Connected USB (MTP). The Player Cannot be Operated.
clickman
  • 93 Answers
SOURCE: MTP Connected but not Accessible
It is simple. Forget the MTP Mode. Simply put the player on, put it on hold, press and hold the record button while you plug in the cord. It will go into USB mode, the only thing is that you have to do that everytime. Hope this works.
Posted on Aug 02, 2008
SOURCE: Switch from MTP to USB
I had this same problem and was able to solve it. Just go into Control Panel (make sure it's in Classic View)-> System -> Hardware -> Device Manager, right click the GPX icon under Protable Devices and then click unistall. Then disconnect and reconnect the player. Windows will automatically install the drivers and that's it, you can now go into USB mode again. Hope it helps.
Posted on Feb 22, 2008
NOT CONNECTED MP3 PLAYER
Posted on Apr 15, 2008
SOURCE: Player does not connect using MTP USB mode
when i plug the player to the computer USB port , the player either keeps disconnecting and connecting over and over again spontaneously, or it shows up on the player' s screen as connected but the computer does not detect it.how do i fix this problem
Posted on Dec 09, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: player does not connect using MTP USB mode
Uninstall the MTP device in device manager to prevent the annoying problem of continuous pop-ups.
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Dec 17, 2008
My Sansa e280 is not downloading my playlists from Windows Media. I have tried dragging and dropping the playlists from my computer music folder to the Sansa folder and it still will not write to the mp3...
The Sansa e280 can be operated in 2 ways of USB connection modes: MSC or MTP.
In MSC mode, viewing the player as a removable disk, the "copy
and paste" or "drag and drop" method will work.
In MSC mode always through the "safely remove hardware" icon, click to remove the player's disk before taking out the USB cable.
In MTP mode, operating the player in software like Windows Media Player: under Library or Sync,
first create a playlist
next sync the playlist.
In MTP mode, follow up the warning or text in the software that gives permission when to disconnect the player.
Apr 11, 2010 | SanDisk Sansa E280 MP3 Player
How do you take music off your mp3 player
The Sansa c140 can be operated in MSC and MTP mode for transferring and deleting music files.
See also setting USB mode for autodetect or MSC mode on page 16 of the manual: link to the Sansa c100 series manual.
  • For deleting files a connection to a computer has to be made in either MSC or MTP mode, see page 10 of the manual.
MSC mode means that a computer will see the player as a removable disk when connected.
It's like exploring the computer detecting the player as an external memory, showing up as a drive letter with about 1 GB of memory.
Before disconnecting the player, always safely remove hardware, the icon in the bottom taskbar on the right.
MTP mode means that a computer has software installed like Windows Media Player 10 and in this software, when started, the player is being recognized as Sansa c140.
Before disconnecting the player, wait for the message that it is allowed to disconnect the device.
How to use Windows Media Player 10 ? See the site of Microsoft:
http://www.microsoft.com/windows/windowsmedia/player/10/using.aspx
Need more help ? Just post a comment.
Dec 27, 2009 | SanDisk Sansa c140 MP3 Player
Need to mp3 out of mtp mode and into usb mode need help
in the manual it says Turn on the MP3 Player by holding the PLAY/PAUSE button. 2. Take the USB Cord and plug the corresponding ends into the MP3 Player and a Computer. 3. When connected the LCD Display will either say “USB” or “MTP”. 4. Press the “M” (mode) button to switch between “USB” and “MTP” mode. “MTP” mode will only work, when your player is connected to Microsoft® Windows® XP and Windows® Media Player 10. The MP3 Player will only work in “USB” mode when it is connected to Windows® 98SE, ME, or 2000 Professional. 5 is this helpful.Take your time sometimes these things don't work because you've missed out one step so go slow and try it two or three times before you give up
Aug 29, 2009 | GPX MW3837 MP3 Player
When i put music on my mp3 player it says error
You can switch your player between USB and MTP mode only if your player is connected to Windows XP machine and Windows Media Player 10. When the player is connected to your Windows XP machine, pressing the M button on your player will switch your player between USB and MTP mode.
Dec 04, 2008 | GPX MW3836 MP3 Player
Problem with mp3
-Tha Mp3 Doctor
Sep 18, 2008 | GPX MW3836 MP3 Player
Will not show songs
This player has a USB and an MTP mode- the most annoying fetaure ever invented on mp3 players.
-Tha Mp3 Doctor
Aug 26, 2008 | GPX MW3836 MP3 Player
Jun 30, 2008 | Samsung Yepp YH-J70 Digital Media Player
MTP Connected
Mar 03, 2008 | RCA S1000 MP3 Player
Jan 20, 2008 | GPX MW3837 MP3 Player
1,251 people viewed this question
 Grubhead
Grubhead
