Question about Sewing Machines
I have bought a second hand singer blind stitch machine Mod 6SS. But the knee lifter was missing (missing part including K215, K216, K217, K218). Where can I find one?
  • 745 Answers
SOURCE: Blind stitch won't lock
This is hard to find in the internet so I hope this will solve your problem...
Frequently Asked Questions
Q) Help!
I am breaking a lot of needles and the tension is getting too tight on its own while stitching and causing the thread to break. I am learning the machine for two weeks. Is it so sensitive too wools, cottons, and fleece that this would make such a major difference in the stitching - breaking needles, breaking thread?
(A) It may not be tension that is causing the problem with your portable blindstitch. If you have broken needles it has probably left some needle burrs in the thread and needle path that need polishing off with fine emory cloth (crocus) before sewing again.
Start with a new LWx6T needle without thread or fabric. Watch the needle as you turn the hand wheel. If there is needle deflection, reduce the penetration dial until there is no needle movement. If there is needle deflection caused by burrs, they must be polished off. Check the looper tip and two arms for any needle burrs and polish off. If there is needle deflection caused by the needle track lifting the needle, lower the track very slightly with the screws on the side of the black metal bracket above the needle.
Finally, Back off on the tension dial and retighten while you are sewing with a light strong thread and light to medium weight fabric, until you get the correct tension without loops. If tension is too tight it will push the thread up so it is not all the way down between the tension discs where it belongs.
(Q) I can't understand how to finish off at the end. It
always unravels. I have read the manual and it seems simple but I
apparently just "don't get it." Any help would be appreciated.
(A) At the end of the blindhem seam, position the needle all the way to the left, then use the knee lift to remove the fabric and jerk on the fabric at the same time. That will tie off the tread and break the thread at the
needle without bending the needle. You can weave the thread tail back into the stitches or cut it off. Before the above procedure, you could also turn the handwheel counterclockwise for a few stitches, then come back to the end of the seam and repeat the first procedure above.
Posted on Nov 17, 2007
SOURCE: Blind Stitch Machine
The machine is skipping stitches. How do I set it to not do that.
Posted on Apr 24, 2008
SOURCE: Singer Ingenuity Mod. 7436
you can download the manual at: http://www.costco.com/images/content/misc/pdf/334599_instructions.pdf. This site is fairly stupid and won't let me cut & paste the URL so copy it carefully.
Posted on Dec 16, 2008
SOURCE: I'm trying to do a blind stitch with the Singer
check needle is correct and in machine correct.
Posted on Jun 29, 2009
tbirdfan1
  • 3051 Answers
SOURCE: need instructions for a 'Singer' Handi Stitch hand
Hello there:
please go to www.singer.com and look for user manual for your model it will be downloadable and printable too ok?
best regards mike
Posted on Aug 17, 2009
Hi What does the symbol for blind hemming look like
The blind stitch would look like a couple of straight stitches and then a :"V" shaped zig-zag that will zag left to catch the very edge of the folded fabric.
here's the manual:
http://homeappliance.manualsonline.com/manuals/mfg/singer/4212.html (pgs 55-56)
May 08, 2017 | Singer Sewing Machines
I have a singer sewing machine model 1 I am wanting to order a blind stitch foot. I don't seem to be able to locate can you help me?
Hm, if you talking of a blind hem foot, this indicates that one came with the Singer One.
1 ONE Singer Sewing
It appears your machine has a snap-on foot capability, so if that is the case, a snap-on blind hem foot should work.
http://www.sewingpartsonline.com/blindhem-foot-singer-006812008.aspx
Apr 01, 2017 | Singer Sewing Machines
How to sew in reverse on the Singer 57820C
The machine will have a lever on it.?
or a knee pad lever that will make it stitch in reverse.
Aug 02, 2014 | Singer Deluxe 57820 Mechanical Sewing...
Knee lift won't engage on my Juki. Ddl-8700industrial straight stitch
tilt machine back and look at the lifter bar. try moving it now without any pressure on it. move ok then problem too much presser ft tension of the lifter plate on the vertical bar under the machine is bent or not high enough or not align with the botton of the part the machine thta connects to the presser ft. the lifter bar connected to the knee lifter can be bent to line up with the bar on the machine. go to the other side of the machine and look in thru the oil pan to see how they match up.
Apr 07, 2014 | Juki DDL-8700 Industrial Straight Stitch...
Does the singer 3116 come with a blind stitch for hemming
Most sewing machines come with a blind hem stitch. It is the one that looks like several small zig-zags then occasionally a large one, or several straight stitches then a large zig-zag. Either will result in an invisible hem.
Some machines have a special foot but it is not necessary, mine does not. There is however a special way of folding the fabric.
See http://welcome.solutions.brother.com/BSC/public/eu/eu_ot/en/faq/faqh/000000/000000/000017/faqh000017_000.html?reg=eu&c=eu_ot&lang=en&prod=hf_rs240250260euk
Or also an instructional video: http://www.ehow.com/video_4407404_machine-sew-blind-hem.html
Hope this straightens things out for you!
Nov 06, 2011 | Singer 3116 Simple
I have a 5417 C, How do I do a Blind Stitch?
You will need a blind stitch foot. I believe that your machine requires a short shank foot. If you already have the foot, you can refer to the Singer sewing book for step by step or go to YouTube for a video of the process (the video uses a different machine but the process is the same) :
http://www.youtube.com/watch?v=jdKe9crSHac
May 09, 2011 | Singer 5417 Mechanical Sewing Machine
What are the settings for a blind hem stitch? I've ordered the foot but can't find the settings. Singer 57815
I downloaded your manual for free at www.singerco.com and I be darned, I see why you are baffled. Call Singer at 1-800-4singer and ask them to tell you. This is a first for me to see in a machine that is not that old, my 45 year old Kenmore has the blind stitch setting. There has to be some answer to this.
Apr 19, 2011 | Singer 57815 Mechanical Sewing Machine
My singer 7470 is skipping stitches on the left hand side ie. if im doing letters it misses the bottom 1/3rd. and other wider patterns misses about 1 in 12 ? i have cleaned bobbin case and it has obviously...
Take the machine in for service by an authorized Singer tech.
Hitting the bobbin case may have knocked the timing off and the shuttle may have to be replaced.
Trying to fix this yourself may lead to more problems and additional expense.
Mar 27, 2010 | SINGER 7470 Sewing Machine
Bought blind hem stitch for a 3116 singer and the needle hits it
I think you may have to make an adjustment on your blind hem foot, it also could be the wrong fit for your machine.
Mar 08, 2009 | Singer 3116 Simple
Looking for a lifter rock lever plate pad for a singer 211g156
Bit confused here, what is the 'make' of the machine and what do you mean by 'pad'
Mar 25, 2008 | Sewing Machines
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
