SOURCE: setting clock
Try this (it is from the instructions for a similar model): The URL for this manual is: http://books.jvcservice.com/download/685823823/19755.pdf
SOURCE: Using an external mp3 player on my JVC KD-LX111
You could try using an FM transmitter which plugs into the earphone jack on your Mp3 player, then all you have to do is tune the radio to pick up the transmitters frequency.
SOURCE: No output from speakers in car.
Sounds like a couple speakerwires could be crossed/shortcurciting somewhere...;)
SOURCE: I don't know how to connect the wires from my JVC car stereo
Radio wire colors:
P o w e r
Memory (+12v Constant)
Yellow
Ignition (+12v Switched)
Red
Ground (-)
Black
Dimmer
Pink/White (Alpine only)
Power Antenna
Blue
Amplifier Turn-on
Blue/White
Phone Mute
Light Blue (Sony only)
S p e a k e r s
Right Front (+)
Gray
Right Front (-)
Gray/Black
Left Front (+)
White
Left Front (-)
White/Black
Right Rear (+)
Violet
Right Rear (-)
Violet/Black
Left Rear (+)
Green
Left Rear (-)
Green/Black
1991 Oldsmobile Cutlass Supreme Car Stereo Wire Diagram
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 4′
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: 6′ x 9′
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
window.google_render_ad();
SOURCE: how do you set the
To set the clock please click on the link below then go to page 15.
http://a248.e.akamai.net/pix.crutchfield.com/Manuals/257/257KSFX490.PDF
Good Luck
