Question about Bosch Integra 500 SHX42L15UC 24 in Builtin Dishwasher
Re: bosch-integra-500-shx45p05uc PEASE, please, tell me how to turn off the annoying signal that comes on at the end of the cycle!!!!! Who had the big idea to add this feature and what is so important about being alerted when the dishes are clean? And if it can't be turned off, is there a way to disconnect the wiring and disable it? If so, how and if not, is it legal to shoot your brand new dishwasher or throw it out the window? Thanks so much!
SOURCE: Strange noise from my Bosch Dishwasher SHU66C02UC/14
my dishwasher started making a load noise last night found out it was the pump . It was a easy fix to access the pump you need to remove the outer side of the door and the bottom cover .then you can see the pump .to remove it you need to remove the clear hose in front of it .it just pulls out of the tank sealed by a o-ring move it out of the way next unplug the wires to the pump .then you will see a plastic clip on top the pump just push the clip and turn the pump clock wise about a half turn and pull it out replace new one make. sure you get all the water out off the bottom tray before running theres a swicth that will keep the pump running if leak
Posted on May 08, 2008
here2helpBSH
  • 27 Answers
SOURCE: Loud humming noise when dishwasher is filling up with water
your model is pretty new. just so you know your warrenty is 1 year parts and labor. 2 years on parts. it should not cost that much money.
there are two components that start before the circulation pump.(wash noise you hear)
first sounds you hear will be the drain pump. usually rattling noises if something is in it but it can make a hum noise if something is jamming the drain propeller up. which is accessible with a T20 torx driver. take the filters out and the mesh filter. and unscrew the screw in the base towards the left. pull out whatever is lodged.
the other humming sound can come from the next component that activates is the watervalve. make sure you dont have a kinked water intake line. otherwise its a bad valve. i have had to change a few of those water valves out already but not for a hum noise on your model. you have a new style water valve. when brands make new parts we get problems fast sometimes..
Posted on Mar 19, 2009
  • 457 Answers
SOURCE: My Bosch logixx dishwasher is sticking on 1 minute
100% add the jet dry until it is completetly filled then close the dispenser door and lower then raise the door.repeat this at least three times then check and fill if you can still add more. then after doing that b4 you start the machine run the hot water to get the right temp. when the water is hot enough then start the machine.
Posted on Mar 03, 2010
SOURCE: Bosch dishwasher timer sticking
I have been told to replace the timer which I am looking to do the same to my machine!
Posted on May 25, 2010
Vinegar or jet dry
both actually. Use a rinse agent (jetdry) in the dispenser and refilll and needed it dispenses about 2 tear drop sized drops on the rinse cycle, Vinegar will clean any nasty things left behind once cycle is done it can be used about every 2-3 months
Aug 03, 2011 | Bosch Integra 500 SHX55M0UC 24 in Builtin...
How do I turn off the annoying beeping alert after the cycle is complete?
Hello Joanna,
Welcome to FixYa.
I think I can answer your question..."How do I turn off the annoying beeping alert after the cycle is complete? "
Follow these steps for the SHV6800 will be the same...
**How to Operate the Cycle Completion Signal**
1. Open door, hold down program button (see
Beeper Table below) and simultaneously turn the unit "ON".
MODEL Program BUTTON
SHU 9950 Delay Start Hours
SHU 9910-9920 Delicate/Econo
SHU 8800/8810 Quick Wash
**SHV 6800 Delay Start Hours**...should be applicable to yours, let me know if not.
SHV 4800 Delicate/Econo
SHV 4300 Delicate/Econo
2. Release program button.
a. For SHV 6803 and SHU9950 models:
The display will blink with a code of "0", "1" or
"2". You are in program mode.
If the display blinks with a "0", you will hear
no signal (indicates OFF).
If the display blinks with a "1", you will hear a
LOW volume signal.
If the display blinks with a "2", you will hear a
HIGHER volume signal.
b. For all other models with the beeper
function:
If the machine beeps, then the Cycle
Completion Signal has been enabled.
When you push the button again and it does
not beep, it means that the Cycle Completion
Signal has been disabled.
3. To change the program, press the program
button until the desired setting is selected.
4. Turn the Dishwasher off to take it out of
program mode.
* At the end of a wash cycle, the beeper will sound
off two times, and again every 15 minutes until the
dishwasher is turned off.
Hope this answers your question and provides you with what you needed.
Thank you for choosing FixYa and good luck.
Please take a moment to rate the solution provided and a short testimony if you feel it's warranted, but also let me know if you require further assistance.
Regards,
Macmarkus :)
Oct 18, 2010 | Bosch 24 in. SHU66C05 Stainless Steel...
I have bosh dishwasher model shx46 is stak on demo cycle
lol
There is not demo cycle. Most likely your board went out and it just keeps running all the time. (common problem)
Bosch dishwasher repair in orange county, ca
appliance repair orange county, ca
Feb 06, 2010 | Bosch Integra® 500 SHX46L Built-in...
Bosch Integra 500 dishwasher turns on and starts wash cycle, turns off after 90 seconds and then there is no power on the button panel at all. The dishwasher is full of water. Now the unit will not turn on...
your controlboard is no good. find out if its a recall unit go to thermador.com which is the company that owns bosch and they can tell you the price if you have to oreder it or if its free for part and you pay labor to install
May 10, 2009 | Bosch Integra® 500 SHX46A0 Dishwasher
Bosch SHX46A (6 years old) Selected regular cycle, pressed On and closed door. Cycle did not start normally. Pump runs, but no water is coming into the DW. I confirmed the water supply line is turned on....
From your description, I doubt that the problem is door latch is the cause.
The first thing that a modern dishwasher does before it begins to fill with water is run the drain pump.  It appears that this DW is not progressing to the next cycle (inlet water) and because the pump runs even when the door is open, I agree that the controller card may have failed.
If possible, inspect all the wire connections (remove main power before you do this) ... if there is a loose connection, the controller could do odd things.
Good Luck!  Please report back what you find, OK?
Apr 14, 2009 | Bosch Integra® 500 SHX46A0 Dishwasher
How do I turn off the beepers on my Bosch washer
To turn the beep off (or volume down) on the Exxcel 7 (BOSCH WAE24468GB you do the following:
1. Turn setting dial to off. 2. Turn dial one step clockwise (wait for panel to light) 3. Keep finger on 'RPM' button and turn dial another step clockwise and release finger. 4. The default setting of '2' should appear on the display, this represents the Button Signal Volume 5. Pressing 'Ready in' button cycles through the volume settings from 0 (off) to 4 (very loud!). 6. Turn dial another step clockwise to set the 'Information Signal Volume', which is also set to '2' by default. This is the one that annoys everyone at the end of the cycle!
All the manuals are on the Bosch website, if you know the model code.
Mar 07, 2009 | Bosch Washing Machines
END OF CYCLE ALARM
The manual on my Bosch 500 plus 4.2 says to select a cycle and then push and hold two option buttons until you hear the beep to turn off the audible end of cycle alarm. Hope this works for you! P.S. It says not to try this with a load of laundry in the machine.
Jan 08, 2009 | Bosch Nexxt 300 Series WFMC2201UC
End of cycle signal drives my dog to despare and destruction.......
You should disconnect one of the wires from the "buzzer". Good luck!
Aug 06, 2007 | Bosch Axxis+ WFR 2460 Front Load Washer
Bosch Integra 500 SHX42L15UC 24 in Builtin Dishwasher Logo
75 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
