Question about Magnum 257 CB Radio
Not laoud - Magnum 257 CB Radio
    Novelist:
  • Magnum Expert
  • 500 Answers
Have it tuned. Properly. Do not let anyone cut or clip anything inside. To makeit loud. Like others. They are using amplifiers.
Posted on May 16, 2011
HI WHAT CAN I DO MY SONY LAPTOP K27 IS VERY LAOUD AND RUN HOT
Take some screws out (document where they came from very easily lost) open the case around fan and use a can of compressed air and blow it out.
Nov 02, 2010 | Sony VAIO PCG-K27 Notebook
My galaxy dx 88 hl makes a laoud noise when you key up and the frequency counter it's off. Channel 19 is on channel 18.
my galaxy 88 cb makes a popping noise through the speaker when I key up how do I solve this problem?
Jul 15, 2010 | Galaxy Radios DX- 88HL Base CB Radio
I have a frigidaire affiniy front load washer. After I washed a lightweight blanket i heard a laoud noise from the machine and water was below the drum not behind from the hose. The next time I used it...
check these:
  • Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
  • Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
  • Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
  • Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further detail
Sep 18, 2009 | Washing Machines
Laoud ticking
yes it is a lifter or a rocker arm, add a can of a chemical called Berryman's chemtool, drive it for a day or so and drain the oil, if that doesn't cure the noise u are going to have to replace the lifter, rocker as nessararyt,
Feb 11, 2009 | 1992 Jeep Cherokee Briarwood
Buzzing noize
Have you tried using a different power adaptor? I have noticed with mine that the as the original failed there was a noticeable hum, a new power supply (of reasonable quality) solved the problem.
Feb 15, 2007 | ElectroVoice RE-1 UHF Wireless Handheld...
Radio Communications Logo
27 people viewed this question
Top Magnum Radio Communications Experts
AnyMHz.com
AnyMHz.com
John Porter
Are you a Magnum Radio Communication Expert? Answer questions, earn points and help others
