Question about HEWLETT-PACKARD Hewlett Packard HP Ocean Drive 101 Mini 2102081NR Netbook PC with Intel Atom N455 Processor Windows 7 Starter (885631853054)
What is the average battery life of the hp mini 2102081NR? i see that it is 6-cell, but i dont not understand the equivalency of cell and battery life.
  • 464 Answers
When you use a six cell Li- ion battery the laptop works in battery mode without any problem for 1.30- 3 hours depending on the profile you are in.(example power saver or balanced or high performance). the battery should be working fine for at least a year without any problem in this way.
say, you have a 9 cell battery the it works in the battery mode for more than 4 hours. i have experienced this lively in my previous hp laptop.
Posted on Apr 11, 2011
Thin green lines on the side of a netbook?
There should be about 6 and when you push the little button by them it glows green and it shows the battery life.
Oct 04, 2013 | HP Mini 1000 Netbook
Tip
Looking for the longest battery life laptop ?
We’ve yet to see a Windows laptop with battery life longer than 5~7 hours, unless we add an extended battery to the system. But when hpand dell launched its new series of laptops last week, one big push wasfor longer battery life.
When you purchase your notebook, charge the battery to 100 percent,discharge it completely, and then fully charge it to 100 percent againto help the battery remember exactly how much electrical charge it canhold. From then on, you’ll never need to completely discharge the laptop battery again, but always make sure when charging it that you let it reach 100 percent. DeHoop told us to “remember to plug in the laptop AC adapter(or dock/port replicator) whenever you get a chance. Most notebookswill recharge quickly.” Salinas had another tip for your batteries:“Keep them cool. Exposure to high temperatures can be a battery’s worstenemy,” he said
Hope the list can give you some help when you purchase a laptop or battery:
Top 5 long battery life for laptop
HP/Compaq Business NoteBook 6715B Battery 6 cells 4400mAh Description:
Type: Li-ion, 6 cells
Voltage: 10.8V
Capacity: 4400mAh
UL certificated cells inside!
Original HP Pavilion dv8000 Battery 8 cells 4400mAh Description:
Voltage: 14.4V
Capacity: 4400mAh
Type: Li-ion, 8 cells
Color: Dark Grey
Dimension:205.40 x 69.80 x 20.90 mm
Status: New and original.
Packing: Plain Box
Dell Inspiron 6000 Battery 9 cells 6600MAH Description:
Type: Li-ion, 9 cells
Voltage: 11.1V
Capacity: 6600mAh
Color: Black
HP/Compaq Pavilion DV6000 Battery 12-cells 8800MAH Description:
Cell Type: Li-ion, 12-cells
Voltage: 10.8V
Capacity: 8800MAH
Dell Inspiron 6400 Battery 9 cells 6600MAH Description:
Voltage: 11.1V
Capacity: 6600mAh
Color: Black
on Feb 24, 2010 | Computers & Internet
Replace cimos battery
Disconnect the power.
Use an ESD wrist strap, and connect it's alligator clip to a good ground source. Average price is $3 to $6.
Average example,
http://www.radioshack.com/product/index.jsp?productId=2103245
(It's like a laptop, Not a regular desktop computer.
You CANNOT touch the metal frame to relieve Static )
Here is the Product End-Of-Life Disassembly Instructions,
http://www.hp.com/hpinfo/globalcitizenship/environment/productdata/disassemblydesktop-pc.html
Scroll all the way down the page to the third file from the bottom.
HP Touchsmart IQ804/IQ810/IQ820 Series (02/2010)
Click on it for a PDF file.
Regards,
joecoolvette
Oct 22, 2012 | HEWLETT-PACKARD TouchSmart IQ826t PC -...
MY HP LaserJet 2840 has a brand new Toner cartridge. Now it won't print at all and we are getting a "OPC at end of life" prompt. What does this mean?
Imaging drum reach 20,000 (black only) or 5,000 (color), replace the image drum.
Supplies life
The life of the imaging drum depends on the number of black-only or color pages that print jobs
require. Imaging-drum life is also affected each time the device calibrates because calibrating causes the imaging drum to rotate. Imaging-drum life is measured in terms of number of rotations rather than number of pages printed.
The type and length of print jobs also affects drum life. A series of short print jobs uses more drum
life than an equivalent number of pages printed in a single large job. To extend drum life, print
multiple copies of a print job at one time rather than sending the same job to the device multiple times.
The life of a print cartridge depends on the amount of toner that print jobs require. When printing text at 5% coverage, black print cartridges last an average of 5,000 pages and cyan, magenta, and
yellow print cartridges last an average of 2,000 pages. High-capacity cyan, magenta, and yellow print cartridges last an average of 4,000 pages. (A typical business letter has 5% coverage.)
Aug 18, 2011 | HP LaserJet 2840 Printer
I wonder what is the model of the battery using on HP 10b
HP 10b Calculator requires two CR2032 Lithium batteries. The battery is 3 Volts, 3/4" in diameter and has an estimated life of three years. Replace the battery with CR2032 or an equivalent one.The following brands are used interchangeably for this item: Energizer (ECR2032), Duracell, Panasonic, Eveready, and 3M etc, which can be purchased from any local electronics store.
For further information you may refe to HP 10b Manual
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Feb 27, 2011 | HP 10b Calculator
My battery on my JVC Mobile Mini Note PC/MP-XV841 has not been charging when I plug into an electrical outlet.
How long have you had the battery?
The average life of a battery if charged everytime the laptop is used can be as low as 12 months.
Try a replacement battery if this one is exhausted.
Jan 25, 2011 | JVC Mobile Mini Note PC MP-XP3210 PC...
Where do I get a replaement for asus li-on battery pack BA-DI-LMAI, philippines?
A coin-cell battery (CR2032) usually powers the real-time clock and CMOS memory. The battery is 3 Volts, 3/4" in diameter and has an estimated life of three years. When the computer is plugged in, the standby current from the power supply extends the life of the battery.
GoodLuck!
CreativeTECH
Dec 22, 2010 | ASUS Computers & Internet
What is the correct battery replacement for a Matsonic MS9158E?
GoodLuck!
CreativeTECH
Dec 07, 2010 | Matsonic MS9158E+ Motherboard
What is the average life time od sony Vaio Model PCG-384L Battery? Where is the best place to buy one?
Hello, The average life time of laptops batteries are usually 2-3 years, a good one before they start failing,they will not be able to last the number of hours they do last before, including your sony VAIO, but i must let you know also that the number of the lithium ion cells the battery is made of matters, for example a 6-1on cell, last more than 3, a 12-ion cell last more than 6 However you can get a replacement battery from any good computer stores nearest to your home. Or you can also order it online or if you have any sony stores around you, you can get it from there. But you can consider getting it online from reputable computer stores online. Regards
Dec 01, 2010 | Sony VAIO Notebook
Battery for HP Compaq nx7400
The difference is battery life. So just buy whichever you can afford.
Jan 14, 2009 | HP Compaq nx7400 Notebook
HEWLETT-PACKARD Hewlett Packard HP Ocean Drive 101 Mini 2102081NR Netbook PC with Intel Atom N455 Processor Windows 7 Starter (885631853054) Logo
50 people viewed this question
Top HEWLETT-PACKARD Computers & Internet Experts
Bilal Ahmed Qureshi
Michael Vincent Cruz
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
