The Deflexion Board goes out every 3 months - Televison & Video
  • 8,617 Answers
I will need the model number of your TV in order to help you. Please respond to this same post when replying
Posted on Aug 07, 2008
SOURCE:
How do I measure continuity on a fuse
Use a multimeter set to ohms or to bleep.
Put one test point on one end of the fuse and the other on the other. If there's a deflexion or a bleep the fuse is OK.
Mar 11, 2015 | Dryers
Sony KV-36FS210 intermitted horizontal comes and goes nothing is coming up on self test. notice when tap lightly if facing tv on right side it stops. took back off just don't know what I'm looking for....
Sounds like a loose contact. Check all the solder terminals at the horizontal output as well as IC terminals, for any loose or dry solderings. Re-solder all the suspected solder terminals, by applying a little more solder, without making any solder-bridge short in between adjecent solder terminals.
Oct 11, 2013 | Sony FD Trinitron WEGA KV-36FS210 36" TV
Sony KV-28FX68B (AE-6B Chassis) starts up ok. Occasional horizontal breakup/flashes but eventually vertical collapse (few minutes to few hours) & blinking standby light (4 times). Checked for dry...
Hi
Please check around vertical outpu IC for bad solder joints and you can try to replace the electolitic capacitors in vertical output line. Check if vertical plug (which comes from deflexion coils) is well attached in place.
Sully
Sep 27, 2013 | Televison & Video
Instructions and or diagram on how to replace alternator belt for 97 mazda astina 323
This is from the Owners Handbook :
Alternator Drive Belt.
1. Loosen the alternator mounting bolt and adjusting bar bolt. Replace Fanbelt.
2. Turn the adjusting bolt until the correct tension is obtained. The deflexion should be 10mm.
3. Tighten bolts and recheck the tension.
Read more: http://wiki.answers.com/Q/How_do_you_replace_fan_belt_on_1997_Mazda_323#ixzz1yS0LNtO5
Jun 21, 2012 | Mazda Protege Cars & Trucks
Blue hue accross bottom of screen - Sony KF-50WE610
You can try doing this, turn on the Tv and select the service menu, if that tint also shows on the menu, it's most probable to be your DMD board, but if it doesn't it might be the video board..
Jul 03, 2009 | Sony Televison & Video
Turn off for couple of minutes when try to operate
Check any dry soldering on the micro processor Ic . If there is any drysoldering resolder on the board.
May 04, 2009 | Microwave Ovens
Screen not working can only see top half of screen
looking for a filters aroud of ic deflexion vertical,thias flietrs it bad or have bad soldering,looking around skin heat
Aug 12, 2008 | Televison & Video
NO DEFLEXION VERTICAL
check this link ......
http://www.freelists.org/archives/techassist/06-2005/msg00159.html
Aug 10, 2008 | Toshiba CZ32V61 32" TV
ZENITH ANALOG TV, CRT DEFLEXION YOKE
No Longer Available thru part distributors....you might try
E-BAY......T.
Nov 18, 2006 | Zenith SY2751Y TV
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
Ekse
