Question about Belkin Bluetooth f8t041-b Mouse
I have a belkin bluetooth comfort mouse, it was working fine with windows vista, but recently i upgraded to windows 7...it is not getting connected
  • 69 Answers
Try installing bluetooth drivers
Posted on Apr 11, 2011
Magnifier not showing real time
Windows Vista and Windows 7 may need updated drivers made for these windows version.for your device to be able to work properly. Sometime the manufacture for older device will not make drivers for the newer windows.
They want to sell newer product instead of updating the older mouse.driver.
Go to the manufacture web site of you mouse if there is an updated version for your mouse for Vista.
Mar 23, 2012 | Microsoft Wireless Laser Mouse 6000 v2.0
COMPUTER KVM
the belkin needs a driver for win 7
Nov 22, 2011 | Belkin Computers & Internet
I am Looking for Sony VGP-BMS77 VAIO Rechargeable Bluetooth Wireless Laser Mouse drivers but i can only find the vista one and it is telling me that it will only work with vista and I need to work on...
Windows 7 and Windows Vista were built off of almost the same code. Try using the windows vista drivers anyway. If it doesn't work, you can always uninstall them.
Jun 15, 2011 | Sony VGP-BMS77 VAIO Rechargeable Bluetooth...
Belkin f8t003 will not work windows 7
You were probably using it on an XP or Vista PC. You will need to go to www.belkin.com and download the Windows 7 wireless adapter driver. Go to belkin, support and drivers, put the F8T003 model number in, put Win7 as your operating system, download the driver and double-click on it to install it. Then insert your Bluetooth Wireless adapter in and it should work just fine.
Oct 18, 2010 | Belkin F8T003 Bluetooth (F8T003V) Wireless...
Belkin F4U017 7 port USB hub Connected to a Windows Vista 64bit computer Windows updates are automatic When plugged into the computer, Device manager reports the hub as a "Bluetooth Radios: Broadcom...
I just had the same problem and was able to figure our a permanent fix.Judging by the date of you post, I'm guessing you've already remedied this problem one way or another. But just in case you haven't or someone else is having the same problem, I'll go ahead and post what to do. First, make sure you leave the USB hub plugged in right now so that Device Manager lists what it thinks is the Bluetooth device. Go into Control Manager > Hardware & Sound > Device Manager. Right click on Bluetooth device that is showing up in error. From the dropdown box, select Properties. Click the Driver Tab. Click Uninstall. Check "Delete the driver software for this device." Click OK. Unplug your USB hub for a few seconds, then plug it back in. Windows should now recognize it as a "Generic USB hub." You should be good to go. Just remember not to install that update again or try to update the driver for the Generic USB hub. If you do, you'll end up with the same problem. I hope this helps someone out there.
Sep 24, 2010 | Belkin (F5U237) 7-Port USB Hub
Belkin bluetooth mouse unable to work with windows 7
try installing the driver for mouse in a compatibility mode....
rightclick on driver file >properties >select compatibility tab > check mark in the checkbox "run this program compatible for" and select windows xp....
guess it ll work fine....
good day....
Mar 03, 2010 | Belkin Bluetooth f8t041-b Mouse
Belkin N+N storage router doesn't work wirelessly
Hi, I had something like that with my Belkin Router N+N with USB F6D6230-4 V1, only I had a configuration wit a wired XP pc, Wireless XP and Wireless Vista. With both XP pc’s it was really plug and play, but with the Vista pc I had some problems to access the on the router connected USB drive. The Vista pc was connected to the network, and had Inet access. Other shared (network) drives were accessible on the Vista pc.
The first thing I tried was if I could access the drive trough its IP address, (\\routerIP in my case \\192.168.2.1), and I did get a question for a username and password. The only thing is that I tried all the regular names like Admin, Administrator, and so on, with my password but I did not get access.
On the internet there was no help to find for this model router on the Belkin websites (diverent country’s), the data on the Belkin websites is out of date, there is no support to find for new models. ………. So finely I did took the phone and did call the support desk…
Solution to my problem:
The problem seems to be in the Belkin storage manager program, that program works not correct under Vista. When I enter the routers IP and use the username “guest” without a password, it get access to it from my Vista pc. The follow thing I did was press the right mouse button on the drive, and press on “make connection” So..
\\RouterIP
Username : guest
Password : none
Hope, that this is also the solution to your problem.
Greatings
Martin,
The Netherlands.
Feb 23, 2010 | Computers & Internet
I have a Belkin F5D9630 wireless router and presently use a windows vista laptop without problem. I now want to connect another laptop running windows 7. I can "see" this new PC is connected to the router...
since one of the computer is going w/l, that means router should be working fine. the computer that is not connecting might have some w/l settings that neds to be changed
Jan 16, 2010 | Belkin F5D9630-4A Wireless Router
How can I get an upgrade for my wireless mouse?
If your mouse manufacturer does not supply a driver for Vista you are pretty much out of luck for now. Vista is radically different from previous Windows operating systems and some hardware manufacturers are having a hard time adapting to it. If you have to have the mouse I would suggest you switch back to Windows XP till working drivers are released.
Feb 26, 2007 | Belkin F8E825 USB Mini Wireless Optical...
Belkin Bluetooth f8t041-b Mouse Logo
448 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
