Question about Hoover Washing Machines
My hoover 750 LD top loading washing machine is extremely noisy when on spin cycle. How can I fix this? I have checked the balance of the machine and that is fine. Could it be belts or bearings perhaps...
  • flowerwareho Apr 15, 2011
    Thanks for the solution. Is there any instructions available on how to replace the bearings and belts i.e. how do I get to the bearings.
    Thanks
  • flowerwareho Apr 19, 2011
    Thanks for your solution. How do I remove the drum to replace the bearings? Is there a service manual available online to assist me?
    Thanks
    Brigadier General:
  • 3,917 Answers
Hi
In first instance it is likely to be the bearings, and most bearings are common sizes, so they can be replaced. But between the bearing and the drum will be a water seal, and if the bearings are worn, that is likely to be damaged too. So assume that you if you dismantle you will need to replace that too (if you don't, and it is worn, it will let hot soapy water wash the lubricant from your nice new bearings, and they won't last very long).
It is just possible that the bearings aren't yet badly damaged but are running short of lubrication. You can try laying the machine on its face and dribbling oil on the bearing, giving it time to drip through and on to
the inner bearing as well. If it works, then you are really lucky - but it is cheap and easy, so worth a try.
However here are several factors that cause a washing machine to make noise in spin cycle. Please check the following.
If a washing machine is rumbling, and noisy on spin, the main suspect is the drum bearings. Drum bearing failure is common on washing machines due to water getting into them if the drum bearing seal fails. To check for drum bearing failure you can take the belt off and spin the drum by hand. If the drum rumbles when spun then the bearings have probably gone.
Another drum bearing failure symptom is excessive up and down play in the drum which can be checked for by lifting the drum up and down from the drum lip behind the door seal. A further symptom of drum bearing failure is a brown rust patch underneath the washing machine and down the back of the outer drum, underneath the drum pulley (where the belt goes) There are usually two small holes at the back of the drum bearings where water that has got past the drum bearing seal trickles out, and it's usually stained with grease and rust.
Other causes of a noisy washing machine are coins and other obstructions inside the water pump. This will cause noise when the washing machine is emptying the water. Coins or other obstructions can get trapped between the outer tub and the inner drum. This would produce a lot of noise on spin as they coins get tossed around inside. Usually, spinning the drum by hand will not reproduce the noise in the case of coins as the coins drop to the bottom of the tub when the washing machine isn't spinning.
A light scraping noise when the drum is turned by hand is usually a bra wire trapped between the tub and drum.
A high pitched squealing or harsh noise can be motor bearing wear. This can also be checked for by taking the belt off and running the motor alone.
A knocking noise can be a loose tub weight. This would be worse with heavy loads and would not be present on spin with no washing in. This is because the knocking noise is caused when the tub (or outer drum) shakes about on spin. Without washing inside the drum the tub doesn't move. Another symptom of a loose tub weight is grey concrete dust under the washing machine.
Also check this link to get a detailed idea:-
http://www.ehow.com/how_2085860_stop-washing-machine-noise.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Apr 12, 2011
Noisy when in spin cycle
This could be the drum baring and probably will need professional engineer to do it.
Jun 01, 2017 | Kenmore 24032\24036 Top Load Washer
Hoover premier 710 washing machine out of balance
WHAT IS WRONG WITH YOUR WASHING MACHINE?
small_11_21.jpg For a detailed Washing Machine illustration, click below.
redarrow.gif Top Load Maytag Style
redarrow.gif Top Load Whirlpool Style
redarrow.gif Top Load GE Style
redarrow.gif Front Load Maytag Style
redarrow.gif Front Load Frigidaire/GE/Kenmore Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Some problems that can occur with your top-loading washing machine are:
There's an error code on the digital display
It doesn't work at all
It won't drain
It doesn't spin
It doesn't agitate
It's noisy
It leaks
It's off balance
There's no hot water
There's no cold water
It's slow to fill
There's no water at all
The clothes are wet after spinning
The cycle doesn't advance
There's no delicate or regular spin or agitate
It's overfilling
It's underfilling
The water temperature is incorrect
Jul 24, 2008 | Washing Machines
During the spin cycle the washing machine becomes VERY noisy, sounds like its off-balance, but happens EVERY time, even with very small loads. The whole unit doesn't move when it happens, just extremely...
During the spin cycle the drum moves at a higher RPM and so the counter weight of the clothes within can make the drum rotate eccentric or out of sync.
So check if the belt is loose on the motor, checck if the spindle is tight with friction or the drum assembly suspension is out of alignment.
You must check the reason with the following points to confirm the drum spinning making noise. check point of noise , is this on hitting the sides , or from the motor, any foreign objects or the drum spindle. But you are the judge with a first view. Use good lighting to look out and confirm the fault.
Sep 16, 2010 | Frigidaire FEX831CS Top Load Stacked...
Very noisy during spin cycle
The drum balance ring cound be unliquified. Turn it when it is off. There should be sloshing. If there isn't, call in a repair man. He will try to fix it.
Jun 13, 2010 | Maytag Neptune MAH5500B Front Load Washer
Nextra is shaking itself to bits and extremely
sounds like the bearing has gone possibly taken out the drum support to shaking could also be one of the wieghts has worked loose.
Mar 15, 2010 | Hoover Nextra HNF 3157 Front Load Washer
Very noisy on spin cycle, not out of balance
Hi, check leveling of machine, machine should be proper leveled on all side, use spirit level to adjust legs, there should be no rocking motion, in any direction after leveling, put hands on top of machine and try to rock it sids to side, there should be no movements, also check for overloading, be careful when washing things like bath towels, etc, they absorb lots of water, eg. one regular bath towel are equivalent, to six pants, six tops. or possible springs or bushings broken, you need open machine and check.
Aug 02, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Ariston Margarita 2000 NOISY spin cycle....
Remove drum drive belt, and spin drum by hand, if there is any resistance,. or it feels rough or noisy, the the main bearigs have probably failed.
If it is o/k then check motor for worn or noisy bearings,
Please rate my solution.
Thanks.
Jul 24, 2009 | Ariston Technologies Ariston AWD12 Front...
Hoover750l
Please help
My Hoover 750 L Top Loader leaves a lot of fluff when I wash my dark clothes. I have been looking for a filter on it but no success. Any one have an answer please.
Sep 07, 2007 | Hoover Nextra HNF 3167 Top Load Washer
My old Hoover top loader Washer is noisy & doesn't spin out properly - how can I fix it?
Sounds like the switch which cuts the machine off when the load is unbalanced. My guess is that: This switch is being triggered too easily The springs holding the bowl up are either stretched or one is broken; The machine may not be level.
Mar 30, 2007 | Hoover HTC243 Top Load Washer
Washing Machines Logo
648 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Johnny Ramirez
Johnny Ramirez
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
