Question about Empire Direct Vent Wall Furnace; Modulating Hydraulic Thermostat Control (20,000 BTU) - MV-145 Heater
I've got a 23 yr old 30DV3 whose pilot light works, and the thermostat & heating element seem to work, but not well. With the thermostat set at full hot, it just barely throws out any heat at all. ???
    Brigadier General:
  • 4,736 Answers
As I'm sure you already know, Empire Comforts Systems, no longer makes that model heater and hasn't for some years, now. I mentioned that, because if your unit needs parts, they may be almost impossible to get. In any event, there are a several things that may be causing the problem.
  • Low Gas Pressure - Burner is not receiving enough gas. Check for obstructions and have gas pressure at the unit checked.
  • Clogged burner or air intake (venturi valve) is partially clogged. Clean burner ports and venturi valve.
  • Gas line Shut Off Valve at heater not fully open. Check Gas line Shut Off Valve.
At 23 years old, you've gotten your money's worth out of this unit and it may be time to replace it. Empire makes several Direct Vent Wall Furnaces that are rated as High Efficiency Furnaces. In the long run, the money saved in fuel cost, would be worth installing a new one.
Hope this helps you solve the problem.
Posted on Apr 11, 2011
Oven temperature
have a service technician examine the oven and in particular the digital controlled thermostat
from what you describe the thermostat setting is not constant (loose connection etc) or faulty digital control unit
Nov 07, 2015 | Electrolux Ovens
Pilot light goes out after thermostat kicks off
If it's a direct spark ignition type heater maybe that's how it's designed to.work .When called for heat pilot open allowing gas then ignitor spark and ignite the pilot then gas valve open and allow gas through burner then unit fires off .
Once temp is met pilot valve closes and pilot out .
Feb 19, 2018 | Desa International Heating & Cooling
Have a Baxi solo boiler 340PF, have hot water but no heating, pilot light will not stay on. how do I fix it so I get heating please?
it might be the thermal coupler....it is a piece of wire that goes from the pilot to the thermostat. very inexpensive. .I am a 50 yr old woman, and I changed mine on my furnace twice..Home Depot or equivalent should be able to help. Google "thermal coupler"
Jan 22, 2013 | Water Heaters
SMEG OVEN BRAND NEW WON'T HEAT
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Sep 08, 2012 | Smeg Ovens
Hello - I have a 6-7 yr old Whirlpool EnergySmart 50 gallon 5500 watt water heater. (Two control boards fried and were replaced free). Symptom now is not enough hot water. No 'error codes' are blinking...
1) Residential water heaters are non-simultaneous. Only one element works at a time.
Upper element comes on until top of tank is heated, and then lower element is switched on until lower part of tank is heated. Lower element keeps tank hot during standby hours
http://waterheatertimer.org/How-it-works.html
2) Typical Whirlpool energy smart has 4500Watt elements. Look at label on side of tank
If both elements were ON, that would draw 9000Watts or 37.5 amps, requiring 50 amp breaker and 8 gauge wire. V x A = Watts.
All dual-element tanks are 240V.
Whirlpool energy smart requires 10 gauge wire and 30 amp breaker so electronics are not starved during operation. If your wire or breaker are undersized, that is suspect for repeated failure.
http://waterheatertimer.org/Whirlpool-Energy-Smart-electric.html
3) Typical electric water heater heats 21 gallons per hour. First hour delivery is higher since elements heat water as you use it. Overall however, electric water heater cannot re-heat as fast as gas because gas water heater burner carries more BTU punch per minute than electric element. Gas heats about 41 gallons per minute, with higher first hour delivery.
4) IF YOU HAVE OLDER energy smart and installed newer board, then you could have non-simultaneous operation is reversed so that lower element comes on first.
Read following post at Fixya:
http://www.fixya.com/support/t8263226-our_water_heater_doing
Contact Whirlpool 1-877-817-6750
5) Another potential problem is that you have sediment inside tank and that is reducing efficiency of lower element.
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
http://waterheatertimer.org/How-to-test-water-heater-element.html
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Apr 09, 2011 | Water Heaters
I have a diplomat 4510 electric oven, the pilot light is constaintly on even when the oven is not on,the oven does not heat up, i recently replaced the element
If you have replaced the element, and it does not heat up, then I would suspect the thermostat as being the cause of the problem, more so if it is the oven pilot light that is on.
To be certain, you really need to see if you are getting a feed to the element when you you set the thermostat.
Hope this helps.
Jan 31, 2010 | Belling XOU592 / XOU593 Electric Double...
Old Magic Chef Gas Oven won't light
sounding like thermostat isn't working. If you could ohm out the t-stat should be closed when you call for heat. If that passes the test then only thing it could be is the gas valve.
Nov 24, 2008 | Magic Chef Ovens
Oven pilot light won't light
Part of the problem was my own ignorance about this particular Kenmore gas oven. It doesn't even have a pilot light. Instead, there is an electric heating element close to the burner which gets so hot that it ignites the gas. It seems that the heating element also doubles as a temperature sensor, so that it opens the gas valve only when the heating element is hot enough to ignite the gas. This heating element, called the "ignitor", no longer gets hot in my oven even though there is 120VAC applied to it when the oven knob is turned on. Therefore, the ignitor is defective. I ordered a new one on-line from "Appliance Parts of America" for $31.50 plus shipping, and this should fix the problem. If it does NOT, I'll add to this post.
Apr 21, 2008 | Kitchen Ranges
Heating & Cooling Logo
312 people viewed this question
Top Empire Heating & Cooling Experts
Paul Carew
vance jones
Dan Webster
Dan Webster
Are you an Empire Heating and Cooling Expert? Answer questions, earn points and help others
