Question about Toshiba Satellite P205-S6287 Notebook PC
2 SATA Drives will not burn DVD-R but will burn DVD+R
I just had a computer built with three LiteON DVD writers, two iHAS120 SATA drives and one DH-20A4P-08 IDE drive. The IDE drive works as it should. The SATA drives will not burn to a DVD-R format. I have tried several brand disk. I have updated the firmware. On line chats with LiteOn Tech support have not produced a solution.
  • shagdancer Aug 07, 2008
    AMD Athlon 64 X2 5000+ Black Edition Processor ADO5000DSWOF - 2.60GHz, 1MB Cache, 1000MHz (2000 MT/s) FSB, Brisbane, Dual-Core, Retail, Socket AM2 (940), Processor and XFX GeForce 8200 MCP Socekt AM2+ Motherboard. 3 Gig Ram, 1 500G SATA harddrive and one 80G SATA harddrive
    Champion:
  • 208 Answers
I had once a problem with slow burning then data was corrupt. it turned otu to be a bug in xp and sata/ ide relation to eachother.
i had to unplug all devices except hd to boot. saw no drives. and rebooted 1 drive added at a time and it saw the dvdr properly and burned. its a longshot but maybe you got an ide hd ? or raid is enabled ?
thsi is a strange problem. try 1 drive at a time
Posted on Aug 20, 2008
    Scholar:
  • 46 Answers
Well, for one thing, your system is faster then mine. AMD Athlon X2 4000+ 2.10 GHz, 2GB, BIOSTAR A770 A2+ 160GB SATA. Anyway, what sata port did you install these DVD-Burners to. I know it shouldn't matter, but humor me for a minute. I have mine on the last two normally. Seems to work fine. Try it and see.
Let me know
comier957
Posted on Aug 10, 2008
I have sata dvd writer.when i connect it my computer does not boot.does intel D102ggc2 supports sata dvd writer?
You're Intel motherboard does support up to 4 SATA hard disk drives including SATA CD-ROM / DVD-ROM drive, reader/writers. This MB also includes two serial ATA IDE ports.
The most likely reason you're system is not booting is because all SATA ports are all seen as Master drives. By connecting the SATA DVD-ROM drive the bios auto configured the SATA ports.
You'll need to enter the bios when you're system boots-up. Press the F2 key on you're keyboard right after hearing a single beep. You will than enter the bios main menu. Listed at the main menu are devices connect to the motherboard. (Instruction on how to move around in the bios is listed at the bottom of the screen). Mainly, the hard disk drive or (drives) and the SATA DVD writer. You'll need to open the Boot tab. Look for boot order. You want the boot order set like so;
First boot device: [Floppy disk] drive; if one is connected.
Second Boot device: [Primary Hard Disk] drive.
(The drive with windows installed on it). (This drive may be ATA IDE or SATA; you did not provide that information).
Third Boot device: [DVD-Rom] drive. Save and exit the bios. The system will auto restart.
You're windows operating system should load correctly after the auto re-start.
The SATA data cable and the SATA power cable should be checked for good connection. It only takes a little bump to make either loose.
Here is the link to Intel for you're motherboard;
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=%22+D102GGC2+%22
Mike
May 12, 2010 | Intel D102GGC2 Motherboard
My SATA dvdrw drives are recognized, but don't find media.
try doing a firmwear update..make shure you are using dvd ram drivers...then when all else faild try loasding power dvd.. thats what i did and it werkd..
Feb 18, 2010 | Lite On LITEON 8X DVDRW +/- Burner
Replaced IDE DVD writer with a SATA DVD writer. Powered up XP Pro system, but no drive letter shows up. There is power to the DVD drive, but the OS does not see it. No BIOS updates available from EPoX.
Check your bios settings. If you already have two SATA hard disk drives in your system the bios should also list your SATA DVD writer as third in the list. Make sure the bios list the DVD writer. Remember all SATA drives including SATA DVD drives are all seen as Masters. Check your Boot order settings as well. If windows sill does not list a drive letter for your SATA DVD click, Start/Run and type: diskmgmt.msc in the run window. Assign a drive letter to the drive manually.
Cheers!
Mike
Oct 22, 2009 | EPoX EP-4PDA3I-3 Motherboard
Write error message with liteon dvd writer..
I had the same issue with a liteon DVD drive I had. It worked fine and then one day it couldn't write to a DVD if I paid it to. I troubleshooted it for a few days, installed all the latest updates and patches and still nothing. From what I could tell, it baiscally died. So fortunately Liteons are relatively cheap so I just went out and got another LiteOn and it worked just fine. I would consider purchasing a new Drive.
May 04, 2009 | Lite On LiteOn LH-20A1P - Disk drive -...
CD/DVD Burners for Gateway 835GM PC
Your system has 4 SATA controllers which I mentioned on your previous question. Yes, they will work.
SATA drives are faster than the IDE interface drives.
Here is your motherboard:
The SATA connectors are those 4 approx. 1" vertical black connectors about a 3rd of the way down. The IDE connector is the horizontal one right on top of them.
As long as the SATA controller is set to Automatic in the BIOS, you should not have any problems. Also, the new drive should come with a SATA cable.
Jan 08, 2009 | Gateway 835GM (835GH) PC Desktop
DVD Writers can read but can not write
update their drivers: they're indicating readers, not writer devices..
Mar 25, 2017 | LG GMA-4082N DVD±RW Burner
Sata connection for my dvd drive
Check your BIOS and make sure your SATA is enabled. Also verify that the SATA cable is tight in the back of your drive and on the motherboard itself.
Jun 17, 2008 | Computers & Internet
Liteon DVD writer & re writer
You can not use cable select without the correct cable. Most "stock" cables are not. So...
An IDE port supports -2- drives (CD, HD, DVD, Etc). If you have 2 drive connected on the ribbon cable then one must be set to master and the other to slave (the little jumper clips on the back). If it's the only drive on that cable, set it to master. Some drive may say Master Only and Master with a slave.
Geno
Feb 16, 2008 | Lite On LiteOn LH-20A1P - Disk drive -...
Dvd writter is not working
hey john,
do you have a burning software installed? you can download nero express @ majorgeeks.com
you mention that your friend gave it to you? was it working fine before? its easy to set up your new dvd writer whenever you have already installed a burning software like nero. well, you can also try clone dvd. it works very well too.
and also check for firmware upgrades for your dvd writer...you can find it here...
http://drivers.softpedia.com/get/FIRMWARE/Lite-On/LiteOn-DVD-JLMS-XJHD166S-firmware-101.shtml
hope this hepls
Jan 24, 2008 | Lite On LiteOn 16x Black internal oem DVD...
Won't Recognize Blank Maxell DVD+R Disks that I Try to Burn!
sounds like your loose 4 prong may have shorted the burner drive on a power on- it may just be that simple- it died...
Jan 15, 2008 | Lite On Lite-On LH-20A1L-06 SuperAllwrite...
Toshiba Satellite P205-S6287 Notebook PC Logo
74 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
