Top half of agitator not working seems the drive lugs have broken have taken it apart need to find where to get the parts from???
  • 5,911 Answers
If this is a Whirlpool manufactured top loader (such as Kenmore, Estate, and Roper) they use a split-agitator design like you've described. In most cases, agitator slippage is caused by worn agitator dogs, or a worn cam assembly. You can access these components by following these steps:
1. Remove the agitator center cap or softener dispenser by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
2. If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
3. Remove the center bolt of the agitator. You will have either a 7/16 inch hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8 inch to ½ inch ratchet adapter to remove.
4. Remove the lower portion of the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make any repairs much easier.
5. Place your hand over the top of the agitator and separate the upper portion (auger) of the agitator from the lower portion and turn the top half over in your hand. The agitator cam assembly will come out in your hand.
6. With the cam assembly in your hand, pay careful attention to how everything is assembled. The cam asembly and associated parts usually wear with age and will cause the agitator to slip. If any of the cam assmebly parts appear worn, now is a good time to replace them. The entire assembly is usually sold as a kit for $20 or less.
7. When reassembling the agitator, carefully align and reinsert the upper portion of the agitator to the lower portion. Make sure the two pieces align correctly. If equipped with an inner cap, make sure it seats and seals properly. This provides an air gap to prevent water from rising in the agitator shaft and getting inside the transmission.
8. Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped).
If any replacement parts are required, they can be purchased at any of the following websites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
It is often more cost effective to purchase the entire cam replacement kit as opposed to purchasing individual parts. The kit usually includes the agitator dogs, cam, cam thrust bearing and replacements washers/seals (depends on the model number). The agitator cam assembly should be listed under the agitator parts listing. If you have questions, please post back with your MODEL NUMBER and let me know. I hope you find this information helpful.
Posted on Apr 11, 2011
Agitator seems "broken" in half.
You will need a set of adjatator dogs about 5.00 for a set..get them and we will show you how to replace.czerney@msn.com thanks for voting good luck.
Mar 15, 2011 | Whirlpool Washing Machines
Agitator drive shaft pulls out of transmission LAT2600AAE
I believe there is a set screw or screw that goes throught the agitator to the shaft.
Mar 07, 2010 | Whirlpool LSB6200PQ Top Load Washer
How do I remove the cam-drive from the agitator. The agitator doesn't agitate. the dog agitators are broken. I should be able to take the agitator apart. I was able to take off the dispenser cap...
If the bottom agitates and not the top, the problem is likely the 4 "agitator dogs" designed to allow the top agitator to turn only one way.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Look at the section on the Sears site for Agitator, basket and tub.
See the part "Dog, agitator "
Remove the fabric softener unit, lift the top agitator cap (use a screwdriver) and you should see a plastic part in the center of the top agitator with a 1/2" square drive.
Remove the drive and lift off the top agitator. Turning it over you should see the 4 "dogs", replace these and the top agitator should turn in one direction only.
Replace the 1/2" drive, the cap and fabric softener unit and the top agitator should work.
Also see the following illustrated description of the above.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=0da65cea0e338fe930b1fde153a243f0
Jan 30, 2010 | Kenmore Washing Machines
The top half of the agitater does not work it just
There are small plastic parts called "dogs" that wear out. The agitator needs pulled apart and those dogs replaced. It is fairly simple to do.
Jan 09, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Top agitator doesn't agitate properly
you have to pull hard it will come off,there are 4 plastic gears that have to be changed inside the top half,you can get them from your local appliance store for $3,let me know how you do-mike
Apr 09, 2009 | Washing Machines
Washer does spin but barely agitates
It sounds like the agitator dogs are worn.
To remove the agitator, pry off the agitator cap and remove the bolt that holds down the agitator. With the bolt out pull up on the top section of the agitator (auger) to remove it. Underneath the auger you should see 4 small white or beige plastic gears (dogs). . Replace those and it should be ok.
The part number is 80040
Let me know if you need more assistance.
Apr 08, 2009 | Kenmore Washing Machines
Whirlpool ultimate care II super capacity plus ser.# LSQ8243HQO The top half of adjitator is not turning at all. Handiman1125@aol.com
If the bottom half of the agitator is turning and the spin cycle works, then the motor coupling is good.
Check the agitator by turning it back and forth. It should work like a ratchet (turns one way, locks the other way). If you're able to turn it in both directions, the agitator dogs are worn and need to be replaced. To do this remove the agitator cap and the bolt that holds down the agitator. With the bolt out you can remove the top section of the agitator (auger) where you should see 4 small white or beige plastic gears (dogs). Replace those and it should be ok.
The part number is 80040.
If it there is no agitation or spin, replace the motor coupling.
The part number is 285753A
Mar 13, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing machine agitator upper half not working I have a Kenmore Elite
Pull the fabric softener cap off, next pull the top cap off the agitator. Then remove the 7/16 bolt in the center of the agitator. Then you can remove the top part of the agitator.
Nov 09, 2008 | Kenmore 24032\24036 Top Load Washer
The top half of the agitator (near the fabric softner comp) is skipping while it is in wash cycle
yes the top half seperates from the bottom half inside the top half are 4 little parts called dogs. the part number is 241341. replace the dogs to fix it
Nov 27, 2007 | Kenmore 22932 Top Load Washer
Washing Machines Logo
73 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
