Question about Gateway FPD2185W 21 in. LCD Television
Gateway FPD2185W - Picture goes off after logo
I have a problem similar to the 'capacitor' problem, but also have a problem with what may be a MOSFET transistor or something (voltage reg??!)
There are four T-220 package components, the back of the board is burnt, one is cracked Two have BE 5235 and D408 on them, two have BE 5X24 and D405. One is cracked and has a small bump in the case, I would imagine this part is smoked.
A couple caps are bulging, will replace them while I am in there. Any source for these parts??
  • toreson2000 Apr 20, 2009
    i just had some one drop one off at my shop to be recycled i plug it in and it flash's off and on showing the gateway logo even if it is plugged in to the computer not showing desktop so from reading above ill check and test the caps and see what else i can find
  • Anonymous May 11, 2010
    What do these mosfets run control??
    Problem Solver:
  • 3 Answers
Hmmmm.... my board doesn't look anything like yours...
what is the manufacture date of your monitor? Perhaps it's an earlier version?
Here's what the power board looked like inside mine (with the new capacitors installed):
http://www.ccountry.net/~stinkijeans/monitor/DCP14869.JPG
I replaced all my capacitors and it's been working great... BUT it blacked out again this morning.
I cycled the power cord and it came right back on, so I don't know what to do next.
I'm guessing the power regulators, but some of mine had their numbers sanded off.
Probably Gateway's idea to screw you out of fixing it yourself.
H.
Posted on Oct 02, 2008
  • Anonymous Oct 02, 2008
    Oops.... I see where those transistors are... they were on the backside... My bad... sorry.
    http://www.ccountry.net/~stinkijeans/mon...
    I was thinking of the parts on the component-side of the board. Some of mine are sanded so you can't tell what they are.
    H.
    New Friend:
  • 16 Answers
If any of you still have these monitors, and wish to sell them, i am interested in finding some to use as spare parts if i can’t get them working. send email to [email protected].
I have two of these that i have already repaired successfully.
Or if you would like to have me repair for you.
Posted on Dec 21, 2009
    Novelist:
  • 159 Answers
What it looks like you have there are Dpak (TO-252) transistors, I am going to guess that they are 30 volt amp rated ones and 5 to 7 amps
Trick to finding them is maybe trying to identify the logo letters in front of the d408 number.(looks like 406 on the picture)
Other than that is to take a gamle on a standard dpak transistor. These are obviously toasted so it can't make it any worse !!
EBAYS bammbammfran
Posted on Oct 06, 2008
  • Fran Bednar
    Fran Bednar Oct 09, 2008
    Did some searching.
    They are transistors by Alpha Omega
    Search AOD408 and AOD405
    Ebays bammbammfran
6ya staff
SOURCE:
I HAVE A Gateway FPD2185W that goes on for a split second then goes black I have already changed the 8 capacitors that i was told to change is there anything else i can do because it still does the same...
make sure there are no briged solder connections. make sure all the inside connectors were properly inserted into the connection on the boards. Check to see if you have the correct input settings by pressing the pushbuttons on the right lower side of the monitor. check all cables or switch to dvi or agp cables.
Nov 26, 2009 | Gateway FPD2185W 21 in. LCD Television
Gateway fpd2185w stopped working and will not show a screen
Check power supply capacitors for bulging top, replace them with PANASONIC FM or FC series from digikey.com
See pictures here: http://s807.photobucket.com/albums/yy352/budm/Gateway%20FPD2185/
Oct 29, 2009 | Gateway FPD2185W 21 in. LCD Television
Searching parts
try prs eletronics components uk.
Oct 12, 2009 | Gateway FPD2185W 21 in. LCD Television
Gateway FPD2185W
The next thing to try would be to resolder all of the connections on the transformers in your monitor. If you can take a few pictures of the board and email them to me I will mark the points to check and send it back to you.
Buddy
Corporate Computer
www.ccl-la.com
Aug 14, 2009 | Gateway HD2200 LCD Monitor
Gateway monitor fpd2185w goes to sleep and then shuts off
I suggest to mess around with the monitor buttons and see if you can disable it from sleeping from there. If not then try enabling it to sleep on your computer settings. A good restart after any changes is always helpful.
Jul 07, 2009 | Gateway FPD2185W 21 in. LCD Television
Gateway fpd2185w capacitor fix question
to take solder off you can get some cross wire called DESOLDER this copper wire soaks up the old solder, by heating this new desolder the old solder will jump into it and clear your way. I like the Techspray #3 no-clean model 1822-5f
and its made in the USA!
Jan 15, 2009 | Gateway FPD2185W 21 in. LCD Television
FPD2185W Gateway Monitor
its still ur power chck for swollen fillter capacitors
Oct 17, 2008 | Gateway FPD2185W 21 in. LCD Television
Open Questions:
See all Gateway FPD2185W 21 in. LCD Television Questions
Gateway FPD2185W 21 in. LCD Television Logo
960 people viewed this question
Top Gateway Televison & Video Experts
Ronald
Level 1 Expert
Jerry Greenberg
Jerry Greenberg
Are you a Gateway Televison and Video Expert? Answer questions, earn points and help others
