Question about Philips Televison & Video
I have a (50") 50pl922od/37
  • Philips Master
  • 17,130 Answers
If the TV is still under warranty then you must not take chances in attempting to tamper on the board. But if you are Tech sa-vy and is familiar with the board and components, then an attempt can be tried with caution.
So remove the power and open the rear panel. Now check the main board specially in the power sections , the main driver sections and the pins of transistors /IC's , resistors and capacitors for dry joints.
Use a good soldering iron to touch up all suspected joints. Tap on the board with power connected but with caution to see if there are dry joints and gives an intermittent picture.
if the fault is oriented with heat then try to cool suspected components that seems to RUN AWAY on heat build up .Use a freeze-it spray to confirm .
If none of these works then my recommendation is to seek your privilege warranty and opt for free replacement.
Posted on Apr 11, 2011
We had this tv for less then a year nd all ov a sudden the remote stops wrking for the tv and we dont know whats wong with it we bought new batteries still doesnt work would u be able to help me out
Take out the batteries clean the - + battery connections with some rubbing alchahol,wait like 20 mins. put batteries back,still have the same problems.Tv is under a year old,tv still under warrenty call the tv company for remote warrenty replacement.
Mar 18, 2011 | Televison & Video
I have a new tv fro wal mart and i"ve had it for
Tries unplug,replug it back like about an hour later.The tv now,will resetting itself back to the factory setting.The tv now should work.If not the power LED light indication on the LCD screen panel flashes or take 2 or 3 mins picture to come on.The problems is the tv power supply board,that the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.If tv was bought and it under a year old,call Samsung Corporation for a warrenty repair.
Nov 24, 2010 | Samsung LN-T4665F 46 in. LCD Television
I purchased a (LN32B360F) 32" 720p Series 3 High Definition LCD TV [B717Z] , it won't turn off and it's still under warrenty, Can I get a replacement or do I have to get it repaired
As long as you didn't damage it. Its covered by warrenty. Warrenties cover internal malfunctions. But if you break a button or break the screen, your screwed. On a extended warrenty, A they fix it for free ( well exception of the warrenty price if u bought an extended warrenty). or B they replace it if it can't be fixed. If you got the extended warranty you can take it back to the store you bought it from ( the dealer).
If on the one year manufacture warranty
You will haft to contact the manufacture and find the nearest authorised repair place. Then you will probly haft to take it to that location or mail it in. You will haft to pay some money in some way to get it fixed. But not much like est. $20-50.
Oct 25, 2010 | Samsung Televison & Video
I just bought a sony kdl40ex400, 40" lcd tv and when i first turned it on the picture quality was poor and there are 2 vertical blue bars running down the screen at all times how do i fix this
The tv Tuner signal board is bad,must be replaced.This tv is new,bought it,under a year old?So this tv is still under warrenty.Call Sony for a warrenty repair.
Oct 16, 2010 | Sony KDL40EX400 40 in. HD-Ready TV
Why is my new samsung lcd 32 inch getting on and off again and again it self? and a voice it coming from the back part too.?
Under a year,this tv was bought?Tv still have warrenty,call Samsung for warrenty repair.Not.Tv power on have flashes of pictures,few sec.than dies,have only sound left?Yes.Ur tv have dead 1 or 2 long board call the LCD inverter boards.These 1 or 2 long LCD inverter boards help the LCD screen to have a backlight to produre a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those refurbishes 1 or 2 LCD inverter long boards for the replacement.
Aug 09, 2010 | Samsung LN32A550 32 in. LCD TV
JUST BOUGHT TV NO SIGNAL need help
Reset the tv and the cable box by unplug,replug it an hour later.Ur tv and cable box should reboot it self.The tv signal should return and work again.Not,call ur tv warrenty service for the repair.Tv under a year old,still have warrenty.
Jul 11, 2010 | Vizio VW32L 32 in. LCD HDTV
New mintek flat screen tv won't do anything
Its not the power pack. The problem is with the dvd player which is also where the cable inputs converts through to the tv. if you are lucky enough to find a new internal dvd unit then you are in luck but I have'nt been able to. Your problem is an old isuues at least 2 years old...Sorry no Mintek tech support available.
Mar 31, 2009 | Mintek DTV-373-D 37 in. LCD HDTV
Emerson 37 in LCD Television
the problem can be fixed by replacing the digital main board. if its under warrenty take it in and have it replaced for you.
Sep 25, 2008 | Emerson EWL3706 37 in. LCD Television
Broken screen on a 37 inch hd lcd
That may have been an expensive tantrum - I doubt if it will be repaired as a warranty item and the typical cost of replacement makes it a costly lesson.
I doubt if the LCD panel is priced under $6-700.
Jul 01, 2008 | Olevia LT32HVM 32 in. LCD Television
Samsong 37 " lcd no display only sound
I think it the main logic board!! I have 42 plasma samsung doing the same! change that works!! cost $124~~
Mar 23, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Televison & Video Logo
94 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
