Question about Motorola Mobility E770 Cellular Phone
Microsd cant readf
After i reformat the microsd at my pc. i cant used the memory card in my cellphone. it can read my card but not my files inside the card
    Problem Solver:
  • 10 Answers
Format the card by your phone....
Posted on Aug 07, 2008
My memory card shows msdc write side error
You have problems with your memory card. Save all files you can. If it is a microSD try to reformat it on a computer using a microSD reader. If you can't format it or worse, can't extract files, you are in real troble, means your memory card died.
Oct 20, 2014 | Avanquest Fix-It Utilities 9 Professional...
My nokia n72 memory card has corrupeted how can it be recover now?
Reformat it again, friend... Note: Before you reformat your memory card...try to read the card using a computer to recover all the files inside it...if you cannot open the card...continue reformat and follow the procedure below:
Go to phone menu...find memory card icon in your cellphone...open it...find format...then ok
Just wait a minute to finish the reformatting...
If the memory card did not continue formatting...
Sep 23, 2011 | Nokia Cell Phones
Nokia 7210c memory card was not working
hi,try to my advice you get out your memory card from your cellphone,and try to reformat your cellphone and memory card.but before you reformat your cellphone,you need to back up or save your contacts to sim memory.after that you reformat your cellphone,you reformat also your memory card to computer,i aware you if you reformat your memory card all data or files you save is delete all.nokia reformat manual just dial
Jul 29, 2011 | Cell Phones
I cant format my memory card and my cellphone cant read it to what should i do .
Get a Multimedia card reader for yourself. Plugin in the card reader in computer and insert the SD card in it. Once you see the SD Card in My computer that means your card reader is able to read the SD card that you have inserted. You can right click on the icon and click format. Do a quick format and choose file system as FAT32.
or
You can use SD Card Formatter and can follow their manual. I think that will also work for you. http://www.sdcard.org/consumers/formatter_3/
Jun 21, 2011 | SanDisk 2GB microSD Memory Card
Some of my files have been corrupted. and i want to reformat it but the computer can not read it.
if a memory card can't be read by a computer means that the card is no more.!!!
try to run you system in safe mode and try to format your card it may work !!(if it had virus only not if its repair)
Jun 14, 2011 | SanDisk 2GB microSD Memory Card
The memory card sandisk micro sd not work on my mobile samsung gt-s3353
Previous stored files can't be read. You need to reformat it using your samsung phone in order to be usable.
May 14, 2011 | SanDisk 2GB microSD Memory Card
I cant read my sd card 2gb wen i put my celpon did not see any files of my memory card wat i do this i need your help.
Welcome to Fixya
Since cellphones have limited access in checking the memory card. Try to insert you memory card to a laptop that has acard reader slot and see if you are getting the same thing if you insert it to laptop. In most cases, these files become hidden if the card is infected by a virus. Check the folder of options of the compuer and click show hidden files and folders and click OK. You should be seeing now the files or folders of the card. If it fils are not showing then there might not be no files at all inside the card. Check the properties of the card. If you have the full capacity available on the card then it clearly says that there is no files in your memory card.
Thank you for using Fixya!
Mar 26, 2011 | SanDisk 2GB microSD Memory Card
The pictures are showing they are there when they are...
check your memory reader is reading properly your MICROSD Card, or maybe you inserted your memory card without reformatting first on your cell, this will have a problem. To make sure that you get the file pictures on your memory card, run your cell on the computer and copy all the pictures inside then reformat your memory card. Good luck!
Jul 22, 2009 | PNY 2GB microSD Memory Card
Memory card cant be read My 4gb SanDisk microSD memory doesn't read on my computer. I bought it today at Radio Shack.
Are you using a card reader? If yes, you need to isolate the problem. Please follow the steps below:
1. Try connecting your memory card reader into different USB port of the computer.
2. Try using different card reader to see if there's a problem with the card or with the reader.
3. Connect it into different computer.
4. Remove and reinsert the MicroSD in the card reader and make sure that the card is properly seated.
5. If the card reader and the computer are working but still unable to detect the MicroSD, try to reformat the card.
6. If same problem persist, return it to the store and have it replaced.
Have a great day!
May 26, 2009 | SanDisk 2GB microSD Memory Card
Sandisk microSD 2GB : well formatted on cellphone but...
its not the adaptor its the card hence it gives you the error means it can access it. is the card working 100% when you plug it back to the phone?
Mar 09, 2009 | SanDisk 2GB microSD Memory Card
Motorola Mobility E770 Cellular Phone Logo
48 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
