP addresses. I personally would recommend using the DIR 655 to route IP's as it's got far more configuration utilities than the M1000 does as a router, and really what's the point of getting the 655 if you're only going to use it as a switch or access point when there are other simpler and cheaper devices that could do that for you.
Jul 20, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Weird MN700 hassle...
can you tell modem has the 192.168.2.1 ip just chage into different
Mar 04, 2009 | Microsoft MN-700 Wireless Router (p5308j)
Want to use Dlink DI-514 with Qwest modem to hardwire 2 computers
Believe it or not, Actiontec modems from Qwest are setup as a router already (even though ports are missing from it). You should use a switch instead of another router. Otherwise you will have to configure the DI-514 to act as a switch rather than a router. This is done by assigning a new starting IP address into your DI-514. By default both routers use 192.168.0.1 as the default. You will have to plug the DI-514 seperately into a computer (to take it off the network) and assign a new starting IP address for the DI-514 such as 10.150.1.1 for example. Then you will be able to get it work. I would strongly recommend using a switch instead and turn the wireless on the modem itself (this is why the modem is the router). It will save you some headaches if the power goes out.
Feb 04, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Problem between my Qwest actiontec modem and D-link router
You need to sign into the dlink router and check the status tab, to make sure that the router has picked up the modems IP address. it sound like it hasn't, and is just assigning lan IPs to the client machines, butd oes not have a valid WAN IP to the internet.
If it hasnt got a wan ip, you want to do a hard boot on the router .unplug the router ONLY for 30 sec, and power back up the router only ...not the modem this should allow the router to find the modem IP
Dec 30, 2008 | D-Link DIR-625 (790069292637) Wireless...
D-link 614+ will not connect with Qwest M1000 modem
Aug 27, 2008 | D-Link AirPlus DI-614+ Wireless Router
Ip problem
It is common to have this as the default IP to connect to equipment.
I suggest you unplug your modem while you set up your router. You can also change the default IP for the router while in the settings. be sure to remember the new IP or you will have to do a factory reset to get it back to default
Jul 03, 2008 | D-Link 802.11g Wireless Router WBR-1310...
D-Link DIR-815 Xtreme N Wireless 802.11N Simultaneous Dual Band Router With 4 Port Gigabit Switch Logo
357 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
