Question about McCulloch FG7000MA 7000 Watt 13 HP 389cc Portable Generator
I have a McCulloch FG7000MA generator. I have a throttle problem that it continues to die after starting. Is there a schematic that shows how the spring is connected to the carb throttle?
5 Suggested Answers
SOURCE: McCulloch generator stops after about a minute
Have Generator McCullough FG 6000 was running fine motor still running fine than NO power output, any suggestions ?? Can you get replacement parts and repair diagram off the interent ??
Posted on Jul 12, 2010
  • 1388 Answers
SOURCE: spring on recoil starter broke
Generic version of your starter is most likely available from small engine shop. Look for model and type of engine itself. Briggs stratton, honda, etc. model number if engine is usually on starter cover or stamped on block or tag attached. If the recoil part is riveted to housing you may need to either re-rivet or use screws to attach new rewind. Used parts are also available at small engine shops. Just take in the starter housing only for match-up. Good luck
Posted on Sep 13, 2010
  • 31 Answers
SOURCE: Where can I buy a mcculloch 5700 generator carburator
if you can not find a carburator you may need to find a re-built kit on the internet.
Posted on Aug 28, 2012
i don't have the starter cover i was working on the unit and in emergency i had to go to work for 8 months when i came back the parts were missing
Posted on Oct 24, 2014
Mcculloch generator fg7000ma will not start. changed spark plug still nothing
do you have spark if not first check off on switch if good check coil and flywheel for rust if no rust coil is bad
Sep 12, 2012 | McCulloch 13HP 338 Cc Portable Generator #...
What kind of oil does it take for the McCulloch generator
They usualy have a Briggs & Stratton engine. The manufacturer recommends using SAE 10W40 oil for temps. above 20F (-7C) and SAE 5W30 oil for temps below 20F (-7C) .
Nov 22, 2010 | McCulloch FG7000MA 7000 Watt 13 HP 389cc...
Titan generator Manuals
Can you please provide more information
Oct 05, 2010 | McCulloch FG7000MA 7000 Watt 13 HP 389cc...
How to adjust carby settings after rebuilding. McCulloch Eager Be
Turn both jet needles CW to stops (lightly), then back out each CCW 1-1/2 turns. This is a basic setting that should allow the engine to start and run. Start the engine and allow to warm up, then pull throttle full on. Adjust H needle CW until the engine starts to speed up, but continues to 4-stroke. Proper setting is when the engine 4-strokes unloaded, but immediately 2-strokes when cutting. Release the throttle and adjust L needle CW for better idle, yet allows the engine to 'follow the throttle'. Adjust idle speed screw so that the chain stops turning, but the engine continues to run. Hope this helps!
Aug 01, 2010 | McCulloch Garden
My generator turns on but, supply's no power?
You must check:
  1. Are your breakers ON?
  2. Measure the voltage on generator terminals.
  3. If the voltage is less than 20 V AC, you should check the excitation field, rings and brushes, AVR - rectifier, cables and fuses.
  4. If every thing is OK you may need to recharge the DC field with a short connection of "+" and "-" of a 12 V battery to respective field terminals when the engine is running.
  5. If the AC voltage raises for a second and drops when you disconnect the battery - the excitation circuit is bad.
Jul 13, 2010 | McCulloch FG7000MA 7000 Watt 13 HP 389cc...
Mcculloch generator 5700W 11 hp
Sounds like your choke is not closed correctly when you first start the genset. Remove the air filter and look at the throttle plate. It should be closed with a hair line gap. With your finger you should feel very little play on the throttle plate. As you open the choke, you should be able to open it all the way once the engine has reached a hotter temperature. If the engine is still cold and your opening the choke all the way, it will try to die out.
Feb 09, 2009 | McCulloch 13HP 338 Cc Portable Generator #...
McCulloch FG7000MA 7000 Watt 13 HP 389cc Portable Generator Logo
Top McCulloch Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Are you a McCulloch Electrical Supply Expert? Answer questions, earn points and help others
