Question about Refrigerators
Norcold N821 Refrigerator. Built after 11APR06. When using A/C voltage I get an error code "A." I had to reset the unit to get the gas portion to function. on the diagnostics menu it says A/C power is not present. I have 115 VAC present at the fuse. The fuse is good at 0.1 ohms. Is there a schematic available for the circuit board? I would rather replace a component than spend $200.00+ on a new module. Thank you for your assistance. Daniel Smith Williston, ND.
  • Refrigerators Master
  • 4,654 Answers
Yes there is a schematic but it may not be the best approach to the solution. You may be losing a chip on your board because of what I call bad batch and Quality Control failure.Also the boards owner may not want their board schematic published. Most times when people experience these related problem's you are having they share Q&A in their related group. Daniel here is that group and your answer may be found there. If ths is not the answer you wanted to hear please don't rate. I have found my way around the last 30 years asking those that have been there and done that and it works for me. Click Here=> Norcold N821haywire!
Thanks, Sea Breeze
Posted on Apr 11, 2011
  • John Tripp
    John Tripp Apr 11, 2011
    Almost forgot to say click on were it says=> PUT IN AUTO MODE 3D MANUAL FROM BOTTOM.
    That give you up to date information, Sea Breeze
I have a Norcold 2 door fridge. It works fine on propane or electric but I hear a VERY loud bang and see flames shoot out. It is a propane leak some place but checked fittings and lines -no leaks.
is this new? never been used before or old. ? please read this
Norcold, Inc. Product Recalls - Call 1-800-767-9101 Monday - Friday 8:00 am to 8:00 pm EST
The Norcold, Inc. refrigerators listed below have been recalled.
It is important to implement this safety enhancement to prevent an unsafe elevation in the temperature of the cooling unit should the unit fail in operation. This enhancement seeks to minimize the risk of injury or ***** due to fire.
Norcold Inc. has decided to recall certain 1200, 1201, 1210 and 1211 model gas/electric refrigerators with serial numbers from 315525 to 13088811, non-consecutively. The refrigerator's model and serial number are located inside the fresh food compartment. These refrigerators may have cooling units with a cooling unit serial number between 700000 to 13085759. This is a new recall campaign to include all 1200, 1201, 1210 and 1211 models.
Even if your refrigerator was repaired as part of a previous recall, it is necessary to have it repaired again to minimize the risk of injury or ***** due to fire.
If you have one of these refrigerator models, use the following procedure:
  1. Identify and write down the refrigerator model. If it is a Norcold 1200, 1201, 1210 and 1211 model, go to step 2.
  2. Identify and write down the refrigerator serial number. If the serial number falls in the range of 315525 and 13088811, go to step 3.
  3. Identify and write down the cooling unit serial number. If the serial number falls in the range of 700000 and 13085759, go to step 4.
  4. Call your dealer immediately.
The installation of the High Temperature Sensor will be at no cost to you.
Owners of recalled refrigerators should NOT operate their refrigerator until it can be professionally repaired by your dealer or a Norcold authorized service center.
If you have one of the recalled refrigerators and you:
Currently reside in the RV, you should immediately:
  1. Set the refrigerator controls to "OFF".
  2. Unplug the refrigerator through the service vent on the outside of the vehicle.
  3. Contact your dealer, a Norcold authorized service center or Norcold's Recall Center at 1-800-767-9101 as soon as possible to get assistance.
Do not currently reside in the RV, you should immediately:
  3. Disconnect from shore power.
  4. Contact your dealer, a Norcold authorized service center or Norcold's Recall Center at 1-800-767-9101 as soon as possible to get assistance.
Failure to follow these instructions can result in a fire causing injury or *****. To locate an authorized service center,
http://webcache.googleusercontent.com/search?q=cache:tnsP3IdSqhgJ:www.thetford.com/customer-support/recall-information/+&cd=10&hl=en&ct=clnk&gl=uk
if you have this model STOP using it!!!
Jun 19, 2017 | Refrigerators
Thetford gas igniter burns but ignition is not seen by control unit
Without the make & model...
the only answer possible is a "TYPICAL" SWAG: Looks like NORCOLD is most likely your manufacturer (although I've also seen U-Line).
