Question about Sharp Televison & Video
Our TV is Sharp 21" Flat CTV 21V-FW75M, it has two
SOURCE: no power no light sharp tv 21V-S300
This is a classic switchmode power supply, has sensed a severe potential problem, and is shutting down to avoid a fire, explosion, or both. This set had developed a problem, that is so severe that the set must be shut down, This set should be removed from the Power, and in my professional recommendation, you should get a "Quote" for repair, from, an, Approved Service Center, this point is very important for a good result, Always contact, their local, "Head Office" Now, when you get the information you want, then you can decide as to repair of replacement. The reason we want an approved agent, is that way, all the engineers are trained on their own brand sets, they have seen almost all faults, and will get the job done quicker, and for less cost, and usually have parts on hand, also sometimes, there has been a service bulletin in issued and the repair may be subsided or even free. There are many, many, many reasons that display this symptom, one must work through the troubleshooting steps to isolate and identify, the Cause and repair that and any damage done
Posted on Oct 11, 2011
SOURCE: 21v-l70m
sorry bat you heve need the asistence califications your problems,needs oscilografition/time
Posted on May 23, 2007
jingjao
  • 252 Answers
SOURCE: 21pt2216/94 phillips 21'' audio problem
your speaker maybe busted or check the amplifier IC
Posted on Oct 22, 2008
  • 255 Answers
SOURCE: how to solve the problem of sharp tv 21 inch, is
Use the remote control to power it on, it behaves so if switched off with remote control.
Posted on Sep 25, 2009
  • 1274 Answers
SOURCE: what is the number of audio ic for philips 21
look for a 8 pin chip,hope this helps.....
Posted on Feb 23, 2010
Ask for a resistor value of r704 on sharp model 21v-fk200m
Sharp 36C-230 36" TV Repair Questions,... - Fixya - Answer
www.lpjaz.com/support/p217124-sharp_36c_230_36_tv
I forget my password TV sharp model 21s-fx10a ยท Sharp Standard. ... What is thevalue of resistor R704 in SHARP TV model 21V-FK200M circuit diagram.
[WML]sharp 21v-fk200m flat screen crt
www.elab.ph/forum/index.php?topic=41147.0;wap
sharp 21v-fk200m flat screen crt. Pages: (1/4) > >>. bobet20: pahelp po mga master,may problema ako malaki,,,sunog po resistor sa power supply r704,,syaka
Dec 28, 2015 | Sharp Televison & Video
Resistor value of R704 of Sharp tv model 21v-fk200m
How do i unlock sharp crt tv model 21v-fk200m? i forgot the ...
www.fixya.com/.../t25439922-unlock_sharp_crt_tv_model_21v_fk200...
Feb 17, 2015 - Question about Sharp Standard (CRT) Televisions .... What is the valueof resistor R704 in SHARP TV model 21V-FK200M circuit diagram.
Sharp value 2 watt resistor Standard (CRT) Televisions ...
www.fixya.com > ... > value 2 watt resistor > Standard (CRT) Televisions
value of r707 sharp model #27c241 R707 is 27 ohm 1/2 watt carbon resistor,if you ... What is the value of resistor R704 in SHARP TV model 21V-FK200M circuit ..
Schematic diagrams of Sharp Color TV 21 Alexander Pro Model No. 21V-FX300S.
Check the IC numbers used in it kit; and distinguish which company kit is used with. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Feb 11, 2015 | Sharp Televison & Video
Tv stays standby mode
There are a few possible reasons
1. Line scan has failed - line o/p transistor
2. Frame scan failed (unlikely)
3. Power supply problem/chopper transistor
4. (and hope it's this because all you need is a soldering iron, good lighting and soldering skill) Dry joints or cracks around line output stage
May 17, 2014 | Sharp CTV 21V-FW150M BLK
I have a crt tv sharp model:21v-fw150m blk.. is
Try to download the repair manual to this TV by internet. It has all details.
Oct 05, 2013 | Televison & Video
My sharp tv 21" 21V-FR95s CRT tv
tried to re soldered first the main board, at the video section. sometimes it was a loose or dry joints on the pin of the parts in the pcb.
Feb 01, 2013 | Televison & Video
The problem of my sharp tv model 21V-FR80M is after powering it ON 3-5 seconds the tv will turn OFF?what could be the posible cause and trouble? PLS KINDLY REPLY AND HELP ME TROUBLE SHOOT!THAKS!!!!
the tv goes to "safe mode" to avoid damage to the main board, your problem should be related to a bad caps on the power supply due the tv turns on and off
hope that this help u out
http://www.bostonrecycling.net/
Jun 18, 2012 | Sharp Televison & Video
What is the code of sharp tv model 2V-FW75M
Hello
You are asking about the universal remote code for Sharp I assumes, and place this solution before you.
Three digit universal remote codes for Sharp are:
004/ 009/ 079/ 095/ 111/ 112/ 114/ 122/ 123/ 124/ 173
Four digit universal remote codes for Sharp are:
0079 0123 0063 0020 0004 0009 0226 0266 0006 0095 0122
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand
May 16, 2011 | Sharp Televison & Video
21v-l70m
May 23, 2007 | Sharp VT-G21 21 in. TV/VCR Combo
Televison & Video Logo
116 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
