Question about Refrigerators
At the bottom of my Kitchen aid Superba 48 refrigerator...there is an adjustment to limit the door opening. there are no pin limiters there...either they broke or fell out over time. How do I fix this
  • goldsweet Apr 13, 2011
    you didn't give me a solution...there are screwed in stops that keep the door from opening all the way.
    It's a limiter of sorts. where do i get the part to adjust the door opening. there are threads for some part to screw into which would limit the opening. one was bent or broken on the floor when I discovered this.
    Brigadier General:
  • 3,917 Answers
Hi
Yes, the door should have a door stop on it under the hinge. It screws to the door then hits the hinge when it gets to about 160-170 degrees stopping from opening more.Somtimes if a door is replaced this part is left off or yours maybe damaged. However most refrigerators do not have anything to prevent the door from opening all the way. To minimize this , adjust the front leveling legs up enough so the door won't stay open by itself. The refrigerator doesn't have to be level, it just should not rock. Most are adjusted this way to let the door shut itself. This should help. If this doesn't work make a strap with small chain or seat belt type material. Attach from the bottom of the door. Make it just long enough to not let the door open past 90 degrees.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Apr 11, 2011
Is the filter behind the kick plate on the Kitchen Aid Superba made in 1998?
Hi, the filter should be on the bottom kick plate and should have a cap of the same color as the kick plate.
Hope this helps
May 23, 2014 | KitchenAid Superba Architect KSCS25INSS...
No door adjuster on my kitchen aid superba o move the door up and down.
Yes, there is no adjuster so you will (a)just have to be clever and use an old carpenter's trick. To raise the door you simply place washers of different thicknesses over the hole where the bottom pin of the door goes in.
Jan 04, 2013 | Refrigerators
Kitchenaid superba ksrg25fkwh01 wire harness
Called Kitchen aid and protested, frig was 4 years old at the time. door was almost $1200 to replace. Kitchen aid paid for new door and installation
Sep 19, 2012 | KitchenAid Superba Architect KSCS25INSS...
Kitchen aid top shelf warm
  1. check gasket
  2. check the light switch on top of the refrig. section. If then pushed the switch turns the light off, but the light is still on with the fridge door closed - door needs adjustment.
Oct 13, 2009 | KitchenAid KSS48QM 48" Built-In...
Kitchen Aide Superba 48 1997, refrigerator door remains ajar,Fix?
They actually make a guard that acts as a height shim. You do need to remove the door to install it though. Try looking at appliance411 they usually have some insight into out of the ordinary parts. Hope this helps. Good luck.
Aug 04, 2009 | KitchenAid Superba Architect KSCS25INSS...
Ksrs25ikss01 kitchen aid fridge portion not
1.check if the fan inside the freezer is running
2. if ref runs none stop, defrost timer is out.
3. or it could be the high limit that paired in series with the defrost heater
good luck!
Jun 25, 2009 | KitchenAid Superba Architect KSCS25INSS...
Problem with KitchenAid Superba KSRG25FK Side/Side Refrigerator
I found you looking for keep en mind kitchen aid is made by whirlpool good luck :) http://www.appliancepartspros.com/partsearch/model.aspx?model_id=504094
Jun 12, 2009 | KitchenAid Superba KSRG25FK Side by Side...
Kitchen Aid Superba - door needs adjustment
there is two bolts oin the very front of the unit behind the kickplate the oiu can turn clock wise until there is a slight tile toward the back of the unit so that the cams on the doors will have a little bit of gravity to helop them stay shut.
Mar 26, 2009 | KitchenAid Superba Architect KSCS25INSS...
Kitchen aid superba door problem
HAVE YOU TRYED ADJUSTING THE TOP HINGE?MIKE
Oct 15, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kitchen aid -Superba 42,
Make sure the fan motor is running in the freezer.
Sep 15, 2008 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