SPARES are good to have... (now you understand).
On-Line parts abound everywhere... It is likely an "electric"
(because of your control board statement).
I'll put up sample Pix from Amazon & eBay.
http://www.ebay.com/sch/i.html?_nkw=Norcold+Refrigerator+Thermocouple
Your THERMO-COUPLE (flame monitor)... same (type) thing that always fails on our water heaters... typically costs $6 if you are buying one in advance... up to $24 (twice that for the "Refrigerator versions" $12 to $48) in you hour of need... Unless you call a "service" (plumber) person... Then just start adding on those ZEROs.
These also can use an INTERRUPTER (same price range)...
Buy them both... As you can tell... they are good spares to keep around (I always buy a NEW thermo-couple & put it on a nail
with a "NEW water heater installation (keeps evil spirits away).
I'd recommend you post the complete make, model & year...
Defective GAS appliances can be quite deadly... even if the work is done properly... improperly the sky (is quite literally) the limit...!!
Could NOT more strongly URGE... Buy and USE a good carbon-monoxide monitor/alarm.
Truly a LIFE-SAVER.
All gas utility companies will (or used) to QUICKLY send out their representatives to inspect/light gas appliances..
Historically this was always a FREE SERVICE...
(but sadly that the extent of my knowledge... HISTORIC).
Be safe... Comment me back if you need:
(never test for leaks with a match... My grand-daddy taught me that (course hair & eyebrows grow back... MOST of the time).
Norcold Refrigerator Thermocouple
Apr 11, 2016 | Refrigerators
Norcold fridge in my motorhome
Norcold fridges are now part ofThetford one of the largest suppliers of mobile and marine products. You do not quote the model so not sure if a 3 way (gas/mains/12v) or AC/DC. The most common problem with all mobile fridges is the heater unit is faulty. Thetford have discontinued spares for a large range of norcold models. Information can be obtained on the Thetfold.com website.
Good Luck
Jul 09, 2014 | Refrigerators
Want to reset board on N611 norcold ref
The Norcold board reset is done by jumping a pin terminal to ground. There are several steps involved but it's all pretty straight forward. Here is an article on the steps of doing this: Norcold Refrigerator in Lockout Mode do you need to reset your power board
Jun 09, 2011 | Thetford Refrigerators
Norcold model 1200LRIM. Unable to select AC or LP mode. Auto is only option. Fridge frequently quits in Auto mode. No error codes. Display just goes blank. Battery connections are good; voltage is good....
Try to unplug it from the battery a few hours and then plug it back in and see if you are now able to select the AC or LP mode. There has been a recall on the 1200LRIM, The defect is a potential cooling unit leak caused during AC electric mode operation. Click on the link below to read more:
http://www.texastriallawyer.com/norcold/index.html
Nov 21, 2010 | Thetford Norcold RV Cooler/Freezer
Norcold model n611rp works on gas but not 12 volts is there a relay in curcuit board have14.2 volts going in but hear a click and five seconds later it clicks again thanks tom
Sounds like the unit may not have enough DC power. See the manual.
http://www.thetford.com/HOME/PARTS/NorcoldIncRefrigerators/GasElectricRefrigerators/322323Series/tabid/472/Default.aspx
Nov 15, 2010 | Thetford Norcold N323 1.7-cu ft 3-way...
How do you reset circuit board on norcold refrigerator
No way to do that other than to unplug refrigerator for at least ten minutes and then plug back in. Don't use surge protector, power strip, or extension cord.
Sep 21, 2009 | Thetford Norcold DE0051 Refrigerator
Frig will not cool
I had a similar problem. One thing that I need to know is is it cooling at all? If everything is operating, but no cooling occurs, you may have a bad board. This controls all of the components. Getting it replaced could be pretty pricey. Good luck, and please rate.
Jun 18, 2009 | Dometic NDR 1292 Refrigerator
Frig does not go below 52 degrees.. Freezer OK
MAY HAVE PUNCHED HOLE IN EVAPORATOR AND GAS LOW????
Refrigerators Logo
344 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
