Question about Maytag Dryers
I have a Maytag Neptune MDE 7500 AYW that has been a great dryer. Yesterday when I went to dry a load, I found no heat. Everything else works great. Flipped the circuit breaker off/on a couple of times - still no heat. What would you suggest might be the problem?
  • Maytag Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks.
If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the
wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed
component. The switch is inside the dryer main housing near the door frame.
Sometimes you need to raise or open the top or front of the dryer to reach the switch.
Check for continuity you should have none with door open, and should have a reading when closed.
If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause
heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the
thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape
or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged
with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's
plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace an element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please rate me
Posted on Apr 11, 2011
My Maytag electric dryer model# MDE 4658 AYW does not dry my clothes (no heat) and the light no longer stays on when the dryer door is open. started happening after i turned all fuses off in the house. can...
I gotta assume you're joking since it looks like you're asking why the dryer isn't working when you've turned all the power off in your house.
If this is the case then the only way your dryer is going to function is if you bought it with the optional Maytag Cold Fusion power supply. Or you could turn the power back on...
Oct 30, 2013 | Maytag Dryers
Dryer won't heat maytag neptune mde 5500 ayw
Hi
If the dryer is not drying the clothes then you would need to check for the following things-
Electric Dryer---
1. Inspect the fuses and circuit breakers they may have burned out or tripped. Usually, dryer will still tumble but not create heat if a fuse or a circuit breaker is not working.
2. Check for the amp reading at 240 V, it should have reading of 24, 21 and 3 amp (approx.) for 2 lines and neutral respectively.
3. Heating element may have turned or the connection to the element might be loose. Sometimes a shorted circuit element will keep on blowing the fuse or circuit breaker.
4. Motor wiring shorting to ground.
Hope this helps...
Daniel
Sep 20, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Neptune glass front takes 4 hours to dry clothes.
make sure the vent system is clean. any restrictions can cause the safety switches to activate and turn off heaters. When it cools, the switch resets and starts heating. Unit will continue to cycle the heat off and on. Make sure all elements are working.
Start there.
Jun 07, 2010 | Maytag Neptune MDE6700A Electric Dryer
Maytag neptune dryer model mde3000ayw
you want to start at high limit thermostat or thermal fuse
its white and has two small wires
it sits on the heat tube
it could be black too
it is shaped like a warped ball
and is rather flat
sears has them in stock
ive included the part number to help
307473
Oct 09, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag dryer access to the thermal sw
moz-screenshot-4.pngThe thermal limit mounts beside the heater element chamber and is held to it by the same screw that holds down the element.
The kit comes with 2 limits one fer gas the other fer electwic.
Sep 02, 2009 | Maytag Dryers
My Neptune mde 9700 dryer heats inconsistently. more times than not it take forever to dry a load nomatter what the size
you have either a thermistor at fault of the heating element isnt operating properly
Aug 21, 2009 | Maytag Dryers
Maytag Neptune Dryer-stopped heating
first, check the exhaust, make sure every inch of it is clean on the inside. if there is any blockage, the heat will build up in the exhaust and a sensor will shut down the heating element.
Oct 27, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag neptune dryer wont restart mde 3000 aya
Your dryer needs a new motor. It should cost about $200-250 including labor. Call a local repairman - not a national company. Give him the model number and ask him to bring the motor with him.
Mar 31, 2008 | Maytag Neptune MDE5500AY Electric Dryer
MDE 9700 AYW Maytag neptune dryer
My dyrer just stopped working one day. I've had the heating element checked, both boards and my electrical outlet checked but my dryer still doesn't work. All I get is a troubleshooting code that looks like an upside down F with a 5 behind it. If you have a solution to this problem please let me know Thank You.
Dec 05, 2007 | Maytag MDE9700AYW Neptune 174 Electric...
Dryers Logo
249 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
