What voltage is the charger for an amp sound rocker boomchair
Accourding to the website it is 12v 1830 amps
Posted on Jul 30, 2011
  • holamoc Jul 30, 2011
    According to the website it is 12v 1830 amps.
Great information such a nice and very useful ideas i am very inspired form you and i will buy soon Boomchair because i am daily playing game it looks too luxury..
Thanks for sharing with us.
BoomChair
Posted on Oct 29, 2011
Charger output voltage and amp
Search google for a charger for your laptop model and look at the specifications shown for the chargers available. The voltage may also be on the bottom of the laptop and also on the battery pack.
Jun 28, 2016 | Computers & Internet
I need instruction on a phone charge cord on a Riverside Bonded Leather Rocker Recliner from United Furniture Industries.
I doubt they supplied the charger for the phone, as they do not know which phone a customer would have. There are many types of phones with different connectors and output voltages. As a result, you will probably need to supply the charger for the particular phone(s) you have.
Dec 02, 2014 | Cell Phones
I have craftsmen 19.2 volt tools while using the electric sander my batteries have died and when i put them in the charger the green indicator light comes on saying they are fully charged , when in reality...
It sounds like your charger is faulty. Try to measure the voltage of the batteries. If the nominal (workingh voltage of the batteries are 19,2 volt, then they should invrease to about 22 volt while in the charger. If the voltage does shoot up when the charger is on, maybe even to 25 volts, (which should turn the green light on) the new battries are dead!
It happens!
The other possibility is that the batteries are OK & fully charged!
But!
Your sander is damaged. Again, try & measure the voltage in the sander, before & after you switch it on. A large drpop in voltasge can indicate the sander drawing too much current. Also try them in another machine if you can.
Andy
Sep 03, 2011 | Craftsman 19.2v 3/8"drill/driver W/ Work...
I turn rocker switch on with one battery I show full, plug in a different battery, turn on rocker switch get nothing, both batteries show a full charge on charger. I think one battery is 3 years old other...
Hello
Check the following:
* Circuit breaker on main control box is tripped
* Fuse blown (check fuse in main control box assembly).
* Incorrect polarity at battery terminals
* Dead batteries.
* Charging cable is still connected to charging receptacle
* One of the cable connections at the main control box is loose.
* Control connection cable disconnected
* Broken key switch
* Throttle stuck fully open
* Throttle control potentiometer broken.
* Speed potentiometer broken
* Battery voltage too low.
* Faulty charging cable.
* Charger not working.
* Charging circuitry in main control box assembly not working
If these check OK, the problem is likely to in the control connection cable or upper control box Verify that the upper control box is getting 24V. (Blue wire on red connector.)
* If the upper control box is not getting 24V, replace control connection cable
* If the upper control box is getting 24V, check key switch operation and verify wiring in the upper control box. Trace voltage from keyswitch on to find where the problem occurs. (Replace upper control box if necessary.)
* Charge batteries with a 12V charger or replace if necessary.
* Ohm test the charging cable - replace if necessary.
* Test scooter with a different charger, if new charger works, replace charger.
* Check wiring in main control box assembly - replace in line relay if necessary
* If batteries, charger, and all wiring is good, replace controller PCB. (Note the model number for the PCB, for example 1208-2330.)
Aug 22, 2011 | Shoprider SL73 Echo 3 Wheel Scooter ()
What is the voltage on the vibration moters in a boomchair svc
i found 2 boomchairs lumisource SVC i will make tst expect 12 volts 2 Amps
Jul 24, 2011 | Electronics - Others
I can't find the series # of my note book---- where can i get a replacement charger?
Any charger which fits the following conditions will be a good fit to your laptop:
1. Charger has a jack which fits in the laptop's power socket.
2. Charger can provide enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the charger. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery.
Alternatively, you can look for a universal laptop charger which is suitable for your laptop's model.
Aug 28, 2010 | Acer Aspire One PC Notebook
Have lost manual. I need car charger for Mio P550 but Mio no longer making. Have purchased Scala AC Travel Charger Part No; SEL15305 (Input voltage 100-240VAC, 50/60Hz) and end is right but not sure if it...
The important thing is the ampage. If you have your old car charger check the ampage output. A higher amp rating charger will be ok as the p550 will only draw the current it needs. The voltage you listed sounds like a house charger not a portable car charger. cars run at 12v and the output should be something like 5v dc - 1amp (normally anyway).
Feb 18, 2010 | Mitac Mio P550 GPS Receiver
Just bought a boomchair SVC and the rumble on it will not turn off. Any ideas?
I have the same problem, and after cutting the bottom open to get to the mainboard, I discovered that playing with the 4 pin (2 brown, 2 white) connector between the two boards on the main board seems to calm it, and stop it from vibrating.. I just can't get it to stay off. Bump for help!
Nov 23, 2009 | Pyramat Sound Rocker Gaming Chair
Help
That is the specs of the ac adaptor that the X Rocker Chair uses to power the speakers on.
It uses a 10 Volt Ac Adaptor that runs off of 1.2 amps.
May 28, 2009 | Pyramat Sound Rocker Gaming Chair
421 people viewed this question
 Grubhead
Grubhead
