Question about Saeco Incanto Rondo Fully Automatic Coffee Maker Black Espresso Machine
I have a Saeco Incanto S Class rondo I think it is an older version as very manual no computer. It has a flashing red light on left side (where coffee comes out) it has a ~~ on it. The machine still works mostly but I don't know what this flashing light means. Also I want to clean it and don't have a manual. jenny
    Sergeant:
  • Saeco Expert
  • 223 Answers
That light indicate that you need to change the water filter in the tank. The water filter is either an Aqua prima
or intenza filters. If you are not using the filter I would suggest to just reset the light. You can reset the light by holding down the water button under the coffee brew button. Looks like a water drop.
You can also download the manual at www.CeriniCoffee.com
Posted on Jun 08, 2011
Saeco Incanto Rondo right red light is on and I cannot make coffee. The machine grinds the beans but does not dispense any coffee.
Try to set the machine to grind finer. Common problem with this machine when the grinder grinds too coarse, and the coffee will not fit in the brew unit during the cycle. Grinding finer will allow the brew unit to compress and the machine should complete the cycle.
If this does not work there may be another thing to try, Let me know support@cerinicoffee.com
Apr 09, 2011 | Saeco Incanto Rondo Fully Automatic Coffee...
Saeco S class Incanto Classic was working, but now no steam at all. The pump sounds like it is trying to pump, but cuts out after a coupl of seconds, hot water light comes on, red water light flashes, and...
Check the end of the steam wand and parnello, if both are clear, then descale machine, that might unblock the tubes feeding the booster boiler and the steam wand if it doesn't then you will have to do it manually.
Mar 06, 2010 | Saeco Incanto Classic Espresso Machine
Saeco incanto rondo boiler reset
There are thermostats (2) on the side of the boiler colsest to the side of the machine. There is a reset button on each between the wires terminals. Push both.
Dec 11, 2009 | Saeco Incanto Rondo Fully Automatic Coffee...
Saeco: grinder stops grinding
Hello, This may be the solution for you: having removed the ceramic grinder to clean out the unit, one of the wires on the grinder had become removed (the "center wire") on the connector. The 2 outside wires were sufficient to give me the illusion that the grinder was connected correctly, however it would only run for a half second and then coast to an annoying stop.
Check all 3 wires that connect to the grinder and make sure they are making contact.
Jun 02, 2009 | Saeco Incanto Rondo
Saeco Incanto Rondo - Lower LEFT Red Light Flashing
Its been a long time since I posted but I just had to answer this one. :)
The left one is a indicator that its time to change your waterfilter,
If you dont have a waterfilter or if you have just changed it, press and hold the steam button for about 5 seconds and then the red light should go way,
Dec 29, 2008 | Saeco Incanto Rondo Fully Automatic Coffee...
Red Light on left is blinking on our Incanto Rondo
Press and hold the hot water botton for 5 sec. and the light will go off; It will light after 1year again, to change the water filter;
BR,
Dec 22, 2008 | Saeco Incanto Rondo Fully Automatic Coffee...
SAECO Incanto Rondo espresso machine
I think you have to take it to a Saeco service center, they have to upgrade your power board in the machine.
Jul 22, 2008 | Saeco Incanto Rondo RS SBS Espresso...
Saeco Incanto Rondo Fully Automatic Coffee Maker Black Espresso Machine Logo
248 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
